Question about Braun Syncro 7526 Electric Shaver
I have a braun 7570 shaver. the blue button is jammed in and the shaver wont switch off can i get a replacement front sliding part ?
4 Suggested Answers
SOURCE: I have the same problem with my Braun 7570 as the Jan.8, 2008 writer about the 7526 or 7680 shaver. The blue button came off but the shaver still works
Pry out the blue button. In the oval hole where the button was you will see a thin metallic part (semi-circular shapes on each side); pull it out through the hole and the switch will be functional.
Posted on Aug 12, 2008
brector3
  • 1610 Answers
SOURCE: Braun 7570 shaver won't switch off!
Most likely, the switch mechanism is broken inside and will need to be replaced. This part comes with the outer housing of the shaver and is available at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-syncro-body-housing-select-models-p-811.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Posted on Jun 29, 2010
SOURCE: braun 7570 shaver wont charge but wont run on mains lead
My Pulsonic Razor that I received for Christmas will not run on battery, or with the plug supplied. I have tried just about everything I can think of. Is there a way to solve this problem? I do not have a receipt as it was a gift and am quite certain it would cost me a small fortune in order to fix it at a Braun Service centre.
Please help me if you can. TY
jbabcock12@cogeco.ca
Posted on Aug 08, 2010
I have a Braun 7570 and it is marvelous! I replace foil and cutter every year. This time after replacing it the shaver did not cut my hair. Battery still gets full charge. What is the problem?
Most likely, the 'drive unit' is bad. The drive unit is a component that consists of the swivel frame that the head snaps onto and the motor. Excessive noise while the shaver is running is also a major sign that this part is bad.
Unfortunately, Braun no longer provides these type of replacement parts for any of their shavers. You may end up needing to replace the unit.
Since you apparently like that model and you have spare shaver heads for it, you might want to consider a compatible model as a replacement. shaveroutlet.com has a new model that uses the same foils and cutters as your 7570. You can see it at the link below
http://shaveroutlet.com/shavers/foil-shavers/braun-series-1-195s-mens-cordless-shaver.html
Feb 19, 2014 | Braun Syncro 7570 Electric Shaver
Where can I buy foil for Braum shaver 7570
braun 7570 replacement foil and cutter blades is braun series 3 combi 30B screen foil and cutter replacement pack.
Dec 23, 2012 | Braun Syncro 7570 Electric Shaver
Braun 7505 switch won't slide down to off position. battery has to run down to stop. What can I do?
Guest solution (2008) to Pry out the blue button worked great for me. Not sure what the semi-circular shapes under the button were for but the switch works fine now. The only down side was that prying the button off broke the tab holding it, but this is no big deal. Saved me the cost of a new razor and I like the Braun 7505 model because it works great and is smaller than some of the newer models.
Jul 11, 2010 | Braun Syncro 7505 Electric Shaver
Jun 29, 2010 | Braun 7000 Series Foil and Cutterblock
Braun 7570 shaver wont charge but wont run on mains lead
Mar 14, 2010 | Braun 7000 Series Foil and Cutterblock
My power cord has broken at the tip. Can I
Braun Syncro 7570 power cord is Braun 7030458 adapter charger cord.
Feb 08, 2010 | Braun Syncro 7570 Electric Shaver
My Braun 7570 has suddenly stopped working, but there is a high pitched whine when I switch it on.
This sounds like a battery problem. The likely remedy is to replace them. You will find batteries for your shaver at shaveroutlet.com
Jan 17, 2010 | Braun Syncro 7570 Electric Shaver
Looking for a service manual for the Braun 7570 syncro razer
It's actually easier than it looks. On the bottom of the shaver is the charging port. That black plastic piece surrounding it can be pried off. Do it carefully, so you don't dent/scratch the casing. Once removed, the side pieces easily remove. You'll now see screws holding the body together. Have at it. :-)
Jan 08, 2010 | Braun Syncro 7570 Electric Shaver
I need an instruction manual for the Speed xl 8175XL Phillips Norelco razor....any ideas?
http://www.amazon.com/Braun-Syncro-Shaver-Storage-7570/dp/B000050FDR
at the product details section of the page you will find the manual.
Dec 31, 2008 | Braun Syncro 7570 Electric Shaver
This button wears out or just fails with time, but is replaceable.
Braun 7526 Syncro Body Housing with Trimmer
$12.99, Fits Model: 7526, Type: 5493, Includes back case, front case with trimmer/switch, side grips and bottom 'plug', http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
Jul 07, 2008 | Braun Syncro 7526 Electric Shaver
Braun Syncro 7526 Electric Shaver Logo
115 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
