Question about Allied Telesyn AT FS708 Networking Switch
My provider ZIGGO.NL supplied recently a new Motorola modem for faster internet. However my AT-FS708 does not posetively react on it, that is to say it offers no transmitting service. What can I do about this?
  • 19,396 Answers
Hi.
If you are using a motorola modem, there should be no problem in accessing the Wan from AT-FS708.
Modem usually does not have bult in firewall.
If instead, as I think you have been given a new router, then you need to open a port for the AT-FS708 on the router.
A way to proceed would be accessing settings on the older router and check what ports where open, then set the new Motorola to open the same ports.
Posted on Nov 16, 2009
How do i turn wifi off
Locate the Wireless LAN switch located on the front of your computer.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on or off whichever you need.
Move the switch to the right to turn on Wireless connections.
Right-click the network icon located on the system tray next to the clock.
You should see a list of available wireless networks.
Select the network you want to connect to and click "Dis Connect."
Motorola Surfboard Cable Modem User Guide
The user guide for your Motorola Surfboard cable modem can mean the difference between knowing how to locate and diagnose problems with your connection or staring angrily into a maze of blinking lights.
The user guide provides information on properly setting up your cable modem, understanding the indicator lights and troubleshooting problems before you have to call your Internet Service Provider.Connecting Your Modem
Your Motorola Surfboard cable modem must be connected to your home's coaxial cable connection.
Connect the coaxial cable from your cable outlet into the "Input" jack on your cable modem.
If your modem is wireless, it will connect to any computers and wireless devices in your home through the wireless signal sent from the modem.
Wired Internet connections require that you use an Ethernet cable to connect your cable modem to any supported computers and devices.
Understanding the Front Panel
The front panel of your modem is your key to understanding the status of your cable modem.
The front panel features "Power," "Send," "Receive," "Online" and "Link" lights, each of which displays information about your modem.
The "Power" button will display a solid green light when operating normally and will turn off when there is a problem with the power supply.
The "Send" and "Receive" lights will transmit a solid green or blue color when data is being normally transmitted through your modem and will blink when it the modem is scanning for an upstream or downstream connection.
A solid green "Online" light indicates that you are connected to your Internet Service Provider, while no light indicates that the Internet connection in your home is experiencing problems.
A yellow "Link" light indicates that a computer is connected to your modem with an Ethernet connection while a blue light indicates that a high-speed Ethernet connection is being utilized through the modem.
Configuring TCP/IP
The Transmission Control Protocol/Internet Protocol provides the basic foundation for establishing a local network and a connection to the Internet. The TCP/IP can be configured in the "Control Panel" of your Windows computer. Open the "Network and Sharing Center" from the control panel and double-click the "Manage network connections" option. Right-click the network connection displayed and select "Properties," then select Internet Protocol Version 4 and open the TCP/IP properties menu. Select "Obtain an IP address automatically" and "Obtain DNS Server address automatically" from the TCP/IP properties menu and click "Ok" to save your TCP/IP settings.
Troubleshooting
Many technical issues with your cable modem can be resolved by power cycling your modem and the computers and devices connected to it.
To power cycle your modem, unplug it from the power supply for 10 to 15 seconds and reconnect it to the power supply.
Restart all of your connected computers and devices while your modem is power cycling. Problems with the "Send" and "Receive" functions can be the result of a poor signal being sent to your cable modem. Tighten the coaxial cable connection to your modem and contact your internet service provider if problems persist.
http://www.motorola.com/staticfiles/Consumers/Products/Cable Modems and Gateways/SURFboard Cable Modem-SB6120/_Documents/Static Files/557621-001_SB6120_User Guide-US-EN.pdf
Nov 19, 2013 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
WL330 achter een cisco modem als repeater
dat heb ik ook mee geworsteld. kan alleen als je de beide beveiliging op wep open heb staan,dus geen wpa. dus wep open, een SSId naam,mac adrees invullen van de repeater in bij de modem en andersom,zelfde kanaal hanteren en zelfde wachtwoord . het is echter zo gebeurt als je weet wat je doet.
Nov 28, 2012 | Computers & Internet
Will this work with Comcast broadband and Windows 7?
This modem will work with Comcast High Speed Internet.
You will have to contact Motorola for drivers for the Windows 7.
It does matter how fast your internet speed is,anything faster than 20meg,will need a Docsis 3.0 modem.
Jan 13, 2011 | Arris SURFboard SB5101U DOCSIS 2.0 Cable...
How to set up password
insert the disc supplied by your ISP internet service provider then enter the the user name and password you provided to your intenet service provider ISP then just follow the prompts
hope this helps
Dec 22, 2010 | Arris Surfboard SBG900 Modem Cable Modem...
I wanted to know what is the best wireless router compatible with motorolla SBV5120 cable modem? thank you very much
The Motorola SB5120 SURFboard® is a very popular, solid and reliable cable modem compatible with most cable providers. If your modem is two years or older, upgrading to the SB5120 has been known to show speed improvements up to 3X faster than older DOCSIS 1.0 modems. Set up is simple and fast.
  • Compact design: With its attractive and compact design, this cable modem won't clutter up your work space
  • Easy to maintain: Simplify troubleshooting with the handy font-panel LEDs and built-in HTML-based diagnostics
  • Stand-by switch: Disconnect the signal without unplugging the modem with the top-mounted stand-by switch
  • DOCSIS™ 2.0: Take advantage of DOCSIS 2.0 technology for up to three times greater upstream capabilities than older modems running on DOCSIS 1.1
Linksys BEFCMU10
Quick to set up at a great price, the Linksys BEFCMU10 offers fast connections to your cable broadband provider. Connect it directly to any PC with an available USB or Ethernet port, and you're ready to surf the Internet. With the Linksys Cable Modem, you'll avoid monthly rent charges, and make the most of your high-speed cable Internet connection.
  • Compliant with all industry standards: DOCSIS™ 1.0, 1.1, and 2.0 - compatible with any cable Internet provider
  • Ports: Ethernet, USB & Cable
  • Buttons: Reset
  • LED Indicators: Power, Internet Cable, Internet Activity, Ethernet & USB
  • Easy installation: One phone call to your Internet service provider completes the setup
D-Link DCM-202
D-Link's DCM-202 Cable Modem is powered by TurboDOX™ bandwidth acceleration software increasing your download speeds up to 20 times. The DCM-202 makes your broadband connection more efficient and effective by clearing network congestion, resulting in a boost in download speeds. With the DCM-202, you will get more out of your broadband connection with increased bandwidth and enhanced performance.
  • Always On, Always Connected
  • DOCSIS™ 2.0 Certified
  • Ethernet or USB Connectivity
Netgear WGT624 Super G 108 Mbps Wireless Router Netgear's WGT624 108 Mbps Wireless Firewall Router is 10 times faster than 802.11b routers providing 4x the range of 802.11b devices, and double the range of most other 802.11g products. Your home network is secure with over 10 security and privacy features including a double firewall and wireless encryption. Netgear's Smart Wizard set up software gets you connected in 5 clicks or less!
  • Interoperable with existing 802.11b and 802.11g networks
  • Smart Wizard gets you up and running in fewer than five clicks
  • Lighted power, test, Internet, wireless and LAN status icons
  • Works with most Internet gaming applications that support Universal Plug and Play
Dec 12, 2010 | Computers & Internet
My motorola SB5101 cable modem is connected properly. The power light is green but the receive light is keep on blinking other lights was turn off (send, etc.). Does my modem has a problem?
This light pattern indacates that the modem can not establish a connection to your internet service provider (ISP). This is typically do to a signal related issue. To trouble shoot the problem you will need to connect the modem directly to the main cable line where it first enters into the home. You will know when the modem establishes a connection by the top 4 lights becoming solid green. If at any point all 4 top green lights start to blink in sequence than you will need to contact your internet service provider to "unwall the modem". Remember most internet service providers require you to register new modems on there network. So if you have not all ready completed that process you will most likely not have access. If you can not get a connection from the main line than there is a issue with either the modem or the signal coming into the home and you will need to contact your internet service provider.
I hope that information above has helped is some way.
If possible please rate this solution.
Aug 29, 2010 | Arris SURFboard® SB5101 Cable Modem
My pc upstairs has slow internet my e-mail is wimvm@casema.nl i have a cablemodum from ziggo do i need a stronger router? wich one should i have?
you dont need a new router try running a virus check and virus updates on the security software on the computer upstairs as these can slow the speed of the internet to that computer
Sep 25, 2009 | Linksys Wireless-G WRT54G Router
New computer running slow
if you are using dial up, you shud not have a modem.. modem is just for DSL connection
if you have a modem probably you are using a DSL connection
DEFINITION:
dial up - connection using a phone line with internet connection; cannot use fone while on internet
DSL/modem- connection using a modem plugged in with computer and fone line; able to use fone even when on internet.
Jul 10, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Motorola SB5101 Modem
reset the modem at the backside with a pen and restart the computer, check for all the leds and it should be stable
Feb 06, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Allied Telesyn AT FS708 Networking Switch Logo
67 people viewed this question
Top Allied Telesyn Computers & Internet Experts
Prashant M
Prashant M
Mirca Sekosan
Mirca Sekosan
Are you an Allied Telesyn Computer and Internet Expert? Answer questions, earn points and help others
