Question about GE Zoneline AZ38H12DAD Split System Air Conditioner
I have an airconditioner a Kelvinator KSR20C Split system
I have an airconditioner a Kelvinator KSR20C Model. Recently I heard a strange noise coming from the airconditioner inside the house when it was running. I went outside and the fan wasn't working and the compressor was working, I could feel heat coming from the airconditioner case too. I am wondering what is wrong with it??
Not a solution but just wanna ask Dave how to fix this and is it worth fixing?
Posted on Nov 30, 2012
  • 534 Answers
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Posted on Nov 17, 2009
Where can I buy a regas kit for my split unit airconditioner I live on the Gold Coast
I've never heard of a regas kit for a split a/c system. You need a declaimer, a vacuum pump, the designated refrigerant, gauges, and a digital scale. Evacuate the system, when system holds a vacuum, look up amount of refrigerant and type from mfg. tag on unit of spec book. Add specified amout of refrigerant and your done. If noy familiar with pressure on gauges you can use an amp meter to ensure unit is not over charged or has a restriction which would cause higher discharge pressure and therefore high amperage. Best to call a tech. Cheaper and safer.,
Jan 01, 2015 | Sanyo 33,000 Btu Ductless Airconditioner
Hi, i have kelvinator split system in my house.but...
Sounds like a clogged drain pan. You will need to have the unit professionally cleaned.
Hope this helps I take the time to answer your question so please rate me
May 19, 2010 | GE Zoneline AZ38H12DAD Split System Air...
Remot control not working for this unit
change batterys if not working contact tech support from kelvinator
Feb 26, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Delonghi PAC S1000 Split Airconditioner
hello you will need to pump system down and disconnect flare nut or decant gas and then undo flare nutsthis is the only way to remove unit
Jan 10, 2009 | Heating & Cooling
Strange sound coming from walkie talkie, strange beeping
Most Motorola radios give a beep-beep when the batteries are low and need changing. Make sure to use a good brand of battery. One other thing to check for is leaking batteries, the crud with cut down on performance.
Oct 20, 2008 | Motorola Walkie Talkie 2-Way Radio
Kelvinator split system a/cond
An air handler comes with a low, medium, and high speed wire taps and can only be set through these taps.
Oct 16, 2008 | Heating & Cooling
KELVINATOR KSR20C
One might think so, YES! look on one of the door panels that you can remove! Thank-you-very-much!
Aug 02, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Loud whistle noise kelvinator split KSR25F-01
It may be the small vent fan motor on the inside if the control panel. When the noise begins remove the panel and you may be able to catch it in the act.
Dec 27, 2007 | Carrier 36KCARMS Air Conditioner
GE Zoneline AZ38H12DAD Split System Air Conditioner Logo
541 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
