Can you tell me the remote code for my t.v daewoo dlt 32c3
3 Suggested Answers
  • 55 Answers
SOURCE: DLT-32c3...... Mains light on but nothing else
Common problem on power supply board, dried capacitors need replacing
Posted on Oct 06, 2009
BElectric
  • 1140 Answers
SOURCE: I need a code to
The correct code for your TV depends on which version of Sky remote you have. The remote version can be found on a sticker inside the battery compartment. In most cases this will be "Rev 4", "Rev 6" or "Rev 8". However, if you have an older Sky remote with a standard Sky box (not Sky+ or HD)it could also be "RC1600/00". If you have bought a new Sky remote recently it could be "Rev 9".
There is no specific code for your TV model so you will need to try the brand codes for Daewoo. 0092 is the generic brand code, but the are others specific to the various versions:
RC1600/00: 0092
Rev 4: 0662, 0527, 0652, 0402, 0065, 0584
Rev 6: 0662, 0689, 0527, 0402, 1937, 0065
Rev 8: 1300, 0662, 1231, 0689, 0527, 1294
Getting Sky remotes to work when there is no specific code for a TV can be something of a black art. You should try the generic brand code first (0092) and then try the codes for whichever version of Sky remote you have. If they don't work, also try the codes for the other versions as Sky's information has proved to be inaccurate and mis-leading on numerous occasions.
Please note: some of the codes are duplicated so you only need to try them once. These codes should also work if you have a Rev 9 remote.
As you were previously able to control your TV with your Sky remote, it proves there is a code for your TV. However, it is rather strange that it has stopped working. This could be indicative of some other problem. Sky remotes can 'forget' the code when the batteries are replaced, particularly if the batteries died completely before you replaced them or you were too slow to put the new ones in.
If you haven't done so already, I suggest you replace your batteries before trying to re-enter the codes and when you find the correct code, make note of it and keep it in a safe place. There should be a space on the inside of the battery compartment to write the code but, if not, it is perfectly safe to write it on a scrap of paper and keep it in the battery compartment. Particularly useful, as you are most likely to need it when changing the batteries!
If you've tried all of the above codes and still can't get it to work, please reply to me from within this page for further assistance and let me know which version of Sky remote you have.
Hope this helps.
Regards,
BElectric
Posted on Jan 17, 2011
Comment programmer telecommande tv daewoo R-50k18pour la utiliser a un tv daewoo model DLT-42G1
How to program tv remote control daewoo R-50k18 to use it to a tv daewoo model DLT-42G1
Vous ne pouvez pas programmer une t?l?commande autonome pour qu'un p?riph?rique l'utilise sur un autre p?riph?rique, m?me s'il s'agit de la m?me marque. Une t?l?vision, une t?l?commande, celle faite pour cette t?l?vision. Seules les t?l?commandes universelles peuvent ?tre programm?es avec diff?rents codes.
You can't program a standalone remote for one device to use it on another device, even if it is the same make. One television, one remote, the one made for that television. Only Universal Remotes can be programmed with different codes.
codes for daewoo tv Google Search
Remotes, pour votre TV.
Amazon com Replacement Remote Control for daewoo DLT42G1 Home Audio Theater
Daewoo DLT42G1 Remote Control Replacement with 2 free Batteries...
DAEWOO REMOTE CONTROL WORLD REMOTE CONTROL WORLD shop with original and...
Jun 26, 2018 | Daewoo Televison & Video
Tip
DLT-32C3FTB
Hi.
This comment applies to Daewoo DLT32C3FTV. The system had in list only the model DLT-32C3FTB . Parts for the smaller model DLT-32C3FTB are available from the same sellers listed below. Troubleshooting is the same.
The stand by light flashing means that a fault had been detected, and the TV protection circuit had started.
Whenthis happen, the protection circuit will shut down all PSU highervoltages, keeping the low +5V to supply the flashing led on, and warnabout the fault.
The TV does not respond to control when in protect mode.
All you can do is checking all connections, and leaving the TV disconnected for a while, to drain charge held on PSU capacitors.
A short in a cable or connector will also cause the unit going on protection.
You can follow the instructions on this article, it refers mostly to DLP, but the troubleshooting is the same on LCD TV2_bing.gif: Why my TV does not start up and remains in.
If you have done that already, that means that there is an internal fault.
Inthat case the best thing to do is contacting manufacturer at the numberlisted on the owners manual, and getting a quote on repair.
Onan LCD like this there are only few parts, a main controller, aninverter, a PSU board, an audio board, an LCD controller board, abutton and IR assembly, cables and the display.
The parts must be accessed and tested by a technician.
If the unit is less than one year cold, the repair will be covered bymanufacturer. In any case, if the TV does not wake up from protectmode, then it is faulty. Always better contacting Daewoo at the numberlisted on the owners manual.
Parts are available from Daewoo. A spare PSU, that is a common fault, is about £60 in UK. Here the spare:
Power Board FEL-3226H Daewoo DLT32C3FTV . Naturally that is not necessarily the fault.
Try first the troubleshooting procedure suggested above. If that does not work, contact Daewoo.
on Feb 11, 2010 | Daewoo DLT22W4T 22 in. LCD TV
Hi can anyone give me a 4 digit remote control code for a Daewoo DLT-32G1 flatscreen TV please? Cheers Ben
Go to the web site of the manufacturer of your universal remote for the code, if any.
Feb 29, 2016 | Televison & Video
I lost my book and I need tte code for Daewoo TV
Philips Universal Remote codes for Daewoo TVs: 0614, 0002, 0502, 0611, 0102, 0415, 0905, 0615, 0505, 0826, 0529, 0046, 0609, 0805, 0407, 0303, 0602, 0214, 0403, 0314, 0503.
One For All Universal Remote codes for Daewoo TVs: 0451 0019 0092 0623.
RCA Universal Remote codes for Daewoo TVs : 1004 1005 1006 1016 1017 1082 1171 1190.
GE Universal Remote codes for Daewoo TVs: 0130 0004 0009 0100 0005 0138 0043 0140 0039 0252 0279 0444 0080 0042 0058 0017 0010 0126 0018 0127 0019.
Jumbo Universal Remote codes for Daewoo TVs: 004 005 009 017 018 019 042 058 082 085 097 100 126 127 130 138.
Sep 29, 2014 | GE Televison & Video
Whats the code for daewo ttv using a universal remotes/
Jul 20, 2012 | Televison & Video
Cant find code sheet need code for a deawoo tv for remote sru3006wm/17
Code Search Results--> --> Code For Model RCU300T
Code 004 for Daewoo TV Code 005 for Daewoo TV Code 006 for Daewoo TV Code 016 for Daewoo TV Code 017 for Daewoo TV Code 082 for Daewoo TV Code 171 for Daewoo TV Code 190 for Daewoo TV This is a basic set of codes for the TV, I am not sure of the model on the remote so I can only give you what I have. If these won't work, add a 1 in front of these 3 digit codes to make a 4 digit code, this should work. Good luck
Nov 15, 2010 | Universal Remote Control 6-Device...
Dlt-20j9t lcd tv completly blocked
Is the green light on? Power supply board has a know problem with dried out capacitors
Aug 15, 2009 | Daewoo DLT22W4T 22 in. LCD TV
My Daewoo LCD TV (DLT-32C3FTB) will not come off standby.
Common problem on power supply board, replace dried out electrolytic capacitors
Apr 22, 2009 | Daewoo DLP3212 32 in. LCD Television
Daewoo lcd dlt 20w2
Hi this is warjis ahmed,
I can solve your problem of DLT-20W2
My email> warjisahmed@hotmail.com
Oct 29, 2008 | Daewoo DSL-17DW3 17.1 in. HD-Ready LCD...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
