Question about Hitachi CP-S240 Multimedia Projector
My Hitachi LCD CP-S240 projector turns off EVERY 15 minutes. The lamp light turns red and the only way to turn the projector back on is to manually flip the power switch on the projector itself off and then on again. I let it rest for a moment, and then I can turn it back on with the remote. The reason I find this strange is that it is every 15 minutes while other teachers in the school have a similar problem but it is intermittent.
  • 21 Answers
Generally this is what happens when the lamp is on it's last leg or the projector itself is overheating. Being that you said you work in education, my solution for you will be slightly different than I might otherwise offer.
Your institution will have a department who's job it is to maintain this equipment. I know this because that's what I do. You need to put in a work order with the Information Technology department, or Educational Technology department, or Instructional Technology department, or whatever your support department is called. Every educational institution has something like this.
Explain the problem to them with as much detail as you can, and I am sure they will be able to resolve your problem.
Most likely, a simple lamp replacement and timer reset will fix this, but occasionally a fan will have to be replaced. Other times, this is indicative of something that will require a trained technician to repair.
Assuming you have a support area that handles this for your institution, please do not try to fix this yourself. As good as your intentions might be, the tech people at your workplace are the ones who need to handle this and often have to keep records regarding maintenance.
Posted on Apr 07, 2011
Flashing red light for lamp
There could be several causes for this. Does the cooling fan come on, it may be defective. There could be something blocking the heat sensor. Is it possible the connector didn't get fully attached when you installed the new lamp?
Apr 15, 2014 | Hitachi Gst CP-X2020 Hitachi Hitachi Xga...
I have a hitachi cp-251. powers up, no light. power led and lamp led are red
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Sep 17, 2013 | Hitachi Cpx2510 Projector Cpx2510 Xga...
When does the lamp kick in right when it start or when the lamp light comes on
This varies by manufacturer and projector model. Without knowing the make and model of your projector it's hard to give you an accurate answer.
Lamps in Hitachi data projectors tend to come on almost immediately after starting the machine. Lamps on the older InFocus projectors took a bit longer before you'd see light coming through the lens.
If there is a short delay between the time you start your projector and when you first see light, I would not be concerned. Data projectors have to cycle on the same way they cycle off, meaning it's a process and sometimes seems like it is running slowly.
Mar 12, 2010 | Hitachi CP-S240 Multimedia Projector
Hitachi cp-s240 remote question
Hitachi data projectors are able to function as a mouse using either the USB port or the control port located on the back of the projector.
However, they are not intended to be used as a remote presenter. This means that although you can use the remote as a mouse, you will not be able to change slides in a full screen slide show using powerpoint.
I recommend the Targus remote presenter for this purpose. This device will function as a mouse, pointing device, and will allow you to change slides in powerpoint. In addition, it's inexpensive, wireless, and small enough to easily fit in your pocket.
Mar 02, 2010 | Hitachi CP-S240 Multimedia Projector
My Hitachi cp x250 projector powers on and displays and then the bulb turns off after a few minutes, and the lamp light and the power light come on red.
Most likely you have a defective lamp or it is near the end of its life. It's also possible that the high voltage power supply is going out. You might check the lamp hours - you can find this in the advanced menu. Also check the air filter, if you haven't cleaned it, the airflow might be restricted, shutting down the projector.
Sep 18, 2009 | Hitachi CP-X250 Multimedia Projector
Hitachi cp-s240 blue tint cloud problem
This might sound like a worn spot in the (blue) lens from heat, or a bad color driver on the mother board. It could possibly be dirt or condensation behine the lens(s)
Jun 19, 2009 | Hitachi CP-S240 Multimedia Projector
Hitachi CP-X960 Shutting Down
Hi Jason
This is normally a faulty Ballast ( lamp's powersupply )
It will need replacement unfortunatelly
Apr 02, 2008 | Hitachi CP-X960 Multimedia Projector
Hitachi CP-S240 Multimedia Projector Logo
288 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
