Question about Makita 18V 1/2"CRDLS Drill Kit
My 18v cordlass drill moter runs but will not
my makita 18v cordlass drill moter runs but will not drive the keylass chuck
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
Your selector slide for the gears may be broken. If it is broken you will have to replace the transmission unit cause they don't sell the individual parts. Or it could be that your selector slide is off a little, try shifting the selector into the different positions. If it is not locking you are missing the little retention spring that rides along the side of the selector. In this case all you need to replace is the spring. Any questions please post back.
Posted on Nov 16, 2009
Changing the chuck of a 6408 makita electric drill
Open the chuck and remove the screw inside the chuck (if fitted) the screw is left hand thread, fit the short end of the largest hex key that will fit into the chuck and tighten the chuck, put the drill into low gear and turn the clutch to the drill position, support the drill on a bench and strike the long end of the hex key with a firm blow (right hand thread) it may be neccessary to strike it more than once
Jan 30, 2013 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
How can i replace the keyless chuck on my makita
I answered that question already on another post, but if you need to know how to remove the chuck I have detailed instructions in the TIP SECTION on how to do this. Let me know if you need more help
Dec 31, 2011 | Dewalt Makita Bhp452 18v Lxt Lithiumion...
My Makita 3.0ah cordless drill does not drive anything when I put pressure on it. Would the clutch be worn and if so is it easy to repair?
Clutch is part of the transmission assy - yes it is about the only thing that it can be causing your issue. It is a fairly inexpensive and easy fix on Makita - the worst part is removing the chuck.
Jun 25, 2010 | Makita 18V 1/2"CRDLS Drill Kit
How to remove chuck on makita bdf452
the chuck should open all the way then look down the old one attached to the drill there should be a screw near the end undo the screw and then it should come off :)
Mar 23, 2010 | Makita BDF452HW Factory Reconditioned 18V...
Keyless chuck is stuck with bit inside I can't turn it counter clockwise to unlock I have a Makita 6349d drill
Try two channel lock pliers.
Hold the bit close the the base with one.
Take the other (cloth comes in handy here to prevent marring) and turn the chuck counter clockwise to release.
Alternative (little WD40 on the chuck)
One channel lock plier hold the chuck and put the drill in reverse.
The WD40 should allow the chuck to release easier.
Nov 10, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
My chuck is broke , on my 18v makita cordless drill , how do i fix it
Put the chuck key on and strike it with a hammer counter clockwise. the chuck key must be properly seated in the hole. Once the chuck is brokrn free, you can unscrew it my hand. Buy a new chuck an screw it in olace and againm strike the key but no as hard clockwise. It will self tighten more as it is used, Good Luck-Ned-
Sep 17, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Change the chuck on a makita DA39DA coredlesss right angle drill
look inside the chuck for a screw. it will be a left handed screw.once you get the screw out put the chuck in a vice . you will need to squeeze it very tight. then put the drill in reverse and pull the trigger.if i wont come off you will need to hit the chuck with a hammer while you are holding the trigger.
Aug 20, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Removing the drill bit from Makita bdf452.
try hitting the chuck with an hide mallet in the undo direction, it just needs shocking, to rease it
Feb 12, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Chuck change
After removing the screw and inserting the allen wrench shift the drill to the LOW position and turn the clutch to the drill only position. Use an allen wrench about the size of the chuck capacity so that it will not flex when hitting it with a mallet. Sometimes they are stubborn because of the torque but this should work. Put the allen wrench at about a 30deg angle and hit the wrench. I support the chuck on a workbench or a block of wood will do fine. The chuck has standard threads.
May 10, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Chuck won't tighten
The chuck is held onto the drive shaft via screw located inside the chuck. The screw has reverse threads and sometimes the screw gets loose restrictinhg the chuck tightening. Turn the chuck to loosen and tighten the screw as though you were removing a normal screw. Good luck
Feb 19, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 18V 1/2"CRDLS Drill Kit Logo
128 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
