Question about Kitchen Ranges
Gas Range Have GE gas range Model jgs968. Control panel is not working and F0 is displayed.
    President:
  • 1,314 Answers
Touch the clear/off pad then try again if that doesn't work then cut off the breaker for 30 secs then reset the clock and see if the code resets
Posted on Jan 09, 2008
I need Please a solution to F1 Error Code on GE/Kenmore electric ovens Model # 911.4658815 Thanks E-mail: elylimo@gmail.com I have the same model number. 9114658811 and plugged in the stove for the...
To my understanding error code F1 would indicate a faulty control board, possibly thermistor control. The only recourse is to have this replaced.
This of course would require a fair familiarity of electrical/electronic components/circuitry and safety procedures, use of a DVM and possibly a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Kenmore 46123 Stainless Steel Electric...
Have GE spectra range model JB960. The F0 button came on. Followed troubleshooting but no success. Do I replace keypad? If so, how? Where do I get one?
The "F0" fault code implies the Clear/OFF pad is shorted or a touch pad failure. If the code cannot be cancelled, unplug or disconnect the power supply from the range and then disconnect the keypad and then power it up. If "F0" ceases, replace the keypad/glass assembly; if "F0" is still present, replace the main oven control.
I added an image below with instructions how to access the control and glass panel. NOTE: Disconnect the range from the power supply before servicing.
Aug 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Getting error code F0 during oven cool down. During F0 keypad does not respond to clear error, however after waiting several hours error can be cleared. Next use is fine but error reoccurs during cool...
F0
Stuck touch pad Usually means that either the touch pad or the oven control
(also called clock or ERC) is defective and needs to be replaced. If this fault
code cannot be cancelled, replace the oven control (also called clock or ERC),
touch pad, or both.
Jan 31, 2011 | GE Profile JGS968 Gas Kitchen Range
Oven won't light GE floor range profile model
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
hgdhgd
Dec 19, 2009 | GE Profile JGS968 Gas Kitchen Range
Electronic control touch pad not working
This is your electronic control board that needs to be repalced on this unit. GE Profile is a great brand and it is easy to repair, also.
We provide part removal/installation instructions for our customers when you purchase your parts from us.We also ship parts overnight to assure that you get your oven repaired right away.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 9 PM CST. We look forward to getting you cooking again soon.
Thanks, Ella
Nov 17, 2009 | GE Profile JGS968 Gas Kitchen Range
No Bake; everything else works
Most likely a bad bake igniter wb13t10045 cant guaruntee thats the problem but I'd start there.
Jan 28, 2009 | GE Profile JGS968 Gas Kitchen Range
Ge profile JGS968 fan comes on no ignition on gas bake convection bake and roast . Only broiler works otherwise themp always read 100 Degress
natural gas or propane? is this a brand new stove? or did this just start happening? is the gas shut off at the oven turned on? there are saftey features that shut off the gas so you dont get hurt. be carfull
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 09, 2007 | GE Profile JGS968 Gas Kitchen Range
Kitchen Ranges Logo
128 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
