Question about Nautilus Exercise & Fitness
I have a Nautilus Bowflex 5 series treadmill. After 10 to 15 minutes running it suddenly stops and Er 5 shows up.
  • Anonymous Mar 28, 2014
    My Bowflex Series 3 treadmill suddenly won't give me a correct heart rate. Whenever I try to read my heart rate it comes up as 213 or 214 when I know it should be around 100 - 140. What causes this . . . and how do I fix it?
    New Friend:
  • 64 Answers
I will have to check the error code but sounds like a heat problem. When you get too much friction between the walk belt and the deck it builds a lot of heat which creates more drag on the motor. This causes the motor to overheat which in turn usually shuts the machine off. You can let it cool and go back exercising until the cycle repeats. If this sounds like your issue, try lubricating the walking belt. If it's not in bad shape it should make a difference. The machine should run longer. 10-15 is pretty quick though so it make take a couple of application of lubricant. The belt may need replacing if the need for lubricant becomes too regular.
Posted on Nov 17, 2009
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Jan 27, 2016 | Bowflex TreadClimber TC10
The power will not come on when plugged into a working outlet
[PDF]Bowflex Treadclimber - Nautilus
download.nautilus.com/.../Bowflex/BFX_TC5300_6000_OM_AM_Rev...
Bowflex® TreadCl mber® Assembly and Owner's Manual. PREFACE ..... will not workand an electric shock hazard may be present if the wires ..... Plug the machine into anoutlet and turn on the power (see Page 24: Turning on the Power). 2.
Nov 04, 2015 | Bowflex TreadClimber TC20
Bowflew series 5 belt slip
Could be a loose tread-belt, loose drive belt or faulty front roller
Feb 14, 2014 | Nautilus Bowflex series 5 treadmill
Startrak 950 orbit treadmill
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Jun 03, 2013 | Nautilus Exercise & Fitness
My Bowman treadmill 7 series stopped working. It just shows 2 words: safe out. Please help.
Make sure the magnetic safety key ('safety pull' or 'emergency stop magnet') is in place. SAFE OUT indicates that the safety key is not in position or is otherwise not working properly.
For more information consult the following manuals:
http://download.dfxi.com/supportdocs/OM/Bowflex/BFX_TM3-5-7_OM_RevD_web.pdf
http://www.pdfstock.com/bowflex-3-5-7-series-treadmills-assembly-manual-pdf.html
May 05, 2011 | Bowflex Treadmill Series 7
I have an L5 error on the display. Belt not working. What do i do?
This is a LS or speed sensor error, it can be caused by a belt that is too tight, non lubricated walking belt and or a bad sensor. If the belt does not move at all, Bowflex will tell you to buy a new lower control board. $227 direct from them (Nautilus)
Jul 19, 2010 | Bowflex Treadmill Series 7
My bowflex is showing "err l5" what is wrong with it?
This error indicate that the console is unable to deter mine the speed of the belts. Potential parts associated with this are the Speed Sensor, MCB, Motor, I/O cables, and Upper Electronics. Call Nautilus Service Dept 1-800-628-8458
Apr 14, 2010 | Bowflex Treadclimber
Bowflex series 3 stops after 10 min
To much electrical draw on motor control board
Lubricate, lubricate, lubricate
Jan 26, 2009 | Bowflex Treadmill Series 7
Tread will not move, shows a L 5 error code
You need a new lower control board. 225.00 from nautilus.
Dec 14, 2008 | Bowflex Treadmill Series 7
Exercise & Fitness Logo
305 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
