Question about Nokia 3650
I have a optus 3g sim i need the wap settings for
How do i unlock my nokia network from 3G to optus in australia
To Unlock Nokia E63 from 3 Network AUSTRALIA,Use Unlock code...Visit the site Prounlocking.com/nokia/rs8wp8/ get code and Unlock it..Then use with Optus network sim card.
Sep 18, 2012 | Nokia E63 Cell Phone
What sim card do i need to use i have the latest sciphone form hongkong and i cant use my 3g sim card from optus and the guy at the shop couldnt help me so what sim do i need to use living in australia...
Go to this website www.i9forum.co.uk register and check the forum out for a solution, I've had a quick look but its mainly about mms & gprs. If this is what your after the settings the instructions are there on how to set it up.
I'm with Telstra 3g and have the new sciphone i9 3gs and it works great.
Apr 18, 2010 | Dual Electronics CECT P168 Cellular Phone
Hi i have a ka08, i just need to configure the wap and mms using my optus sim, optus couldnt help so could you?
First : they are the only ones supposed to provide the best help for your problem , so try to call them again .
or search their web site .
good luck .
Feb 08, 2010 | Dual Electronics CECT P168 Cellular Phone
Bring an HTC P3450 unlocked phone to overseas. doesnt work
Is Optus an 3G network? Some USIM cards doesn't work with non 3G devices.
Jul 25, 2009 | Cell Phones
I HAVE A CLARO ACCOUNT BUT CANNOT GET INTERNET
I found these internet settings for Claro from another website:
http://forum.itechinnovations.com/index.php?tid=101
Claro's Internet Settings are:
WEB CLARO & Java Claro
homepage: http://internet2g.claropr.com
APN: internet.claropr.com
Port: 8080
username:
password:
authentication: none
Primary DNS: 0.0.0.0
Secondary DNS: 0.0.0.0
IP address:
WAP CLARO
HOME: http://wap2g.claropr.com
PROXY: 10.50.38.3
Port: 8799
APN:wap.claropr.com
MMS CLARO
Homepage: http://mmsg.claropr.com:1021/mmsc
APN: mms.claropr.com
PROXY: 10.50.38.3
Port: 8799
username:
password:
IP address:
This is how you set it up on your phone. Just substitute the settings provided with the ones above:
From: http://www.tomshardware.com/forum/49719-36-a008-ming-xing
The setup of WAP and MMS on your DUALSIM Mobile Phone is carried out in 4 stages.
• MMS Data Account Setup
• MMS Setup
• WAP Data Account Setup
• WAP Setup
Step 1 – MMS Data Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS > Select an empty Account”
2. Edit the following parameters in the account
a. Account Name = OptusMMSGPRS
b. APN = mms
c. User name = [blank]
d. Password = [blank]
e. Auth. Type = Normal
3. Exit back to MAIN SCREEN.
Step 2 – MMS Setup
1. Go to the following menu “MENU > MESSAGES > MMS > MMSSETTINGS > SERVER PROFILE > SIM 1 or 2 > Select an emptyAccount”
2. EDIT the following parameters in the account
a. Rename Profile = Optus MMS
b. Homepage = http://mmsc.optus.com.au:8002
c. Data Account = OptusMMSGPRS
d. Connection Type = WAP
Proxy Address = 061.088.190.010
e. User Name = [blank]
f. Password = [blank]
3. BACK then ACTIVATE PROFILE and exit back to the MAIN SCREEN.
4. Your Phone is ready to access WAP and MMS services.
Step 3 – WAP Data Account Setup
a. Account Name = OptusWAPGPRS
b. APN = prepaidyesoptus
Step 4 – WAP Setup
1. Go to the following menu “MENU > SERVICES > WAP >SETTINGS > EDIT PROFILE > SIM 1 or 2 > Select an empty PROFILE> EDIT PROFILE”
a. Rename Profile = Optus WAP
b. Homepage = http://networker.optus.net.au/wap/index.wml
c. Data Account = OptusWAPGPRS
Proxy Address = 202.139.083.152
Hope this helps!
WizardRepair
Jul 17, 2009 | Cell Phones
Need wap/mms settings for optus (aus) for cect i9 phone
If you have a I9 you must go to this site. very helpful every question you have has been asked at this site. Regestration is free.
http://www.i9forum.co.uk/
Most setups are listed directly on this site. I took this qute from someone asking the same question.
I didnt see the thread they were ytalking bout, but they are suggesting stting it up like the Nokia 2610. I would recommend posting this question again on the above site. Below is what I copied from there.
Hi I'm in Sydney and use Optus mms and wap with no problems. If you look in this thread under the topic Easy configure MMS. Follow the instructions to the Nokia site for the 2610 and you should get a text back to set up MMS and the internet. Good luck It worked fine for me.
Apr 09, 2009 | Dual Electronics CECT P168 Cellular Phone
Wondering how to access optus 3G off a telstra phone
hey i have fixed this problem on my phone (htc touch hd, telstra) and this is how i did it- go settings, connections, go advanced tab down bottom, click select networks, click new on the top bar under programs that auto..... enter in OptusInternet (exactly like this).... then click modem tab down bottom then click new..... enter in OptusInternet again and chance cellular line bar to cellular line (GPRS, 3G)... then click next and for access point name type in internet.............. click ok ok x and then load up internet explorer and it should work
However the current problem i am still facing is opera wont run..... explorer will but opera doesnt load. just sits there untill it comes up with error 104 blah blah blah- still working out how to fix this as i hate internet explorer and opera is way better (going to try downloading opera 9.5 beta again and see if that works)
Mar 25, 2009 | HTC Touch HD Smartphone
G3 via G2
I've setup Nokia phones with 2G SIM's and I've had it running under GSM frequencies using a Optus 2G GSM SIM card; works fine. I've also put 3G SIM's in 2G Unlocked Phones and haven't had any issues before.
Have you tried putting in a 3G SIM and had problems?
Is your phone locked or unlocked?
Be careful of the terminology, some people get "3G" mixed up with the company "3" which is owned by Hutchison.
For example, if the phone is locked to 3, and you try and put an Optus/Voda/Telstra/AT&T SIM inside it will not work.
If it's just a Generic Branded 3G phone you should be fine.
Make sure your phone is unlocked, then purchase a SIM online or back at the AT&T store.
You should be able to take your phone back to the "stupid people" at the AT&T store and have them register a 3G SIM and you shouldn't have any problems; just tell them it's a unlocked phone.
Here are some helpful links:
http://www.planetomni.com/FAQ_sim.shtml
Mar 08, 2009 | Dual Electronics N99i Cellular Phone
Needing mms and wap settings
Go to this site and set up WAP and MMS. Worked for my KE970 and Optus
http://www.moto-zone.com.au/dealermoto/wap.html
Jul 23, 2007 | LG Shine KE970 Cellular Phone
Nokia 3650 Logo
116 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
