Question about Sony Handycam HDR-HC3 HDV Digital Camcorder
Hdr-hc7 c:31:22 re-insert the cassete
When I insert the cassete in my hdr-hc7 I get this message: c:31:22 re-insert the cassete
Sony Handycam HDR-XR150 - Cannot access data in hard drive. Visible in windows as removable drive E but error message Please insert a disk into drive E: E:31.00 message blinking continuously. Please help....
hi i format my handycam hdr-xr150e(sony) hdd then i see e:31:00 then i insert memory stick and do wht you help(1- Place the memory stick 2- Go to "Home" -> "Manage Media" (or something like that) -> And select the option to change to the memory stick, instead of HD.) now i can record but in top of screen the e:31:00 not removed
Jan 19, 2011 | Sony Handycam HDR-XR520 High Definition...
I insert ink cassete into it"s selphy cp780 photo
Go to section on Error Messages at page 32 of the User Guide found at:
http://gdlp01.c-wss.com/gds/0/0300002060/02/SELPHYCP780_PUG_EN_03.pdf
It will tell you to remove and reinstall the ink cassette. Try this and make sure you install correctly as per instructions on page 11 of the User Guide.
If this does not resolve the problem, do a complete power down of the printer. Turn off and unplug from the power supply. Lets rest fro a few minutes and then plug back in to the power supply and if necessary turn on power. This should allow your printer to reset and hopefully recognize that a new ink cassette has been installed.
Trust this helps. Please vote. :)
Dec 17, 2010 | Canon Office Equipment & Supplies
Cassete not getting inserted.[message comes as remove cassete]
Does this happen with all cassets???
If So then....
1. try using a head cleaner casset.
2. connect the cam to your p.c. and check it for viruses.
Nov 06, 2010 | Canon ZR85 Mini DV Digital Camcorder
Casset will not load and I get the error message C32:11
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 27, 2010 | Sony Handycam HDR-HC7 Mini DV Digital...
Hello...i m using a sony DCR-HC48E....from 2 yaers....very good condition still...not much used even.... Oneday i just ejected its cassete in a proper manner...and than afterwards i was no way able to...
Your continual use of multiple full stops makes it difficult to comprehend your query - as I understand it, you have broken your camcorder. Your choices are to get it repaired or to replace it. BTW, demanding help 'immediately' is both impolite and uncouth - we deserve to be treated with respect.
May 05, 2017 | Sony DCR-HC18E Mini DV Digital Camcorder
I get a error code 30:23 on my HDR HC3 and it won't play or
Sony is pretty secretive about the :23 code. It can't be found anywhere. Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 120 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
Nov 12, 2009 | Sony Handycam HDR-HC3 HDV Digital...
REINSERT THE CASSEETE
Me also getting the same problem.. but some times it is getting okk...  what i m doing is, put the casset while pushing the cassete hold little bit down.. i think it is due to the improper position of the cassete holder...
Jul 20, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
Canon ZR60 Mini DV Digital, remove the cassete message
This is a tape transport problem and is expensive to fix. Unless you know a cheap tech, it's time for a new one. Be patient loading and unloading tapes. This is usually what causes this problem. The Yellow warning sticker is REALLY important. Another important item is to always use the same brand of tape because switching tapes causes a gummy build-up the makes tapes get caught in the machine.
Videoteacher
Dec 08, 2007 | Canon ZR60 Mini DV Digital Camcorder
DHR- 1000
Recently repaired one of these with what appeared to be a power supply problem; found several defective capacitors on the drive board. The symptoms were similar to what you are seeing.
Aug 20, 2007 | Sony DHR-1000 DVHS VCR
Sony Handycam HDR-HC3 HDV Digital Camcorder Logo
303 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
