Question about Maxent MX-42HPM20 42 in. Plasma HDTV
Horizontal lines on Screen
My TV started about a week ago with a horizontal line about 5" from the top. The line is very thin. A few days later 3-4 horizontal lines appeared at the bottom. These lines are black and very distracting if you focus in on them. I contacted the manufacturer and was told that the screen needs to be replaced. The TV is not even 1 year old. They said that they will replace the screen for free. I would have to pay for the shipping of the TV to the manufacturer which will run about $1,300.00 - $1,500.00 with insurance. Is there any other way to ressolve this issue?
  • micheleb Apr 15, 2008
    My 42" plasma from Maxent is about 2 years old and now has 2 black vertical lines coming from top of screen . They are about 1/2 -1" wide and go halfway down the screen. Both lines come and go, but they are never both gone at the same time.
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Here's something you can try...remove the back and notice that there are ribbon cables (FRAGILE!) on the right and left side...alot of times these cables develope bad connections and cause the lines you see...other times the panel will be suspect. Removing these ribbon cables and reseating them have helped me determine in the past if it is a bad connection...or a bad panel
Posted on Jan 31, 2008
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
Dec 20, 2015 | Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET -
Jun 10, 2015
More results from
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
Sep 2, 2014 - Uploaded by
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Horizontal line at top of screen in any hd format with componet or hdmi. model is sv470m. the tv isn't even a week old.
Get into the TV menu and locate the H (Horizontal) and V (Vertical) picture options. . .increase the V until line at the top is gone.
Oct 20, 2009 | Vizio SV470M LCD TV
Horizontal lines at the top of the t.v. screen.
you will have to find fault in vertical deflection try condencer replacement in that stage
Jul 11, 2009 | Philips 27PT6441 27" TV
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Jun 23, 2009 | Toshiba 36A40 36" TV
Insignia 32" TV Thin line across screen 1-2" from top
This is usually caused by bad capacitors in the vertical circuit. If you have an electronics background you should be able to find the defective ones with an ESR tester .
Dec 16, 2008 | Insignia NS- 27" TV27 TV
Permanent horizontal black lines on my 50
Ive got bad news for you, about 90% of the time black horizontal lines are caused by the panel failing, your going to need a new TV. You can try replacing the timing board but the chances of it fixing it are slim..
Jan 06, 2018 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 14, 2008 | Gateway FPD2275W LCD Monitor
Picture is now a thin horizontal line
now only visible in a thin horizontal line. first of all you reduce brightness to monimum. it just to protect your tv from crt demage. your problem is in horizontal output section as you have mentioned that week or so ago the right and left bottom edges of the picture began to move in like a sideways triangle filled with black so this sympton is due to hor. section problem. your flyback transformer or horizontal output might be defective. but remember check for power supply is ok from surge protector hope this will help.
Oct 07, 2007 | Hitachi 35UX80B 35" TV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Maxent MX-42HPM20 42 in. Plasma HDTV Logo
515 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
