Question about LG 37LC7D 37 in. LCD HDTV
Like a dust mark streak top right hand corner
  • 79 Answers
That's is sad..you should call the tecnician..the liquid from the t.v as spread.
Posted on Nov 16, 2009
How can I check my purchases so that I can find my voucher?
Hi Anne
On a computer: Select "my vouchers" in the upper right-hand corner of the page.
On a mobile phone: Select 'vouchers' at the top right-hand corner of the screen.
In the iOS app: Select 'vouchers' at the bottom right-hand corner of the screen.
In the Android app: Select the menu button in the upper left-hand corner of the screen and select 'my vouchers'.
From the "my vouchers" page of your account, you can also sort your vouchers by expiration date -- this is a convenient way to see which ones you need to use soon or mark a voucher as "used" to remind yourself that you've already enjoyed it!
May 01, 2016 | Cell Phones
Tip
Scan lines are generally due to dust or marks on the white reference strip ...
Steps how to clean scanner glass
1. Unplug the power cord.
2. Clean the outer case with a cloth dampened with a mild detergent and water.
3. If the document table glass gets dirty, clean it with a soft dry cloth. If the glass is stained with grease or some other hard-to-remove material, use a small amount of glass cleaner and a soft cloth to remove it. Wipe off all remaining liquid.
4. Ensure that there is no dust on the glass of the document table. Dust can cause white spots in your scanned images.
*** CAUTION: Do not press on the document table glass too hard.
5. Be careful not to scratch or damage the document table glass, and do not use a hard or abrasive brush to clean it. A damaged glass surface can decrease the scanning quality.
6. Never use alcohol, paint thinner or corrosive solvent to clean the scanner. These chemicals can damage the scanner components as well as the case.
7. Be careful not to spill liquid into the scanner mechanism or electronic components. This could permanently damage the mechanism and circuitry.
8. Do not spray lubricants inside the scanner.
9. Never open the scanner case.
***NOTE: Wipe the inside of the document cover and the scanner's document table before scanning transparencies.
on Aug 28, 2009 | Epson Perfection V200 Flatbed Scanner
How do I send a photo from album to friend ?
Go to Photos / press select (top right hand corner) / select the photo you want to send (a tick mark will appear on it) / select the box with an arrow pointing upward (top left hand corner) then select the method you wish to use to send it (message / Mail etc) then send it using this method in the normal way.
I hope this helps
Mar 13, 2015 | Apple iPad 2
I am printing envelopes and have black ink marks and streaks across the left hand side of the envelope (return address area).
There is dust & ink build up on the printer head. Take it apart. Wipe it off by hand with print head cleaner & lint free cloth.
Apr 05, 2011 | HP PHOTOSMART PLUS B209A All-In-One...
BLUE FINGER LIKE STREAK ON TOP RIGHT HAND CORNER
Sony A10/A20 TV Class Action ' Home Follow this link to the world of Sony optical block headaches. There have been three class actions so far, and a few more in the wings. Contact Sony customer support and climb the ladder if necessary. Hope this helps
Jan 16, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
HP Laserjet 2820 Streaks on Page
There are 3 parts to the imaging process that could cause your issue. You have the toner (x4), the imaging drum unit (Q3964A) and the fuser unit. If you are getting streaks from all colors, one or more these parts are the issue.
Let's start with the easy stuff:
Open the cover as if you were replacing toner where you can "visually" inspect the toner and imaging drum. Pull the drum out and pull back the "plastic shutter" on the top, this will expose a green drum CAUTION! Too much exposure to light and touching it can cause damage. Just take a quick look trying to see if any of the lines on your page match any marks on the drum. Check the bottom half of the unit as well there should be a white section across the bottom, expect that as well.
Next look at the toner, if you can look at any other color but black it will help you look for the streak marks a lot easeier. If you couldn't see any streaks on the drum on toner cartridges, it's time to look at the fuser unit. Power the machine down and turn it around, unplug it then fold down the blue clips and CAUTION! the fuser heats the toner to the page so if it's been used recently it may be hot. once the clips are down, just pull straight back and look for the streak marks.
Sorry for the book, but I hope it helps.
Jul 30, 2009 | HP LaserJet 2820 Printer
Career mode freezing up after playing a game
You may need to clean your PS2 mine did the same thing tilli cleaned it. the littlest bit of dust messes with it. hope this help you have a good day.
Mar 26, 2009 | Sony MLB '08: The Show
Color separation
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Panasonic PT-51HX41 51" Rear Projection...
LG 37LC7D 37 in. LCD HDTV Logo
87 people viewed this question
Computer Repairing
Computer Repairing
