TOA 903A Lack of volume when unit is powered on. After master volume is rapidly twisted from 0 to 100%, speakers krackel and music slowly comes back to an acceptable level. Have sprayed a contact cleaner in master volume rheostat (knob), this has helped a little, but the unit is still unreliable.
  • 4,234 Answers
If the volume control does not appear to be defective, I would next check the speaker relay. If the contacts there are corroded, the symptoms will be as you describe. The higher voluime level will allow the initial "connection" to occur with the unit working almost normally after that. Replace the relay with a new one. You should be able to get one from TOA.
Dan
Posted on Nov 16, 2009
How to get sound from a nady audio 4130 mpm 4 channel power mixer
First, plug it in. Next connect the speakers. Center all eq controls both master and channel. Turn off any reverb or effects. Turn the master volume 1/2 way up. Plug a sound source into channel 1 wiyj the channel volume all the way off. Turn on the amp. Slowly raise the channel volume until you heat output. If you get nothing, it's broken.
Nov 10, 2016 | Nady Systems Music
How to do a master reset on a ctk-491 keyboard, no sound from speakers
Does unit power up? A "dead" keyboard could likely be a defective "wall-wart" power supply BUT don't forget to check the AC outlet as well. If the function lights come on but no audio, I would 1st check with headphones but if that is also dead it may be related to either the slider style volume control on the keyboard, or internal electronic failures.
Mar 02, 2015 | Casio Ctk491 Midi Keyboard
Got a problem with my speakers thay are plugd in but there is no sound comming out off them
If they are powered speakers please ensure that both the power cable and the audio cable are plugged in. If the speakers have a volume knob try slowly turning it up while you play music. If nothing still happens, try plugging the audio (green usually) into another audio device (E.g. iPod) and play music from there to test the speakers.
Jul 28, 2011 | Audio Players & Recorders
Standby light is flashing rapidly and I cannot turn on
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR7002-Receivers-manual/id/6753ci475/t/2/
Page 81...
PROTECTIVE FEATURE
In some cases, the STANDBY indicator may blink slowly, twice per second. In this case, turn off the unit, unplug the power cord, and check the following points.
Make sure the speaker cables are not reversed and connected to the wrong sides (+ and -) on the unit.
Make sure the speaker cables connected to the unit are not shorted. (Check both the unit end and the speaker end.)
Make sure the volume does not exceed the level that the unit is capable of producing.
When using the unit in a rack or other enclosed space, heat may build up inside the unit and cause a fire. When installing the unit, be sure to leave suffi cient space between the top, back and both sides of the unit and walls or other AV components to prevent the internal temperature from rising.
After checking these points, plug in the power cord and use the remote controller to turn on the unit. Turn down the volume before resuming playback. Confirm that there are no problems with the speaker connections and playback performance.
If this symptom recurs, request service at your nearest service center.
In rare instances, the unit may enter standby mode and the STANDBY indicator may blink rapidly, 8 times per second. In this case, unplug the power cord and request service at your nearest service center.
Feb 27, 2011 | Marantz SR7002 6.1 Channels Receiver
There's a button on the back of my vlz pro that says main output +4...if the button is depressed it pads the unit..i saw that in the manual. my question is, for live performance when i use the mixer to...
This will depend upon the speakers. I would suggest that you place it in the +4 position with the main slider down and slowly increase it with the speakers set as you normally would have them. If the sound quality is poor at low volumes, then you are overdriving the inputs to the speakers and need to use the other option from the mixer. If you still have questions, please post what you are using for powered speakers and I can better guide you.
Dan
Nov 18, 2010 | Mackie 1202vlz3 12 Channel Mixer
Protect power keeps coming on - rdx5 MHC
protect usually means a speaker wire problem. remove all connections and redo them making nice tight twists in the connections the spliced end should be no more than 1/4 inch long. make sure to do this for all speakers as well as on the back of the unit.
Feb 23, 2009 | Sony MHC-RXD5 Shelf System
M&S Systems MC602 Master Unit and M&S MCD6 6-disc CD Player
mc 602 system---volume stuck on 32 and not playing main speaker
Mar 05, 2008 | Audio Players & Recorders
Only one speaker working
Even I have faced the same problem for the past six months.. Today i have fixed only issue with the back jack.. removed slowly and fixed it tightly.. it's works. :)
Oct 06, 2007 | Harman Kardon HK206 Computer Speakers
Speakers fade in and out when listening to music
ensure all connectors are properly inserted, then if you have a speaker mounted volume control, then run it back and forth rapidly about 100 times with power off. this will allow the tiny copper "wipers" contacts to brush off any accumulated dust.
May 25, 2007 | Dell 5650 Computer Speakers
64 people viewed this question
 Grubhead
Grubhead
