Question about Ricoh Aficio 1035 Copier
TRYING TO MAKE OLD COPIER WORK
I RECENTLY ACCUIRED THIS PROBLEM WHEN I SWAPPED JOBS AND THERE IS NO MANUEL. IT HAS A LITTLE TRIANGLE OF GREEN DOTS ON THE TOP - WHAT DOES THIS MEAN. IT IS NOT PRINTING & I AM TRYING TO FIX IT. PPPLEASE HELP! THANK YOU!
Error code 452
Posted on Mar 04, 2009
  • 4 Answers
That LITTLE TRIANGLE OF GREEN DOTS means your toner is empty try to replace it while it is not blinking
Posted on Mar 01, 2008
  • 589 Answers
That means it needs toner.
Posted on Jan 09, 2008
We no longer have our manual. The Little man is lit up and also the dotted circles to the right of the triangle. What does it mean?
the little man means time for service, that is replace the drum and toner developer units,
the maint. man has to be reset by aservice tech, you might try the sharp support site for the reset instructions .
good luck ,tinyman
Jul 19, 2011 | Sharp AR-153E Copier
I have a problem when u use copier. there are red icon in triangle. how to fix that.. .plz help me.
Normally the symbols indicated require attention some times a triangle with little dots in the triangle need to have the waste toner emptied from machine hope this helps you it depends what is being shown in the triangle a zig zag with may be two circles in the triangle would be like jammed paper needs to be removed
Feb 25, 2011 | Sharp AR-M205 Copier
What does the dotted triangle mean?
On most sharp copiers the dotted triangle that points up is Toner and if it has a triangle that points down that is Waste Bottle
May 13, 2010 | Sharp AL-1457 Black and White Copier
My Sharp AL 1000 has quit copying!
The triangle or stack of 6 dots is the toner cartridge light. The drum light looks like a cylinder or aa battery.
If you open the right side door, then the front door you will see the 2 cartridges. The toner cartridge is on the left and should have a large green button you push down on to release and slide out. Later or when needed you can slide out the drum cartridge AFTER you remove the toner.
You might have a local source to get your toner cartridge refilled. Or just order a new one and unpack it, then slide it in and your all set.
About $50 for refill or about $100 for new.
Good Luck
Nov 25, 2009 | Sharp AL-1000 Copier
No manuel. Triangle lights on - will not copy/
triangle light (Looks like billiard balls) means that you have run out of toner.
Oct 25, 2009 | Sharp AL 1631 Copier
Vertical dots down center of paper HP 1320 printer
If the pattern repeats down the feed path of the paper, then a roller is causing it. The toner cartridge replaces the transfer drum, the fuser roller remains in the printer. Since your old cartridge does not show this problem the fuser roller sounds to be fine. Return the recently purchased toner for a replacment, you should be fine. If not then a proper cleaning by a certified technician would be in order.
Aug 26, 2009 | HP LaserJet 1320 Printer
The exclamation sign flashes and then the green light but no printing
The service Manual says that if both the ready (Bulb) light and the exclamation light are both on it is a invalid engine
code /Invalid network code. But to clarify that you say they are both on and solid and not blinking. If they are you have a bad main board.
If they are blinking then the error is a Flushing /Resolution reduced error.
The cause is:
Printer is processing data or printing pages,but the resolution of a page in the current print job is reduced from 600 dots per inch (dpi) to 300 dpi to prevent a memory full error.
Solution is:
Wait until the ready light is displayed to print other jobs.
• Press and release the triangle button to cancel print job. It is the lower of the two buttons.
• Press and hold the traiangle button again to reset printer.
Hope this helps
Bruce
Jul 14, 2009 | Lexmark E232 Laser Printer
Hp desktop 1320 printer has yellow light on - it the icon symbol
The symbol for toner low is a box, without a top, with an arrow made of dots pointing up. Insert an new print cartriage.
Nov 12, 2008 | HP LaserJet 1320 Printer
L lost my manuel
Hi Kennedyc50,
Please visit the Hp website using this link:
http://h10010.www1.hp.com/wwpc/us/en/sm/WF06a/18972-236251-236268-15077-f58-375773.html
And on the R.H.S you will find the PDF and 3D product demo.
Hope it will resolve your problem
Regards
ELLIN
Sep 18, 2008 | HP LaserJet 4650 Color Printer Manual...
Ricoh Aficio 1035 Copier Logo
82 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
