Question about HP DeskJet 1280 InkJet Printer
Printer will not turn on Power cord is conected and turned on at wall but the machine just sits there dead. Does not respond to any of the buttons being pushed
Check that the duplexer unit (or the panel where the duplexer would go) is inserted and locked correctly. if it's not the printer flashes the power light on very briefly and will not power.
Posted on Nov 25, 2009
My printers ink clogs and wont print
Reset the product
  1. Press the Power button (c01602202.gif ) to turn on the product.
  2. With the product turned on , disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Wait at least 15 seconds.
  5. Plug the power cord back into the wall outlet.
  6. Reconnect the power cord to the rear of the product.
  7. If the product does not turn on by itself, press the Power button (c01602202.gif ) to turn it on.
Jul 06, 2011 | HP Officejet 6500 Wireless All-in-One...
It won't shut down and reset and there is no messages on the view screen on the printer
Welcome to Fixya
Try to reset the power of the machine first by unplugging the power cord of the printer from the wall. Let the printer sits for 5 mins then plug it back in then turn it on. Wait until the printer finished initializinf then try to turn off the printer and see if it will respond.
Thank you for using Fixya!
Jul 05, 2011 | Computers & Internet
I cannot open my printer
hi there!
what kind of printer is this, the brand/model name? if you cant turn it on, make sure the power cord is plugged in tight on the printer and directly to the wall outlet (dont use power extensions for now). if its all plugged in, press the power button. if it doesnt light on, press and hold it for 30secs or until it turns on. if its still not responding, there may be a problem with the power cord or the printer is simply dead. if your manual said to reset it, try it too. but make sure you read the manual carefully for reset may even damage the printer.
Apr 07, 2011 | HP Office Equipment & Supplies
Hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
All the lights are blinking! I cant turn it off
To resolve the issue, follow the below steps:
Step 1: Follow the weblink
Rather that sending you steps in text, i will refer u to the weblink. Where all the info is explained with graphics.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00867129&cc=us&lc=en&dlc=en&product=3177566
click on the weblink and follow the steps.
Step 2: Power cycle
Follow the steps below to power cycle your all-in-one:
Verify that the unit is switched on. Disconnect the USB/Ethernet cable from the All-in-One and also disconnect power cable from All-in-One and also from wall outlet.
Wait 20 seconds.
Plug in the power cable to All-in-One and also to wall outlet.
Step 3: Semi full reset
Note: A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models.
1) When the printer is turned ON, Disconnect and then reconnect the power cord.
2) When the lights begin to flash, press ON and CANCEL buttons simultaneously.
3) When the printer turns OFF, release the buttons.
4) Now turn ON the printer
Jun 22, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
My hp officejet 7410 all in one display only hp invent and not respond
Perform a power reset
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
Sep 25, 2009 | HP OfficeJet 7410 All-In-One InkJet...
No power
Try this: - Turn machine off; remove power cord; remove battery. - Without battery or power cord, press the power button and hold it down for at least 10 seconds. This discharges power 'residue' in the machine [and, I suspect gremlins]. - Reassemble power cord and battery. - Restart.
Mar 19, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Printer doesn't turn's on
Per Canon:
Solution: Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
Secure all Power Connections
  • Disconnect the AC Power Adapter or power cord from both the device and the electrical source.
  • Then reconnect it.
  • If you are still unable to obtain power to the device, try another power outlet.
  • If possible, try connecting power directly to a wall outlet (as opposed to using a surge protector or power strip...just as a troubleshooting measure).
If this does not work, have you tried a different outlet to ensure that the outlet isn't the issue? Also, when you press the POWER button, does the printer respond at all, or is it basically dead?
Please post back if you need further help, otherwise, thank you for using and rating FixYa!
May 24, 2008 | Canon PIXMA iP1600 Printer
HP DeskJet 1280 InkJet Printer Logo
153 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
