Question about Honda Garden
What kind of oil do you put in petrol vacuum - Honda Garden
  • 561 Answers
If vacuum is a 2 stroke engine it is possible to buy ready mixed if you have a compartment extra for oil, then use regular engine oil.
Posted on Nov 16, 2009
Testimonial: "thanks for your help"
Peugeot RCZ 2010 petrol 1.6 l 115 kw 155 tho. Vacuum when I take the oil cap off when engine is running
NEVER remove the oil filler cap when the engine is running. It will upset the engine pressures and possibly cover you and the engine in oil splatters.
Petrol engines have a negative pressure by design.
May 28, 2017 | 2010 Peugeot RCZ 1.6
2-stroke or 4-stroke?
Well, if it has an oil drain plug and/or a fill plug for oil, It's a 4 stroke. If it has an odd shaped muffler/resonator, it's a 2 stroke.
Oct 14, 2014 | Garden
How do I mix two stroke engine fuel
Put oil in your petrol can add the exact amount of petrol put the cap on shake well use and store out of sunlight
Jul 17, 2014 | Trueshopping NEW 2 STROKE OIL FUEL PETROL...
For a yamaha outboard motor 2 stroke , how much oil would be added to 12 litres of fuel
50 litres petrol:1 litre Outboard TCW3 OIl
100litres petrol:1 litre Outboard TCW3
@ 50:1 You Would Put 240Mls Oil In 12 Litres Petrol
@ 100:1 You Woul Put 120Mls Oil In 12 Litres Petrol
Mar 12, 2013 | Boating
I have just bought a 1988 vespa px 125 under the seat there is 2 holes one for the petrol and one that says oil ive put 2 stroke oil in the oil tank and petrol in the petrol tank today i hit 50 and the...
older Vespas without separate Oil-tanks need a premix of 1:50 oil in the gasoline - but yours is an automatic oil-mixer type.
check the oil-level-glass under the seat near the choke.
it must be full of oil - the oil tank can hold about 1 liter of 2-stroke oil. How much oil did you fill in?
Probably the previous owner removed the oil supply tube and filled always an oil-gasoline premix. You better ask him about it. If the tube was removed then there was no oil supplied to your engine and it got stuck and the engine bearings are blown.
Apr 07, 2012 | 2011 Vespa GTS 125
What kind and how much oil should i put in the crank case of my 1975 suzuki ts 185 and would to thin oil cause it to lose compression?
ts 185 is a two stroke, the crank case oil is actually only the gearbox oil, the volumne is caste onto the side cover(like 750cc).near the filler cap.
The engine oil is mixed with the fuel and is pumped in from the oil tank under the seat.
The wrong oil or no oil in the tank under the seat can cause it to lose compression. and cause engine damage.
Visit a bike shop and get motorcycle gear oil20w50 for gearbox. and two stroke motorcycle engine oil for the oil tank.
As it is quite old someone may have removed the oil tank, thinking they will make it go faster or save weight or another stupid reason, if this is so you need to mix the two stroke oil with the petrol when you fill the tank at approx 25-1 ( 25 litres petrol mixed with 1 litre of oil)
Mar 21, 2011 | Suzuki TS 185 Motorcycles
What type of oil does the poulan pro BVM 200 EL use and is the gas:oil ratio 40:1?
use - husqvarna , sthil brands high quality 2 stroke oil
as directed on bottle 50:1 that is 20 mils of oil for every 1.0 litre of petrol that you use
if you want 2 litres mix put in 40 mils of oil into petrol container
then put in 2 litres of petrol only and give good shake and fill the blower
cheers
Sep 01, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have a Mercedes c200 petrol 1996 model the engine oil keeps doubling up .there is no sign of water in oil , the yellow oil light comes on on high speed ,what could be the problem
have you checked the trans fluid level? It could be trans fluid geting in through a vacuume hose. vacuume modulator on the trans may be bad.
Oct 19, 2009 | 1996 Mercedes-Benz C-Class
Garden Logo
56 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
