Question about Homelite 'Yard Broom' Leaf Blower
Starter rope broke. how do i get the cover on the
Starter rope broke. how do i get the cover on the left side off? i took the large screw out but still could not remove the cover. i dont see any more screws or catches.
  • 169 Answers
Once u split case open you have to remove the engine from the frame to get to the starter. Its somtimes a bear to get back together due to warpage in the case halves. Hope this helps
Posted on Nov 20, 2009
How do you fix a Massport bio whizz mulcher starter rope that's free-spinning?
try tapping with a rubber mallet on top cover of PLastic wheel housing there is a clutch inside there that allows for free wheel after starting , sometimes these clutches get stuck dissengauged till you shock(mechanical) em back to engauge
also hairspray applied to pull rope (pulled out) help to prolong these for some time , my girlfriend showed me that one sometime back
Jul 29, 2014 | Masport MHG-4 - 4-Way Home Gardener 17"...
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    Rope broke
    Starter rope is sold at home centers like Lowes and Homedepot. It is important to buy the same thickness of rope so that an ample amount will fit into rewind spool(starter rope is sold by size from 3.5 to 6.5) . Remove the starter cover /fan cover if the starter is riveted to fan cover (or just remove the pull rewind if bolted on). With cover removed, notice how the rope enters thru bushing and ties onto spool. Visualize in which direction the spool turns when you pull the rope. This is the direction that you will be winding the spool. Fish out the old rope and wind the spool in the direction mentioned above. The spool will get tighter as you wind. When the spool will not wind another turn, back-off one turn and align hole in spool to bushing on cover. Insert rope thru bushing into hole and tie knot (any knot that will not obstruct motor parts). At this point allow the rewind to take-in the rope to stop at handle. Test your work. The rope will break if you try to start the washer under load. Press trigger on wand to release pressure. Also the rope is stressed when the operator has a very long strong arm and pulls out the rope to bottom out at the knot. Good luck with your repair
    Aug 04, 2011 | Briggs & Stratton 3000 PSI Pressure Washer
    Need to replace starter cord on Tecumseh LV195EA engine for walk behind lawn mower
    This is an easy one. You need a #2 phillips screwdriver, a 1/4" nutdriver or socket, a 5/16" nutdriver or socket, 84" of #4.5 braided nylon rope, scissors and a lighter or flame of some kind.
    1. With the #2 phillips screwdriver, remove the 2 screws that hold the green plastic cover to the top of the engine. This is just a decorative cover.
    2. With the 5/16 nutdriver, remove the 3 screws in the top of the fuel tank. Lift the tank straight up about 3/4" and then just lay it back on the rear of the mower deck.
    3. The round black object on top of the motor is the starter houseing. You will find it being held on with 2 screws from the side. The 1/4 nutdriver should fit these. Remove them, and note the position of each screw and the position of the starter top. It might help to put some colored tape on the starter top and on the upper engine shroud to make sure you put it back in the same position. The starter top will come off by lifting it straight up.
    4. Remove what is left of the old rope.
    5. carefully wind the inner pulley (the same direction the rope will pull it) until it is tight. Then let it rotate back a little until the rope hole in the pulley lines up with the rope hole in the starter top. Use your screwdriver to hold these in place by putting it through the pulley and starter top vent holes.
    6. Measure your rope out to 84inches and then cut it. Take the lighter and melt the ends of the rope to keep them from ravelling. When you melt the ends, take a paper towel or a rag and wipe the ends to form a point. This will make reinstall easier.
    7. Push the rope throught the eyelet of the starter top and through the hole in the pulley and tie a figure 8 knot on the inside of the pulley. Tie the starter handle on the other end. but do not tighten this knot, you may have to untie it to lace it back through to where it goes.
    8.. Hold tension on the rope and remove the screwdriver. The rope should retract into the starter top.
    9.Reinstall everything in reverse order.
    Nov 01, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
    The pull string broke how. how do i put the new one on?
    Go to a hardware store and ask them if they have ant bulk pull starter rope. Buy about 3 feet or so of the small stuff (it is only 30 or 40 cents a foot, cheaper that the kits) Remove the motor cover with the pull start and turn it so you can see the wheel inside. Remove the knot that held the old rope in the handle and then cut the knot on the starter wheel and pull out the tag left in there.
    Now the fun part. The wheel is spring loaded and the spring has no tension on it after the rope broke. Wind it up like a clock spring until it is tight then back off until the holes where the cord goes line up. Stick a small screw driver, nail, ect in the slot to keep it from unwinding . Do not tie the handle to the cord yet. Slide the new cord through the hole in the cover and wheel and then tie a knot in the cord and pull it snug in the wheel. Hold the rope and remove the pin and let the cord slowly wind itself up. Run the cord through the hole in the handle, Adjust to the length of pull you want and tie another knot.
    Reinstall the motor cover (if it binds and wont go on, pull the rope just a little bit to line up the crank with starter wheel and it will slide down.)
    It sounds a bit windy but it really is a simple fix.
    Jun 09, 2010 | Troy Bilt Tiller/Edger 26cc, Model No....
    The starter rope on my B&S 375 engine snapped. Is it easy to replace? I took the cover off from around the starter and it seems to be popped riveted onto the top of the engine. Many thanks
    The pop rivets are irrelevant. if you look in the center of the nylon retract pulley inside, you'll see the screw that holds it all together. Take that screw out, and the pawl system will come out(make sure you remember how they came apart), then you can pull your retractor out, take the old rope out, put the retractor back in, wind it up all the way, then you can run the new rope in and tie the knot. Then let it draw the new rope in, put everything back together, and if you let it draw it in and had rope left over, pull it out about 4 inches before you put the handle on. Don't let go of the rope at this point, or you'l have to take it apart again. After this, make sure everything's back together the right way, and put the cover back on.
    Mar 11, 2010 | Garden
    How do i essemble a pull starter on a troy built snow thrower
    to just put the rope in take starter cover off look inside the cover and turn thr pully to the left counter clock wise turn till it turns no more line up the two hole one from the pully and one on the starter cover where the rope was originaly put the rope in thr hole and tie a knot this is called preload has to have tention on thr pully to pull the string back but if thr spring is broke its another process
    Frazier
    Nov 01, 2009 | Troy Bilt 5.5hp Self Propelled Mower
    Starter rope pulled out and wont retract on craftsman trimmer/edger 32cc convertible incredi-pull
    remove the starter cover and try to wind the starter rope manuly. the rope may have to be replaced if worn or broke..
    Oct 22, 2009 | Craftsman Garden
    The starter rope on my 14PZ push mower broke. How
    The starter rope on my Masport push mower broke. How do I replace the rope and/or starter?
    Sep 27, 2009 | Garden
    Handle came off starter rope and rope rewound on spool. Took off power boom and took out tork screws and loosened cover from engine, but there is a metal disc, looks like a clutch cover on the end of the...
    You shouldn't have to remove it. Just wide the disk up again to get tension on the recoil spring (lots of tension... enough to pull the rope all the way back in). poke the rope back out the hole ( the hardest part of the job) and put the handle back on. You should be back in action
    Aug 20, 2009 | Ryobi Garden
    Homelite 'Yard Broom' Leaf Blower Logo
    Top Homelite Garden Experts
    Jim Parker
    Jim Parker
    roeb
    Mike Squire
    Are you a Homelite Garden Expert? Answer questions, earn points and help others
