I have a vox valvetronix vt 50 around 3 years
I have a vox valvtronix vt 50 around 3 years old has not been used for almost a year when i turned it on it was fine, next day while using it it suddenly began crackling loudly,
and then nothing exept a very loud continuous buzzing
and no output at all. any ideas!
  • Audio Player... Master
  • 5,047 Answers
You will probably need to replace the large Electrolytic Capacitors in the power section. They can fail like that if left without power being applied for a long time.
If you see any other large ones (size wise) I would replace them too, just in case.
The big ones are prone to drying up more than the smaller ones you will see inside it.
Posted on Nov 24, 2009
Is it possible to lower the VOX VT50 transfo outgoing voltage?
bulbs have tolerance, that means it can work with + or - 6.3v just use the 7.6v which a diffrence of 1.is ok for it to work.
Jun 27, 2014 | VOX Amplification Vox Valvetronix VT50...
Vox vt40 factory reset
Consider reading the Manual for this amp, it explains how to reset to factory with the VFS5 footpedal. Or with the power off ..hold down CH1 & CH4 then turn power on.. when the Bank & Channel leds start blinking.. then release the Channel buttons. Next press the Tap switch ... the bank & channel leds will change from blinking to lit. with in a few seconds it will enter preset mode.
Apr 12, 2014 | VOX Amplification Vox VT40+ Valvetronix...
Vox vt40+
that is because it is two different output channels. eventually you will blow the speaker or your amp. It wasn't designed to handle the impedance of an external speaker through the stereo
headphone jack. Are you sure that your speaker is hooked up or plugged in?
Mar 30, 2014 | VOX Amplification Vox VT40+ Valvetronix...
I have a vox valvetronic 50, which keeps blowing fuses as soon as it is switched on and leaves a burning smell. any ideas?
One or more parts in the power supply section is defective. I would recommend taking/sending the unit to a repair depot.
Oct 20, 2013 | VOX Amplification Vox VT30 Valvetronix...
Vox vt120+ cutting out and then coming back on. even when the jack lead is not in the jack input. the fuses all seem ok.
i live in mexico and musics stores here sucks I'm an engineer and y started experimenting i think its an IC the TAS5615 im about to order it but does anyone know for sure what it could be??
Sep 28, 2011 | VOX Amplification Vox VT20+ Valvetronix...
Charge battery, ride bike for about 30 to 45
5-6 years old is actually pretty old for a motorcycle battery. I would try replacing the battery first, then if you still have the problem, it is probably the voltage regulator. Honda is known for having very reliable bikes, with crappy voltage regulators in them. Yamaha's are the same there as well. I had the same problem with my Yamaha VMAX and by changing the regulator, I have not had another problem with it. You can find them on Ebay for around 50 bucks.
Sep 19, 2009 | 1990 Honda VT 1100 C Shadow
The input 3 has been turned off, how do i turn it back on?
it can be turned on and off in the menu. under parental control. you may need a code to turn this on or off.
Dec 27, 2008 | Mitsubishi VS-50705 50" Rear Projection...
389 people viewed this question
 Grubhead
Grubhead
