Question about GIMP GNU Image Manipulation Program
Pasted image becomes distorted in gimp?
I am trying to design header using layers but when i paste a jpeg into the new layer the image is not the same as the original. I have traied changing the image format to gif and gimp file but it just does not work!!
very frustrating
~Geoff
  • 5 Answers
SOURCE: cut image and transfer to transparent background using gimp
Hi Jody,
Gimp can be frustrating, but it's one of the most amazing and powerful free applications out there. You're right...what you're trying to do is very simple, but you need to know a few tricks to get it to work well.
First, you need to use .PNG as .JPG files don't support transparency. When you try to save a file in .JPG that has a transparency, or alpha, channel, you should be prompted to "export" the image by flattening all layers, which essentially replaces all the transparent areas with the current background color (usually white).
Second, there's a tool that's been added to the most recent versions of the Gimp that does exactly what you want to do. It's called the "Foreground Select Tool" and is really simple to use once you get the hang of it. This tool was added in Gimp 2.4, so you'll need at least that version or higher to use it. This tool uses a two-step process: first you draw a rough circle around the object you want to cut out (your daughter), then you "paint" over the foreground object so the tool can sample all the colors you're wanting to extract. This sounds strange until you do it...once you understand, it's really pretty simple. You can read the docs for this tool here. There's also a YouTube video that shows the basic process. Apparently no sound on that video, but at least you can see what to do.
Not sure what was happening when you tried to use the scissors. There are so many variables, it's hard to tell. You probably didn't need the extra step of adding a transparent layer...when you had your selection copied to the clipboard, you could have used "paste into" or "paste as new layer" or "paste as new image" to get what you want.
Let me know if this doesn't answser your question.
Eric Imboden
http://commoncontext.com
my take on tech : http://redsquiggly.com
Posted on Mar 18, 2009
SOURCE: Layered PSD file becomes QuickTime picture when import to DVDSP 4
This is ancient but there are probably people still out there looking for the answer. Try this...
1) First off, make sure the color mode of your PSD is RGB.
2) Rasterize all layers. DSP does not like text, masks, layer styles or anything of the sort.
3) Make sure there are no additional alpha masks or channels.
4) I think this is the one that gets people. It's awkward but it has fixed my problem in the past. Basically DSP needs the locked "Background" layer in your file to see it correctly. Maybe that's what it looks to for the file dimensions. I'm not really sure but it needs to be there. Just create a new file with the same dimensions and duplicate your layers into the new file. Save As... Done.
Hopefully this will help some get past this annoying problem.
Posted on Apr 05, 2009
jamielwright
  • 75 Answers
SOURCE: Is it the way to unlock layers in PSD file (Adobe Photoshop 7)?
Try the link.It may help.
http://kb2.adobe.com/cps/327/327827.html
Posted on Jun 01, 2009
  • 102366 Answers
SOURCE: Layer effects box gone.
From the menu select Window|Dockable Dialogs. From there, select Layers.
Posted on Feb 19, 2010
  • 25 Answers
SOURCE: I am simply trying select half an image and flip
How big is the file? Have you got plenty of hard disk space? If its a huge file, it could be simply struggling and it may solve it to shrink it down.... Or if you have stacks of layers, lose some/flatten/merge some and try again.
If not, sometimes there is glitches in running Gimp on a Mac.... It could be this is simply a bug...but I would have thought they'd ironed out the creases by now....
Might be best just to do the operation but slightly differently? For instance, copying the layer into a new document ... if it is a bug, a small variation in the process may avoid it.
Posted on Jan 16, 2011
Testimonial: "Thank you sir, good thinking as far as merging layers goes and also I think it helped to paste into a new document. "
How to import a word text into gimp ?
It is impossible to import a word document file into GIMP, but it is possible to COPY the text in the document and PASTE it onto a text layer in GIMP. This, unfortunately, destroys the formatting (for instant, tabbed spaces are removed for paragraph beginnings.)
Please contact me at div.ceslum@gmail.com if you have any other questions regarding text layers in GIMP.
Nov 12, 2012 | GIMP GNU Image Manipulation Program
I am creating collages using layers in GIMP. When I go to save it, I have to save it as an xcf file or else the images get distorted (tried saving it as jpeg but a pop up came up basically saying that I...
There are several image types that you can try to save it as. I would suggest trying bitmap but be sure to select the highest level of quality and lowest compression. This will result in a large file size however so it may become difficult to send in email or post on facebook. As far as file size goes JPG is your best option but it does not support transparency so you will have to either be sure to not have transparency or be ok with it being black when you save it. When you save as a JPG you need to again be sure to increase quality to the highest level and compression to the lowest.
Jul 22, 2011 | Computers & Internet
I am trying to create a poster for a fundraiser. I can get as far as creating the legal size of it, but then I do not know how to put the 4 pictures onto it and then move them around and resize them. I...
Howdy, here's my 4c worth.
After you have your legal size image ready then go to file > Open > the_file_you need.jpg
Gimp will open it in another window.
just hold CTRL down then press A while still holding CTRL to select All the image
then hold CTRL down then press C to Copy it
Go back to your blank page and hold CTRL down then press V to Paste it.
This step is weird but necessary, in the Layers panel it will have a new layer called "floating selection" or similar. just right click on it and select new layer...
the copied image will be pasted into the new one as a new layer (so you can edit it independently)
To resize it, look at the tools (on the left) panel and select the Scale tool (hover your mouse over each tool to see what it is called). once you have it selected then click anywhere on the image you wish to resize. then it will go into Scale mode where you can "grab" the corners with the mouse and stretch it to your liking. if you wish to keep the Aspect ratio (so it dosn't look stretched and warped) hold CTRL and SHIFT at the same time whist resizing.
And finally the Text!
Click on the A (text tool) in the tools panel.
Click and drag your mouse on the image to create a "text box" (the actual text you type is in a separate little box, but you can edit the color, font, size, etc.. later by clicking the A (text tool) and then clicking on the solid part of a text layer.)
Hope this rambling was of some use.
Mar 16, 2011 | GIMP GNU Image Manipulation Program
How do you do gimp zig zag
To create a zig zag pattern very quickly...
Select the top half of your layer, enter Quick Mask mode, and run Filters->Distorts->Ripple with the Smear, Vertical, and Sawtooth options (use the sliders to size your zigs and zags). Exit Quick Mask mode.
Here's an example result:
Feb 16, 2011 | GIMP GNU Image Manipulation Program
Hi, I can't drag and drop an image in gimp
You cannot drag and drop an image into another in the Gimp. Open Both images in Gimp then, Select > All on the image you want to copy and click Edit > Copy. Move the destination image and click Edit > paste and it will add it as a new layer. From there you can name the layer and anchor it.
Feb 09, 2011 | GIMP GNU Image Manipulation Program
I am simply trying select half an image and flip it so that I end up with a symmetrical image. However Gimp keeps closing itself out every time when I reach the point of pasting into a new layer the half...
Jan 16, 2011 | GIMP GNU Image Manipulation Program
I want to add a photo to a blog banner which was downloaded. How do I do that?
Open both files into Gimp.
In the window containing the photo file, select all(Ctrl-A), copy(Ctrl-C) then select the window containing the banner file and paste it in(Ctrl-V)
After this, create a new layer, and the photo should now become a solid layer You can move the layer around by clicking and dragging. Or by clicking and dragging the small rectangles at the corner of the frame, you can alter the size. The cursor should change slightly to indicate which setting you are on when clicking/dragging... (When moving, there should be a kind of cross with four arrows...and when enlarging, there should be a double headed arrow, indicating the direction you will be scaling the image)
Jan 12, 2011 | GIMP GNU Image Manipulation Program
Nov 13, 2009 | GIMP GNU Image Manipulation Program
Cut image and transfer to transparent background using gimp
Hi Jody,
Eric Imboden
Mar 10, 2009 | GIMP GNU Image Manipulation Program
Open Questions:
See all GIMP GNU Image Manipulation Program Questions
GIMP GNU Image Manipulation Program Logo
26 people viewed this question
Top GIMP Computers & Internet Experts
Rick Moore
Rick Moore
Michael Vincent Cruz
Are you a GIMP Computer and Internet Expert? Answer questions, earn points and help others
