Question about Sony BRAVIA KDL-52XBR6 LCD TV
Sony Bravia KDL-52XBR9 wont turn back on red led flashes unless I uplug and plug back in. Did firmware upgrade to newest aa0143pn, still happening.
  • Anonymous May 13, 2015
    I know this is an old thread, but it still is viewable. Unfortunately, Ivanov has posted an error code list from a direct view or projection television, and does not apply to an LCD TV. Most XBR9 models wind up with a 10 blink error, and could be either the BU (Main) board, or the panel.
    President:
  • 787 Answers
There is a error in TV.Count how many times blinking the red light.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board. GA_googleCreateDomIframe('google_ads_div_TL-IMU-Article' ,'TL-IMU-Article');
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" boards
Posted on Nov 16, 2009
Testimonial: "I also bought the Sony KDL-52xbr9 mine did the same thing with six blinks. I sent it back to to store. "
  • Cu Vo
    Cu Vo Jul 12, 2015
    where is the D board? ( power supply board?back light board? or video audio board? there is no indicated "D" board...but D3N board, G7N board, and D4N board are available. would you please be more specific, thank you. quangvo11@gmail.com
I have get pro blame in me led 3d sony model no KDL 46W904A my tv is 8 times red blinking i have get this problem after some upgrade specification.
Posted on Nov 17, 2013
When i turn on my tv it shows the bravia sign on then the pictur blacks out
Corrupted firmware. A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Mar 29, 2016 | Sony Bravia KDL-52XBR9
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
My TV does not power up,Sony KDL-52XBR9,it tries to trigger the relay on power supply board G7N 4 times(RY6101) then it turn to blinking red LED 10 times per cycle.Is it power supply fail?which part?
Sounds like main board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 12, 2015 | Sony KDL-52XBR9 52 in. LCD HDTV
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
Sony Bravia KDL-60EX700 BAL Board / Flashing Green Amber
It sounds to be a firmware trouble. Will be best to contact the authorized service center for Sony, rather than trying to do it by yourself, as it is a very skilled work, need both concentration and previous experience. google.com/+GopakumarGopalan
Nov 24, 2013 | Sony Bravia Kdl - 60Ex700 60 inch 1080P...
Sony Bravia KDL-46V3000 turns off with blinking front light.
Sounds like the power supply may be failing. Count the beeps next time, that will give you the error code.
Jun 18, 2017 | Sony BRAVIA KDL-46V3000 Television
Sony Bravia KDL-46Z4100 Standby light flashing 13 times
This sounds like a power source problem! (faulty transformer) I would pack it up and take it back for a new one!
This is a problem you can not fix yourself unless your a pro!
Please rate my response!
Jan 15, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony KDL-40S2000 Picure Disappearing
hello, Check for trapped wires under earth of G2 board (top right).
Jan 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Picture Disappeariing
How many flashes are happening? If its 4 then maybe a bad panel.
Open Questions:
See all Sony BRAVIA KDL-52XBR6 LCD TV Questions
Sony BRAVIA KDL-52XBR6 LCD TV Logo
3,071 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
