Question about HP 32sII Calculator
Hp 32s failed test with a fail 8 error message
What you must do is remove the batteries and short out the two terminals they touch for a few seconds with a battery.
Posted on Mar 04, 2010
How to manage BIOHD-8 Error Code
Hi
If your drive is showing a SMART error I would consider replacing the drive as its showing the 1st signs of failing and if you don't have backups of any important data on there I would back it up now as when it failes you wont have any way of recovering your data
Cliff
Aug 21, 2014 | HP Computers & Internet
I have a 2430 Hp and with the error message 52.00. I have reseated the connections and same error message appears. I have swapped the Laser/scanner with known good one -still same error message. Put back...
Did you change the parts one at a time or all at once?
I think that you swapped the laser/scanner from good printer to bad and it still failed. And then you put original back in bad printer, but didn't put it in the good printer and test it there. And then you swapped out the ECU. Bad printer still bad. You then put original ECU back in bad and then put the laser/scanner and the ECU in the good printer. Now you test the good printer and now fails with the same error as the bad one.
Now you don't know which of the parts in the good printer got wiped out in the bad one. In fact both of the parts could now be bad.
There's a lesson here somewhere.
Dec 09, 2010 | HP LaserJet 2430 Printer
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
Moultrie game cam error code 1496 ?
this can't be an error code; error codes are in the format of 000000...100000=bat.test(0=pass;1=failed);020000=flash test/charging(0=pass;2=fail);003000=IR Sensor Test(0=pass;3=fail);000400=Camera Mod Test(0=pass;4-fail);000050=Memory Test.In this digit there are several codes...(0=memory ok/no sd card;5=memory full;6=SDcard locked;7=SDcard damaged;8= comms error)last digit,000006=Clock Test(0=pass;9=fail).
Are you sure this # is not preceeded by an "E", WOULD BE # OF EVENTS SINCE THEY WERE LAST CLEARED.
Ron L.
Jan 15, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I get lens error M425-12 7f80 and when I test
When you get the message CCD calibration failed nothing can be done other than taking to service center to get your camera repaired . Professional help is required in replacing CCD in your camera .
Thanks for using Fixya.
Dec 08, 2009 | HP Photosmart M425 Digital Camera (5MP,...
Received the following message when I tried printing - "System Error. The printer failed to print due to a system error. Try printing again. If unsuccessful turn Windows off and reprint." Can you sugg
Turn it off and unplug it for about 30 seconds. Plug it back in, turn it on and try printing a Self-Test (Setup, 2, 5). If this works, try printing your document again.
Apr 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Designjet 800 with a 'system error 81:01'
i have hp dnj Plotter 500 Printer Is Redy But Self Test & Computer Print Than Error 81:01 Papar Jam
Feb 23, 2009 | HP Office Equipment & Supplies
C7280 hp all in one has failed the fax hardware test
I uninstalled and installed again and that seemed to have fixed the problem.
Dec 09, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP 32sII Calculator Logo
1,018 people viewed this question
Seeker5211
Seeker5211
