Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
Electronic secuity pin ( 4 digits ) no longer opens electronic safe. The outside of the safe is marked CE GXB0709. I do not know if that is the make of the safe. The pin is diplayed as a LED 4 digit number. We have tried several times tto open it without success. There was a key to the safe for use at these very times, but we have lost it! Any advice would be gratefully received.
  • Anonymous Mar 23, 2014
    I`ve lost the key for electronic safe gxb0709 and the battery is dead. I`m no longer able to open it. Could i get a new key anywhere? Am i able to buy a new key? I`m the owner of the safe.
  • 3 Answers
It sounds like it has reverted to it's factory setting if you can find the hand book it should be in there
Posted on Nov 17, 2009
Where is the battery compartment in my ce electronical digital safe?
do you have a round lock pad. This model has 2 9 volt batteries under the key pad
http://bestbatterytips.com/change-replacement-batter/safes-with-electronic-locks-replacing-the-battery/
Lots of info here
  • How to open digital safe when battery is flat and key not ... www.youtube.com/watch?v=aqC9V7SDKdQ
    • BY KHTHHONL
    • 1 MIN
    • 417K VIEWS
    2012-11-09 · How to open a digital safe when the battery is flat and the ... How to open digital safe when battery is flat and ... How Secure Are Electronic Safe ...
  • Locked out of my Digital Safe [Archive] - PPRuNe Forums www.pprune.org/archive/index.php/t-357319.html PPRuNe Forums > Misc. Forums > Computer/Internet Issues & Troubleshooting > Locked out of my Digital Safe. ... CE (Chinese made) electronic security safe ... battery ...
  • LA GARD LG Basic digital electronic safe lock changing ... www.youtube.com/watch?v=M07EpfSmoAU
    • BY DEANSAFE
    • 3 MIN
    • 99K VIEWS
    2009-10-13 · For instructions on this and other electronic digital safe ... How to change the combination and battery on ... Basic digital electronic safe lock changing ...
  • User Manual for Safe EA25 Installation - Tayabally www.tayabally.com/digitalsafe/mannuals/Safe EA25 Installation... You should change the code as soon as possible after opening the ... BATTERY REPLACEMENT. This safe uses ... MAINTENANCE FOR KEY AND ELECTRONIC SAFE.
  • Elektronischer Digitaler Safe Electronic Digital Safe www.produktinfo.conrad.com/...799999/...DigitalerSafe_de_en_fr_nl.pdf · PDF file Electronic Digital Safe Version 12/08 ... (CE). Any usage other than ... Replace your batteries when both the red and green light illuminate. 1.
  • Instructions for an Electronic Digital Safe ' eHow www.ehow.com > Home > Home Safety > Home Safes Instructions for an Electronic Digital Safe By Shawn McClain eHow Contributor Pin Share ... Replace the used batteries with new ones. For most safes, ...
  • Apr 24, 2016 | Locks & Locksmithing
    My ce safe has flat battery. how do we open it, please advise Graham
    i have a CE electronic safe,batteries went,so i heated the lock with the hair dryer,it worked for me
    Jun 12, 2011 | Safe International Digital Electronic Safe...
    Can not open safe no key dead batterys
    You should be able to change the battery from outside the safe by removing to keypad but no key means you have to drill out the lock start with a small titanium drill bit like a 3/16 and step up the hole size until you have the entire core drilled out then you will have to drill a hole throw the metal case(1/2"drill bit) above and below the key hole to get to the pins then drill a hole in the pins with a small drill bit just enough to put a notch in them so you can pry up on the bottom and down on the top with 2 screw drivers at the same time to release the pins ( not easy to get into a safe ) but it can be done I had to get in to one and this is how I did it, it took about 2 hours to get in it . And the safe was ruined in the process you could call a locksmith that could cut a key for it don't know how much it would cost? They just slip a blank key in the key hole and notch out where the tumblers leave marks on the blank it takes a while and a few blanks. But it can be done if you know what to look for on the blanks.
    Hope this helps and good luck........
    Dec 08, 2010 | Safe International Digital Electronic Safe...
    Dead battery! CANNOT OPEN SAFE
    This model is supplied with a key for emergencies. There is a plastic panel in the middle of the door with a silver sticker on which the moel number GXB0709 is printed . Lever off the plasic panel to reveal the keyhole.
    May 09, 2010 | Safe International Digital Electronic Safe...
    Change code
    Try this
    Open the safe.
    press the red button on inside of door
    entry the new code you want followed by B
    Should be good
    Nov 22, 2009 | Safe International Digital Electronic Safe...
    I have a gordon digital electronic safe # P45891, lost combination .how to open it?
    Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
    Jun 30, 2009 | Safe International Digital Electronic Safe...
    Batteries weak
    Hi, Don't know the make and model of your safe but this advice works for sentry safes,if it doesn't help you get back to me with a make and model: If you need to know how to put batteries in, Turn the electronic lock clockwise ( to the right) from the 12 o'clock position to the 2 o'clock position which opens it so you can put in 4 fresh AA batteries replace the assembly by turning it to the left from the 2 o'clock back to the 12 o'clock. enter your combination and check for the green light. Good Luck!
    Feb 08, 2009 | Safe International Digital Electronic Safe...
    Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
    2,010 people viewed this question
    Top Safe International Locks & Locksmithing Experts
    Jim London
    Jim London
    john h
    Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
