Question about Intel D945GCCR Motherboard
Hello Im using D945GCCR MD. MY COMPUTER PROBLEM IS RESTAR PROBLEM.
    President:
  • 414 Answers
Probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/daughter or addon card(s)..
..plz do check the following as in order:..
the Hardware part:..
1)a)in poweron mode, open/unplug the data/vga cable of the monitor from cabinet..seeif raster or 'osd' is appearing on the monitor screen..if so monitor isok..else replace the monitor and see..[not applicable in case oflaptop]..
b) in case of laptop try to get output from externaldisplay unit/monitor using vga port..if there's proper display inthere..the problem is probably with either the 'lcd' or 'ccfl' or'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4)seeif the ram(s) is loose/faulty..open clean/remove carbon & or oxideformed on the teeth with an eraser n resit it..or replace with a standbyn see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6)remove/clean dustneatly..dust is non-uniform in nature n may causejam/short circuitry/excess resistance n many more..resulting an increasein heat..
7)open the CPU Heat-Sink with fan out of thesocket..put some "Heat Sink Compound" (available in local electronicschip level spare market)between the cpu/processor and the CPU Heat Sink*** fan..resit/fit it tightly in position..if necessary change the fan..
8)on main/motherboard..see with a debug card for mb error..may b short..look fordefective capacitors(espabove1000mfd)/mosfets..go through the mb'ssouth bridge n the circuit lie around atx connector..the crystal clockgenerator (if cpu isn't heating up)..
9) [in case of desktop] thesmps itself may b defective/faulty..check the outputs of smps viz. 0v(black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg&grey~sb); -12v (blue);-5v(white); +3.3v(orange)..the 'oscillator anderror amplifier ic',or pwm switching regulator circuit..lookfor defective protector-transformer/resistance (esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
the Software part:..
1)hvalicensed and UPDATED antivirus installed (i preferavg/kaspersky,remember, without updation a full version antivirus isuseless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'removeall the unnecessary startup items from here..(if u can't find whatto remove, post me/us in ur comment with all the items listed in eachn every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a)'Automatically Restart'right click on my computer->properties->advanced->startupn recovery->(uncheck on the) Automatically Restart;
b)'Error Reporting'right click onmy computer->properties->advanced->error reporting->disableerror reporting->(uncheck on the) 'but notify me when critical erroroccur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r not a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 16, 2009
How much HDD (GB) does Intel d945gccr support ?
This is a discontinued MB from Intel and therefore does not have Windows 7 support. So the latest MS OS you can load is Vista, but obviously you can also load any Linux based or Ubuntu etc on it. But the size of HDD you use is not dependent on the MB, but depends on your Operating System you use. Vista 32 bit can support as much as 256TB. SO choose your operating system carefully. The same with the RAM. But there is no relation in terms of HDD size and amount of RAM, rather RAM to OS again.
Sep 12, 2012 | Intel D945GCCR Motherboard
D945GCCR Motherboard: i dont have a ethernet controller ethernet contro...
dude there is and in built ethernet just installdriver or maybe built in would be disabled ..enable from bios and try again or just buy new 1 it will cot not more than 300rs
May 17, 2010 | Intel D945GCCR Motherboard
Net md walkman mz-n510 can't transfer from md to pc
i have same problem. maybe the tracks on the minidisk were not transferred from the same computer, as in I bought some disks that were already full, but my computer said error when I tried to delete.
Solemuso
Jun 29, 2008 | Sony Net MD Walkman MZ-N510 MiniDisc...
Sony Net MD Walkman (MZ-N910)
had the same problem a few minutes ago!
removed the battery but it didn't help.
tried with another md, no success
tried the same md in another Mz 910, no success
then it got on my nerves and I gave the MZ n910 a little shock with my hand.
It worked, stopped spinning and started to play.
It was, I think, a spinning problem, md couldn't play properly, the little shock helped.
Apr 09, 2007 | Sony Net MD Walkman MZ-N910 Portable...
Intel D945GCCR Motherboard Logo
79 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
