Question about Cell Phones
I want to send a MMS using only the keyboard (as my touch screen is broken) but I'm unable to move from "to" section to the "send" section in order to actually send my MMS. I've tried the tab button and this doesn't make the cursor move. Any ideas?
Cant recieve or send out mms
Here are the APN settings for your phone and T-Mobile.
These need to be correct for mms to work.
APN & data settings
To set the Access Point Name (APN) and turn on data settings, follow these steps:
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Wireless & networks.
  4. Open the Access Point Names or APNs. menu (in steps above)
  5. If there is a T-Mobile APN, touch it. If not, press the Menu key, and touch New APN.
  6. Verify and update the following settings for the Data APN:
    • Name: T-Mobile
    • APN: epc.tmobile.com or fast.t-mobile.com (for LTE devices)
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: <Not Set> OR Internet+MMS (depending on software version)
  7. Press the Menu key.
  8. Touch Save.
  9. In the list of APNs, delete all others that may appear. If there is a FOTA APN, you may leave that one. To do this:
    1. Touch the APN you want to delete.
    2. Press the Menu key.
    3. Touch Delete APN.
  10. Verify that there is a circle next to the one remaining APN to show it is activated.
  11. Perform a soft reset.
  12. Test your data connection, by accessing a web page or sending a picture message (MMS) to yourself.
Sep 15, 2014 | ZTE Concord Blue Smartphone - T-Mobile 832...
Hi i have corby mobile and unable to send mms
you need to contact your mobile network operator to activate the MMS feature for your mobile number and then you have to get settings from network operator and save it to your mobile phone. After that your should be able to send and receive MMS.
I hope this is helpful to you.
Thanks
May 22, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
How to activate & send mms in samsung s8000 mobile
you need to configure the mms settings from your internet menu... but you need the right configuration from your network provider to the settings..
to give you an idea, here's how you may do it.. from your phone, press menu select internet select browser profiles to lead you to internet profile settings.. from your settings, press create.  then create the mms profile your network preferred.  once created, press save and exit the settings for internet profiles..
to make the mms profiles be the default settings for your mms, do thes steps... from your phone, press menu select settings select phone applications select messages select multimedia from multimedia menu, select profiles assign the mms profiles you created for your multimedia. press save and exit the setup...
now to check if it's working, try sending a multimedia message to your own number to check if your phone can send and receive mms. once you successfully send it and received it, it means that your phone mms is already set and working...
take care..
Mar 30, 2010 | Samsung Jet S8000 Cell Phone
Unable to get MMS messaging to function
Yeah thats true before using the service you need to configure it manually or automatic, depends on the service provider, Some provider gives the option to download the MMS settings from Web Site, you just need to select the brand, model number and the phone number to send the settings.
For Example: If you need and settings for SONY mobile just go to the web site and follow the steps to download it.
If it comes to manually you need to call the customer care service provider to get the details like IP address, port or APN (if any).
For more details you can get back to me at <katwal.raman@gmail.com>
Regards,
Raman
Sep 07, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Unable to send and recieve picture messages
hi
firstly contact your operator and request for sending you the mms activation settings once you receive them as a message save them on the phone now you are ready to send and receive MMS messages
now to the part of sending an MMS
go to messages click on the
  • menu then New then MMS
  • now key in the addresse in the TO part and in the msg body
  • go to select insert Picture/ Video to insert a picture or video from your gallery
  • similarly if you want to add text select the text
  • also the same for audio
you can select all or any of the picture/ text/ audio and send as an MMS
hope this helped
cheers
PS: if this has been of any help pls rate the solution
Jun 25, 2009 | HTC Touch Cellular Phone
For My p168c phone says message too large when trying to download
are you sure you set upyour MMS correctly? below is the steps to verify. These phones only allow 100kb download of MMS, but if you saying you cant get any MMS at all here is the proper steps for T MOBILE. Must be Followed Exactly.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope.
MMS Messaging:
1.) From the main screen tap the SMS Text icon.
2.) Tap MMS on the Messages menu.
3.) Tap MMS settings on the MMS menu.
4.) Tap Server profile on the MMS settings menu.
5.) Tap either SIM1 or SIM2 on the MMS settings menu, whichever SIM you are setting up
at this time for MMS messaging.
6.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but
profile 8 is usually the first not already filled.
7.) Tap on Profile 8. Tap Edit profile.
8.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen.
9.) Clear the current text, then tap in the following text between the quotes
“T-Mo MMS”
Tap the Options button at the bottom of the screen.
Tap the Done button.
10.) Tap the area below Homepage, then tap on the Edit button at the
11.) Clear the current text except for “HTTP://”, then tap in the
following text between the quotes after the HTTP://
“216.155.174.84/servlets/mms”
12.) Tap the area below Data account, then tap Select at the bottom of
the screen.
13.) Tap GPRS on the Data account menu.
14.) Scroll down the list until you come to T-Mo MMS, the data account
set up under the Data Account Services section. Tap on T-Mo MMS
to select it.
15.) Tap the area below Connection type, then tap Select at the bottom of
the screen.
16.) Tap on HTTP, then tap on OK at the bottom of the screen.
17.) Tap the area below Proxy address, use the numeric keyboard at the
bottom of the screen to tap in the following numbers,
“216155165050”. The result should look like 216.155.165.050 under
Proxy address.
18.) Tap the area below Proxy port, use the numeric
keyboard again to tap in the following numbers
“8080” to replace the current 0 value. Then tap OK.
19.) The areas under both User name & Password should
remain BLANK. If they are not blank, select each,
and Edit them by clearing all text.
20.) Next tap the Done button at the bottom of the screen.
21.) A Save? question box should pop up. Tap the Yes
22.) Tap the Activate profile button on the T-Mo MMS menu screen, and you should be
taken back to the Select profile screen where a big green check mark will be beside the
newly saved T-Mo MMS profile.
Apr 29, 2009 | Dual Electronics CECT P168 Cellular Phone
How to set up my mms on my CECT p168+
MMS Messaging:
“T-Mo MMS”
the screen.
to select it.
the screen.
Proxy address.
For full help topics I have a cd available fo 10 us dollars. Has 100's of mp3 ringtones wallpapers, and java games. Guarenteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope.
Apr 24, 2009 | Dual Electronics CECT P168 Cellular Phone
Sending Message Problem!!
touch the START menu on the top left of your screen, touch on MESSAGING, select SMS/MMS account by touching, that will take you to your inbox. then just touch the MENU on bottom right of screen and select NEW... then touch SMS. It will ask you to add contact 1st. then touch screen where text goes till curser appears then type either by keyboard buttons or middle bottom of screen if you touch a electronic version of keyboard will appear you can use stylis to type on screen keyboard. Then bottom left of screen hit SEND. message sent message will come on screen when msg sent.... Goodluck
Apr 10, 2009 | Sony Ericsson XPERIA X1 Smartphone
I am unable to send mms messages
hi this is easy to solve either call your service provider and they will send you the settings via a txt message witch will update your phone or the other way i did it was by going onto my service providers homepage and navigate through the site untill you find the section with the settings you should then be able to send the settings to your phone that way either way should work let me know if your still stuck after doing this
Jan 11, 2008 | Cell Phones
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
