Question about Ovens
Yesterday I cleaned my inside glass of my cooker (moffat94971100) The sealant popped and I have a loose glass. I have found sealant however how do I get the door off and weigh down the glass is there any instructions I can follow Please I need to cook my Christmas dinner!. Regards Marisa.
    Scholar:
  • 62 Answers
Hi.
Normally there is a clip on both door hinges to allow easy door removal.
Once door is removed place on a towel on a flat surface. You will find a couple of screws on the top of the door and possibly underneath. Unscrew these and the two halves of the door should come appart. The inner glass is held in place with high temperatute oven sealant. You will need to thoroughly scrape the old sealant from inside inner door and on glass.
Apply sealant bead to inner door (but not too close to the edge) and then gently lower the cleaned glass on to the sealant. Press down gently. Now the sealant must have 24hrs to completely set so place a towel over the glass and place some heavy objects on the towel. House bricks are good if you have any.
Once dry you can then screw both door panels together and refit oven door.
Regards
Aardvark Repairs
Posted on Nov 16, 2009
Testimonial: "Thank you for your words of wisdom!! Regards Marisa xxx"
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
I have firenze electric cooker in my rental flat, but there's no instruction manual, and I can't get the oven to work - can you help?
How do you clean the inside of the two glass doors in the oven. There are no screws.
Aug 20, 2011 | Ovens
How do I get the inside glass panel back onto the door?
You will find sets of screws ether on the outside edge of the door OR on the inside panel. You can NOT! use any glue to "seal" the Glass this will make everything smell like the sealant you picked to use. your door was probably used as a resting spot for something heavy and caused the doors skin to be bent OR when you Cleaned the oven with the clean feature it caused the door to warp. Your option is to get a replacement part to fix the problem you can stop by any appliance parts shop and ask them what the best thing to do is and/or buy the part there you can "pull the door" off the hinges by lifting the door straight up at you and take the part to the stop for help and or replacement
Feb 10, 2010 | Zanussi ZBF360 Electric Single Oven
After some serious cleaning the inside glass has fallen out. NEFF
It will not be tape as this could catch fire, it is a very high melting point sealant that is used to secure the glass in place.
You can find it for sale on the internet, look under sealants
Please rate my solution.
Thanks.
Nov 20, 2009 | Neff U1721 Double circotherm Electric Oven
I need to clean between glass plate and oven door on my Zanussi electric cooker. I have drips where I've wiped the door over, also there is dust in between. Model ZBF 360W, Serial 61705615, Prod. No....
The following worked on my zbf360x built in Zanussi.
First you need to remove the oven door. To do this open the door half way. On each hinge there are two small metal flaps. Lift both of these. Now with the door still half open pull hard on the door. You will find the hinges spring and if you release the pull now it will just spring back. When the hinges spring give an extra hard pull on one side and then the other each hinge should pop out.
Once you have the door off just remove the small screws on the bottom of the door to allow it to hinge open and clean the inside glass.
Hope this helps,
B4M
Sep 29, 2009 | Ovens
The inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Jun 27, 2009 | Ovens
Zanussi Oven inside glass problem
Hi , i removed the door, and removed two small screws from the bottom of the door,you can the seperate the door into two pieces by slidng them apart,cleaned up the glass,bought a tube of heat resistant silicone and put some around the edges of the door and glass. I then replaced the glass,i left overnight to set and rebuilt the door.
Regards
Eddie
Jan 27, 2009 | Ovens
Hotpoint BD 31 Cooker door
The doors are easy to remove if you know how.!
Where the hinge enters the door itself, there is a little catch which can be turned with a flat screwdriver.
By doing so you prevent the hinge from moving into the door.
Do this on both sides.
Then allow the door to move towards the closed position.
About 3/4 of the way to closing, grasp the door at each side, firmly, and move it from side to side gently.
The hinges will begin to dislodge from the oven frame.
The door will be free to remove and be worked on.
The sealant which holds the glass door to the hinges, needs to be a silicone that is heat resistent.
Silcoset 158 Silicone Adhesive Sealant in a 75ml tube has done the job for me - other brands are available online - but make sure they are heat resistent to 300C
Jul 24, 2008 | Ovens
Cooker
HI THERE SKI IS THE GLASS DOOR PANEL THE INSIDE DOOR GLASS OR THE OUTER DOOR GLASS PANEL AND IS IT THE MAIN OR TOP OVEN.
THE GLASS PANELS INTERNALLY ARE HEAT BONDED IN THE FACTORY AND CANNOT BE REPAIRED YOU WILL NEED A NEW DOOR GLASS.
IF INTERNAL ONE COME AWAY THEN U WILL HAVE TO HAVE A COMPLETE INNER PANEL.
Feb 13, 2008 | Ovens
Ovens Logo
233 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
