Question about Acer Pentium II , 266 MHz (91.AB009.001)
Charging problem ; charger is ok but it seems like there is a problem with the actual internal charging device.
  • 2,567 Answers
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Posted on Nov 16, 2009
How do I charge?
you are following correct and logical steps to charge your device. If it won't charge, there are two possibilities:
Your chager is defective: you can detect charger's output using an electronic tester. If you don't have one, should check it with some electronic repair service
If charger is ok, then your battery is dead. Most similar devices have so called "lifetime" rechargable batteries - means, you can't take apart your device to change the battery.
I have no idea if your device is or not servicable so just to be sure you won't throw away a rapairable device, check it at some electonic service site.
Do you have a manual? This one I found actually doesn't tall much about this device
http://headsetplus.com/PDF/SP5050-QS.pdf
But this one is better.
Jabra SP5050 Manual
Aug 23, 2015 | Jabra Sp5050 Bluetooth Speaker Car Kit Rim...
Will not turn on dead as a Dodo, plugged into car 12v supply OK.
after a time without use dechargeable batteries seem not to charge for some reason, apparently this is so on certain rechargeable types more than others.
Check the charger if that is ok replace the batteries...should work ok hopefully
Jul 04, 2015 | Navman Mio M400 Car GPS Receiver
The green light will on to charge but with seconds turn red and not charging
this could be due to a too high or too low voltage from the charging unit. if the device notices that the voltage is not correct it will not charge. ensure the charger is ok try using to charge another device such as a mobile phone and see if the same problem appears if so you need a new charger. if not then the device is faulty and needs repair or a new internal battery.
i hope this was helpful.
May 21, 2015 | Tablets & eReaders
My device is three months old. The charger is giving current as I am able to use it while plugged in, but will not charge at all. The device works beautifully in every other way accept for the charging...
Seems like internal battery charge controller has got fault or internal battery is not accepting charge. If it is under warranty then take it to the servicing centre.
Mar 20, 2015 | Bose SoundLink Color Bluetooth Speaker...
Guys Im using Sony walkman nwze463 The device is not getting charged as I used original charger as well as used a newly purchased one It is not turning up when I plugged directly to switchboard or to...
Data cables are different from charger cables. Charge only cables will never pass data and vice versa. Check the style of cable you are using to charge your device. The connector on the device may have lost a good connection inside the device or the connector solder joints internally may need to be re flowed.
Jul 28, 2017 | Audio Players & Recorders
Manual for ilive bluetooth receiver and adapter lAB13
Have you actually checked the charger is actually working with power coming out of plug that plugs into device.. THe actual charger unit may not be connecting properly into wall socket...
Dec 09, 2013 | GPS
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Mar 13, 2017 | Ainol 10" Novo 10 Hero 16GB Dual Core IPS...
Tomtom problem
When you turn off the device with power button, you actually set the device in stand by mode, not fully turned off.
This state will drain the battery.
The only way I know to turn device fully off, is to do a reset with paperclip at bottom of device...
Mar 05, 2009 | Tomtom One Europe v2 GPS Receiver
Aspire one no statring at all
if new, return it to place of purchase for a replacement. if used, the motherboard or internal problems may be the problem such as a bad motherboard, bad internal connection etc.
it may also be that the battery isn't being charged due to a bad adapter or battery. the battery may not be able to take a charge, or the charger may not actually be charging. if you have a spare charger, try it, and the same for the battery.
a green light on the charger doesn't mean it's actually doing anything. nor does it really indicate the battery is good.
Nov 27, 2008 | Acer Aspire M1641-U1521A PC Desktop
Battery
There is no rechargeable internal battery, AA only.
Nov 21, 2007 | Garmin StreetPilot i3 GPS Receiver
Acer Pentium II , 266 MHz (91.AB009.001) Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
