Question about Maytag Dryers
Need to hold in start button for dryer to work, the minute you let go the cycle stops. replaced timer but problem still exists.
    Scholar:
  • 62 Answers
Hi without knowing the make I cannot offer a true solution.
If its a Candy or a Hoover model then there is a electronic circuit board that sits behind the button. This is faulty.
If its a hotpoint or a creda model then there is a "Hold on Relay" that keeps the machine on when you release the button.
Let me know the make and model on aardvark.repairs@btinternet.com
regards
Aardvark Repairs
Posted on Nov 16, 2009
Frigidaire AEQ8700FGO dryer will run (and heat) for about 30 to 60 seconds then stop. 3 lights above start button will flash rapidly. Depressing cancel and start buttons at same time will not work for...
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it
Sep 30, 2013 | Electrolux AEQ8700F Electric Dryer
Dryer wont stop buzzing
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
When i set the time on dryer and then push the button to start then dryer will run for a few minutes but then stops but still has a ticking noise
Your problem could be a faulty timer.
Watch the time and see if it rotates to different cycles. If it does not rotate to different cycles then you may need to replace the timer switch
Sep 25, 2009 | Whirlpool Dryers
Starts automatically when I set the timer
This could be a problem with the start button switch (it should click when pressed/released) or with the switch on the motor.
May 20, 2009 | Dryers
Shuts off after 10 to 45 minutes
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Whirlpool 6.5 Cu. Ft. 5-Cycle Super...
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Keeps stopping
I have a feeling you are buying a timer board.
Dec 11, 2007 | Kenmore Elite HE4 Electric Dryer
My Dryer Starts, then stops as soon as I release the button.
Its possible the dryer heat selector is at fault. If the timer inside does not move to the end of the heat cycle you may have further problems. Depending on how old the dryer and how long it has taken to dry garments, you may want to check that the motor has not gone bad causing an electrical overload. Faulty timers will cause extended drying times eventually putting a strain on the motor's bearings and electrical windings. You may want to get a replacement or get a repair estimate to repalce the belt, motor, drum rollers and heating coil components.
May 12, 2007 | Kenmore 63932 Electric Dryer
Dryers Logo
67 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
