Question about Hotpoint Dishwashers
Does not feed any water just sounds like its doing something but not
    Scholar:
  • 62 Answers
Without the model number i cannot tell what type of hotpoint dishwasher it is. If it still makes a noise when the door is open then the anti flood device has been set due to water ingress to the bottom of the dishwasher.
If you disconnect the dishwasher from the mains and after pulling it out, gently tip it back (you will need some towels at the back of the appliance), you may see water pouring out of the bottom.
If this is the case and it then works then you will need to call a engineer to locate the reason for the water ingress.
Regards
Aardvark Repairs
Posted on Nov 16, 2009
How can I get code to go away? Code AB just came up in this older copier. It sounds like it's trying to catch paper, but can't. There doesn't seem to be a paper jam. It says anything with A is the mac
Use a little water on grab rollers to see if that helps. If it does use a scrubby to roughen same. This is if the grab or feed rollers have become polished from use and lost the gripping surface. If the issue is after the feed rollers a motor or belt may be the problem inside and after the first feed roller.
Sep 05, 2014 | Kyocera Mita Office Equipment & Supplies
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
Document won't print, but it sounds like it is
Make sure the paper feed is full of fresh paper. Print something, and watch where the paper feeds into the machine. If the feed roller actuates and tries to pickup the paper but doesn't, you may need to clean the pickup roller with distilled water and a qtip. If it still doesn't pickup the paper, repair it under warranty with canon or replace it if not under warranty.
Sep 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Kenmore Elite Refrigerator water dispenser mechanism will not turn off. I turned off the water from the valve under my sink that is connected to the water line, however, I can hear the dispenser still...
most panels have 2 screws under the edge . remoce them and the panel will come off . there must be a bad sw or something caught in sw .. sw do go bad .. mm hope this helped feed back pls .
Feb 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My printer keeps jamming
1. Check any small pieces of paper, sometimes the back will come off
2. If it feeds sometimes but dog ears(bends the corner), there more likely something caught inside, use can air to blow inside lower feed rollers
3. If it does not feed or feeds and jams then take dish soap and water and apply it to a rag and clean any roller you can see make sure you let it dry before trying to print ONLY dish soap and water.
4. If this fails then there is something wrong with the feed mechanism example clutch or spring
Sep 20, 2009 | Canon PIXMA MX310 All-In-One Printer
American Standard kitchen fawcett
It could be air if you recently had the water off at the main and let the pipes drain, but this would go away after a short while. It is most likely either a feed line from the wall to the faucet flexing when the pressure and hitting something under the sink or a water line in the wall that may have not been strapped properly to the stud when installed. They bounce around sometimes if not secured. Hopefully the feed line as the second is a bit more work to correct.
Good Luck
Nov 29, 2008 | Plumbing
Paper feeds into printer uneven
check for anything obstructing the path of the paper..usually something very tiny! and clean the rollers with toothbrush & water.
Nov 29, 2008 | Lexmark X2500 All-In-One Printer
Need to get the back off
The back of this machine IS NOT designed to be removed. When you say you have to fix the water feeds, what are you referring to ? Replacing the water valve assy. or something else ? Do you need breakdown instructions ?
Jan 12, 2008 | Roper RAS8445KQ Top Load Washer
Dishwashers Logo
181 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
