Question about Fuji FinePix F610 Digital Camera
Camera stuck in open position.
When I switch off there is a whirring noise but camera doesn't close down, it remains with lens in zoom position and shutter open. Help?
  • Margaret B Jan 10, 2008
    Managed to close camera but it jammed again when re-opened so guess its damaged permanently!
  • Fuji Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 10, 2008
6ya staff
SOURCE:
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
Lens problem
the lens needs replacement.
for reparing estimates cost of camera
http://www.advancecamera.com/repair
the link will help you to get the device repaired and serviced
· Free estimates.
· Reasonable rates.
· Fast, friendly, and personal service.
· Top quality repairs.
· Advance Camera 1 Year Warranty
Apr 01, 2009 | Canon PowerShot SD1000 Digital Camera
Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Dec 05, 2008 | Canon PowerShot A550 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Turn camera on and it zooms all the way in
hi, i've an fx8. i had a problem 2 weeks ago. my objective didn't want to close when i switched the camera off. it remained open. when i switched the camera on again, the objetcive has closed and opened again, and remained in this position after switching it off. i tried some button combination, like menu button on, and power the camera on. it didn't work, but the second was the shotting button on, power on combination. an it worked, my camera did some kind of reset. it returned to the original position, and everithing is working since then. so try it.
Jun 26, 2007 | Panasonic Lumix DMC-FX9 Digital Camera
Lumix DMC FX8 lens cap opens intermitently,some images shoot rotated 180 degrees
hi, i've an fx8. i had a problem 2 weeks ago. my objective didn't want to close when i switched the camera off. it remained open. when i switched the camera on again, the objetcive has closed and opened again, and the _Turn Off the Camera and Turn On again_ message appeared on the sisplay. and remained in open position after switching it off. i tried some button combination, like menu button on, and power the camera on. it didn't work, but the second was the shotting button on, power on combination. an it worked, my camera did some kind of reset. it returned to the original position, and everithing is working since then.
Feb 12, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera- lens is stuck
The lens assy. has gone bad if it is making noise. If it is only stuck and not moving the power supply link is broken and supply is not reaching the lens assy motor. May be the SMD fuse would have blown in power supply circuit. May be you can seek the service manual from me and this calls for highly skilled workmanship and tools.
Dec 16, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Fuji FinePix F610 Digital Camera Logo
145 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
