Question about Sony Ericsson Walkman W810i Cellular Phone
Hello i topped my mobile up by 50 pounds and it hasent gone on my mobile.
You need to contact you network provider, they will look into it for you but can tell if it has worked or not.
Posted on Nov 17, 2009
    Guru:
  • 312 Answers
That will be because of the network failure...So you can contact the store from where you topped..and tell ths problem...They will find a solution for you....If you used coupon...then call yto customer care and tell this problem....They will clear this ...Hope you will succeed....Thank you....
Posted on Nov 16, 2009
I have a 1999 jeep grand cherokee laredo 4.0 inline 6 and i filled it up but now the gas gauge is reading way over full. And i been drivin it and it hasent moved. What could be making it do that?
Fuel gauges normally work off a float inside the tank, it may be that the float got jammed when the tank was over filled, as you drive it may free its self with the normal vibration of travel. Keep an eye on the distance you have gone and refill tank before you run out, but do not fill to top of tank this time.
Feb 22, 2016 | Jeep Cars & Trucks
Please can i phone you
Call your cellphone provider.
Oct 18, 2014 | Cell Phones
My kymco midi goes ok for about 1 mile then slows and then stops the battery ok can it be the motor
Hi there i would get it fully serviced before it breaks down completely a full service would cost you 50 pounds
Pete
Oct 09, 2014 | Kymco Midi XL 8mph Mobility Scooter with...
Why have I got sound but no picture?
I suspect the inverter board has has gone.
Samsung has a few common faults with their tv sets. can get one for around 20 -30 pound,pretty easy to fit.Hope this helps.
Sep 24, 2012 | Samsung PS50A466 50 in. Plasma HDTV-Ready
How many 12 ounce tins of tuna to make up 50 pounds
There are 16 ounces in a pound, so 50 pounds is 800 ounces. Dividing 800 by 16 gives 66 and two-thirds.
Press 1 6 * 5 0 / 1 2 ENTER to calculate this result.
Sep 05, 2011 | Texas Instruments TI-84 Plus Calculator
The colors dont line up on top of each other to make the picture clear how do you fix it
hello, have you gone into convergance setting and try to adjust the lines if so and it hasn't worked then the convergance ic are the cause of the problem 2 large chip that sit on a metal frame called heatsink, these will have to be replace. also there will be some resistor and capacitors these will need to be tested as well and any pico fuses will have to be tested. for an engineer to do the work it will probably cost £300 to 450 pound, if you were to do it 40 80 pound but you'll need circuit diagram and a good multimeter and good desoldering and soldering skills. the chips are usually located behind the tuner board hope you can get it fixed
regards
shaun
Nov 29, 2010 | Samsung HC-P4741W 47" Rear Projection...
2002 saturn l100 A/C wont work
ok ac system has a pressure switch that stops the compressor when freon is too low. they actually say it is ok for mobile a/c systems to lose a half pound a year. most a/c systems run on under 2 pounds of freon. so after 3 or 4 years some systems will just quit working. you are at 8 to 9 years so i would recommend you find an independant shop that will top off your a/c and see if it works again. this should not cost more that 50 to 75 bucks. If you were here that is what i would charge. I am in columbus ohio just to let you know. hope this helps and thanks for using fixya
May 06, 2010 | 2002 Saturn L-Series
Screen proble
HELLO,the screen price should range between 50-60 dollars,try tovisit an expert repairer you might not need to change the screen,it could be the outer screen that needs to be changed and this is attached to the casing.which the price should range between 13-15 pounds.
please kindly rate this solution if it's helpful.
take care.
Apr 16, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Sony Ericsson Walkman W810i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
