Question about Dell E173FP 17" LCD Monitor
I have a dell monitor that the power light is on but yet the screen is blank? Changed both vga cable & power with no effect?
  • 115 Answers
Pls check that the your system is working or hang on the blank screen .For system check pls press the Num lock button on your keyboard its on/off or not.If your keyboard Num lock button is on/off then Problem with your Monitor might be might be EHT is faulty its better call vendor for repair.If system hanged on blank screen then problem with your RAM OR Hard disk or Operating system.
For Hard disk pls remove the power cable from Hard disk and on the system if not resolve then
Go for RAM,remove the RAM chip and re-installed another goods RAM ano on the system, If still blank screen then Problem with Operating System .Get it re-installed Operating system
Posted on Nov 16, 2009
Blue light on with blank screen dell SE198WFP monitor
It depends on what type of connection you are using. If you are using a VGA (analog) cable then you need to select that mode on your monitor menu. If you are using a DVI (digital) cable then you need to choose that mode on you monitor menu.
Nov 24, 2013 | Dell SE198WFP LCD Monitor
Today I received a faulty Monitor Dell E773c, the problem is that the Monitor get On and the power LED is Green and after remove VGA Cable from CPU it get Orange, But no Display (The Screen is Blank)
To get monitor work for you, you should connect the VGA cable to CPU. When you remove the VGA cable, monitor has got nothing to display so it goes in stand by mode with orange LED on.
Sep 15, 2013 | Dell Computers & Internet
Green power light keeps blinking and screen is blank
Then you should check the connection to the system unit and make sure it is fitted in well...other wise you have to check your VGA card or monitor cable.
Aug 02, 2010 | Dell E153FP 15" LCD Monitor
My monitor is blank it just keeps saying self check its a dell flat screen
If it shows "Self test feature check" the cable (VGA / DVi ) is unlplugged on the computer/ tower. Check the cables it may be loose. If not, try replacing the VGA/DVi cables. The LCD is good since it was able to display the self test feature check.
Hope this helps.
Mar 24, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
LCD Monitor Blank/Non-Responsive - Dell E173FPC
Next thing I would check is the VGA cable between PC and monitor.
Make sure is in at both ends and if possible try another one.
Do the Dell Menus come up with no VGA cable plugged in? Is the light amber? Flashing or static?
Mar 18, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Blinking power light on desk top monitor
-Check to see if your VGA cable(the cable from your monitor to your PC) is properly connected.
if not
-unplug your PC
-remove all devices connect to it(make you remember where each component id connected)
-remove the cover
-unscrew the Graphic Card
-clean the contacts with pencil eraser
-reseat the Graphic card(make sure its is properly seated
-screw it in place
-put the cover back
-plug your pc
if this also fails
-you might have a defective graphic card
^_^
Jul 31, 2008 | Dell Dimension 2400 PC Desktop
No power dell 1900fp silver blank screen power ??? help!!
try swapping the computer power cable and don't connect the vga cable with the system. if you get a power on self test displayed it makes sure that the monitor is fine. if nothing is displayed you can take it for repairs or else call 1-800-624-9896 its Dell technical support number or log on to support.dell.com
Jun 03, 2008 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Dell E173FP 17" LCD Monitor Logo
153 people viewed this question
Alun Cox
