Question about NorStar T7316E Corded Phone
My buttons designated to other rooms are not working when I try to transfer a call
  • 52 Answers
Press feature 0 this is button enquire this will tell you what is assigned to the keys you press on your phone and if the key is not the local you want then press feature * 1 or 2 one of these is for internal dial locals try both then press the key you want for that local then type in the local. hope this helps
Posted on Dec 21, 2009
Can not transfer designs from computer to mc10001. Error reading "can not be registered".
Are you using a Null-Modem cable to connect the computer to the machine? With the Futura I owned it would only work with my version of Windows by downloading a patch from Singer web site.
My machine "saves" the last 10 patterns, at some point I have to delete the saved patterns to make room for transferring another pattern. Also, if the pattern is too large the machine will not transfer it. Try reducing the size.
Good Luck!
Feb 22, 2014 | Singer CE-200 Quantum Futura Computerized...
2002 Chevy K2500 6.6L Push button 4 wheel drive. All lights on buttons are lit up. Service 4 wheel drive is on dash. What would I need to check?
check receiver at transfer case connection get nasty clean contacts
also check to make sure transfer case is working as designed/also check for ground
Dec 19, 2013 | Cars & Trucks
Can you transfer your Dongle to a usb stick and use windows 7 for 3D software insted of windows XP?
I took a class a couple of days ago at my local Husqvarna Viking store and my dongle wasn't working so the lady asked if I could used the cable. I have a Designer Topaz 20 and it didn't have the correct port to use the cable but U did have another USB drive and we were able to transfer the embroidery design to that and it worked just fine. I spoke with the manager yesterday about the dongle issues I have had ans she said that I can use any USB drive as long as it isn't too big because the machine can't read a drive bigger that 8GM. She says if you have more than that it take a really long time for the embroidery patterns to load. I hope that helps.
On a side note, I really wish this site didn't categorize Husqvarna Viking Products under "Floppy Drives". Yes, our embroidery machines are computers but it's not likely that the techy folks looking in the floppy drives category can even help us.
Hey, Fixya can we have a Husqvarna Viking category for sewing & embroidery machines?
Nov 21, 2013 | Husqvarna Viking Designer 1 Embroidery Arm...
The batteries ran out on our designers choice ceiling fan...now wont work. how do i make it work?
replace batteries. While holding the light button, turn the wall switch go and off one or two times. You should hear a slight beep and the remote reacquaints itself to that receiver.
Jul 22, 2011 | Hunter Designer's Choice 5-Switchblades Lg...
We have a Panasonic KX-T7730 in our office but it cannot transfer a call to a designated location.
If you are using a DSS button(direct station select button) to do the transfer ,verify that the button is programmed for the correct station by pressing the button when you are not trying to do a transfer, if the button does not ring the desired station you can do the transfer manually by pressing transfer button while on the call followed by the station number dialed using the dial pad. If the DSS button is correct, then try making the transfer while on a call by pressing the DSS button then hanging up(in this method do not use transfer button)
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
Designed in 4d embriodery extra but my viking designer one wont recognize it.
You haven't given us much information to go on, but try these things. Open your design in 4D and be sure to click the Centre button, then the Apply button then re-save the design. When you take the design to your machine make sure you select a hoop that is the right size for the design. What machine are you using? What method are you using to transfer the design to the machine? What message are you getting on the sewing machine's screen? Write back if the previous suggestions do not solve your problem.
Nov 15, 2010 | Husqvarna Designer I
I switched my phone to another outlet in another room. I changed all the extensions to match the phone and the voicemail will not work. How do it program the voicemail button on my phone?
What happens when you dial 500? If that happens to be your VM access code, then try PROGRAM button and dial the following 90+500 STORE for 2-way record 91+500 (#ext optional) STORE for 2-way transfer to a mailbox, and 94+500 STORE for VM Transfer.
At the minimum you need VMT. I give the customer all 3 buttons.
Carl
Aug 30, 2010 | Panasonic KX-T7633 Corded Phone
How do I switch from my handset to the base speaker?
On the bottom right side of the handset is a button that says speaker. It will not transfer to the base station but does allow for anyone in the same room to hear the phone call or message as it acts as a speaker phone.
Nov 16, 2008 | Uniden 5.8GHz Dual Cordless Phone
Gigabeat room fails to recognize my Gigabeat
It seems to be a permissions thing. When you launch Gigabeat Room, right click and choose "Run as Administrator". The Gigabeat button is then activated in the room interface.
Oct 30, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
NorStar T7316E Corded Phone Logo
41 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
