Question about T-Mobile Dash Smartphone
Dash screen will go white.
I laid down on my phone, and now it won't work, when i power it up the screen is white, but i get the tmobile sound. tried to do a master reset and nothing. can anyone help me ?
  • 4 more comments
  • stoaks Jan 09, 2008
    Same issue as previous poster. Screen is completely white (or light grey), but the phone is on and working otherwise (I can call it for example or use a bluetooth headset).
  • sirricharic Sep 17, 2008
    yea my phone was sitting on the desk and it did the same thing all i see is a grey screen
  • Nathan Shirley Oct 23, 2008
    I droped my phone and screen went white second time.
  • tiekis Dec 01, 2008
    replaced lcd screen, now turn on goes all white
  • garyinstereo Jan 12, 2009
    replaced LCD, phone worked fine but was running a bit slow so I reset. Now when I power up the screen just flashes the tmobile logo briefly and then goes black. bummer.
  • Anonymous Jan 23, 2009
    my fone turn white to is there a way to fix it
For me, the problem was definitely the ribbon connector between the graphics chip and LCD. The YouTube video below describes how to open the dash. You only need to open the device (i.e. no need to take out the printed circuit board) and then you should re-seat the ribbon cable in the lower left hand corner back onto the PCB. Hardest part was finding a #6 torx screwdriver.
Posted on Jan 24, 2008
    President:
  • 625 Answers
It is probably the ribbon connector. Here is a guide for replacing the screen. Just follow the parts that take you to the connector. If the ribbon connector reset doesn't work then a new lcd probably will.
Here is the guide
T-mobile Dash LCD repair Guide
Posted on Oct 25, 2008
I have the exact same problem after replacing the screen...Unfortunately, it is not the ribbon connector..I reconnected it 3 times ... didn't help...I check every connection...didn't help...
any idea ? has anybody fixed the problem by replacing the ribbon connector ?
Posted on Aug 07, 2008
I had this problem also, the screen would intermittently go white. I think a connector is loose inside (i dropped my fone a few times) every so often i would try shaking it really hard to see if the screen would come back. I also treated it nicer and stopped dropping it. the image came back and so far everything its ok. that's the low budget solution. you should probably get it fixed though if you don't have the infinite patience that i have.
Tmobile dash screen is white
Yes it causes probelm in u r display , u need to replace it ,
Apr 22, 2010 | T-Mobile Dash Smartphone
My phone won't power up. It starts on the white
you have to do a master reboot onyour phone.the same thing happened to me. before u power up the phone hold the 2 white line buttons and then power the phone on without letting the buttons go.
Jun 09, 2009 | T-Mobile Dash Smartphone
My tmobile dash freezes every time i try to start.
Turn the handheld off, hold the two soft keys (the dashes to the left and right of the phone buttons) hold the power button for 1-2 seconds and then release the soft keys. It should prompt you to clear storage. The “send” button is considered as the green phone button.
How to Hard Reset a T-Mobile Dash with operating system: 1. Select Start
2. Select Accessories
3. Clear Storage
4. Type in 1234
5. Select Yes
if this helps please rate the posting..thanks
Mar 02, 2009 | Cell Phones
My tmobile wing won't turn on
If you have an SD card in your phone take it out and try turning it on. You can take it out when you see it going back to the white t-mobile screen. Once the device is on and to the home screen you can insert the card again.
Oct 28, 2008 | T-Mobile Wing™ Smartphone
T-mobile dash
Did you do the MASTER RESET?
1. PRESS AND HOLD BOTH SOFT KEYS.
2. WHILE HOLDING DOWN SOFT KEYS, PRESS AND RELEASE THE POWER BUTTON, WAIT 3-5 SEC. (PHONE SHOULD POWER ITSELF ON BY DOING THIS)
3. RELEASE THE TWO KEYS SOFT KEYS.
4. WHEN SCREEN ON DASH LOOKS LIKE IT'S IN DOS FORMAT, PRESS SEND (GREEN ANSWER KEY)
- If this does not work you can try to flash the phone back to factory. Look up TMOBILE DASH factory flash.
May 16, 2008 | T-Mobile Dash Smartphone
Won't Boot Up, Alternates between Windows screen and TMobile screen
Master repoot the phone. You will loose all data, but you can recover the phone.
Tmobile dash is getting me p'd off
Mine does the samething. I'm running 6.1 and have found the problem to be the system fails to read the sd card on boot. When I reset my memory I don't put the sd card in until the system has booted back to the start screen. Works fine everytime.
Apr 15, 2008 | T-Mobile Dash Smartphone
Camera problems
you can do a software reset.......to do this the phone needs to be off. press the soft keys (buttons with the lines on them above the back arrow and home button) and press the power button and keep you fingers on the soft keys until a black screen with white writing pops up....by pressing the green call button here, it will reset the phone.....good luck!
Dec 31, 2007 | T-Mobile Dash Smartphone
Tmobile dash frozen on WINDOWS(DIRECT TOUCH TECHNOLOGY SCREEN)
do a sw reset....its possible it was damaged when it was dropped in the water, but not likey....
turn the phone off, press and hold the soft keys (buttons with the lines on them above the home key and back arrow key) and hold it down.....press the power button while you are doing that until the white t-mobile screen will come on, then instead of going to the green windows mobile screen, a black screen with white writing......press the green button....it will get you in your phone but it will erase your info as a result....
Nov 23, 2007 | T-Mobile Dash Smartphone
T-Mobile Dash Smartphone Logo
2,259 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
