Question about HP Pavilion dv4000 Notebook
Windows xp sp3 installation errors with pavilion dv4000
Hi i am tryin to install windows xp sp3 onto hp pavilion dv4000 after the disk formatting and copying of files, following the restart the xp logo flashes and i get a black screen and nothing else can anyone help its urgent
  • 51 Answers
Try to reload the again if it persist then using a new window xp sp3 disk.
Posted on Nov 16, 2009
    Problem Solver:
  • 10 Answers
I think format is not complete so try ubcd or any other formatting software to completely erase the files and finally install xp reach me at http://xperrorsolutions.blogspot.com
Posted on Nov 17, 2009
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
Please help how to format pavilion dv4000 because effected virus. I hope you will help me, thank you. Paul
Before formatting or reinstalling windows try downloading ESET smart security 30 day trial and uninstalling your current antivirus.
http://www.eset.com/.
If you can install it do it. This will surely clean up your computer, if you see everything is fine then there will be no need to reinstall windows.
Remember that a complete windows install will make you loose everything!
From the Windows XP desktop, click Start , All Programs , and then one of the following options:
The following options are for HP computers. Compaq computers will have similar options (for example, Compaq Tools).
1. HP Tools , and then HP PC System Recovery .
2.Hewlett-Packard , hp pavilion pc tools , and hp pc system recovery .
3.PC Help & Tools , and then HP PC System Recovery .
should be ok.
Aug 02, 2010 | HP 419320-001 - HP Pavilion dv4000 Series...
Where do i find a boot up disk for my hp pavilion running xp? currently the unit starts to boot and then restarts.
Trying to get a bootable XP CD is difficult if not impossible to purchase. Therefore you might want to create one.
I just recently created a bootable XP CD since I was building a new computer and wanted to be able to boot from a CD.
The following URL is a blog I found that helped me create my bootable CD
Create Bootable XP CD
You'll need an XP CD in order to copy the files to your hard disk and to extract the boot image from.
I already had an XP SP3 disk and didn't need to perform the "merging" like the link above does. I did find and download iso buster (freeware) in order to extract the microsoft boot image file.
I used the Roxio steps to create my CD. My version of Roxio was slightly different so the instructions were not 100% correct but I was able to figure things out.
If you successfully create your bootable XP CD you will still need your license key to install just as if it came right from the factory
Oct 08, 2009 | HP Refurbished PAVILION ZT1180 15 SXGA+...
How to install xp in HP Pavilion dv6 1030 us Laptop and how to repartition my C: drive especially I have still 150 GB free space in C drive Please help me in this case Thanks in advance.
get a winxp installer CD, you can repartition your drive on the first part of the winxp installation process. Prepare your drivers for your machine especially the network and USB drivers which you will need to copy and transfer files firstly.
If u meant of installing an additional OS like winxp to your extra space, you need a boot loader to switch between OSes.hope this helps
Aug 17, 2009 | HP Pavilion dv6-1030us Notebook
Blue screen error
I see ..either teh installation didnt complete the loading of the files..or you didnt format the Hdd proper...try to reformat it in the NTFS normal mode...and change the installation cd ..cause in the proces there might have been a file it couldn't copy ..and skip it ...keep trying cause sometimes it does that ...if the server went fine ..this means that the HDD its ok ..and the problem is the installation disk ...with xp on ...
Aug 04, 2009 | HP Pavilion zd8000 Notebook
Winodws sytem 32 file not found
Have you got an Anti-Virus program installed , do you have an Anti-Spyware program installed
If not when you get this machine running again go to www.filehippo.com and download Avast and Spyware Blaster
To get it running go to
http://support.microsoft.com/kb/307545
Jul 01, 2009 | HP PAVILION DV4000 AND V4000 SERIES...
How to install windows xp in hp pavilion dv4-1125nr series???
You should install Windows XP that came with your computer with the recovery program that is built-in with an HP computer. The Windows that comes with your computer includes all the drivers and software needed specifically for an HP Laptop.
Here's a link to HP's website outlining all the ways to Recover your Laptop and reinstall your Windows XP Operating System back to factory default including how to create a set of your own Recovery Disks:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00608578&cc=us&lc=en&dlc=en
Feb 01, 2009 | HP Pavilion dv4000 Notebook
My system hp pavilion dv4000 cannot play out audio and picture from my dvd and window player files, no sound card foud
Have you try installing the driver for your pc?
the sound driver and the
DVD software need to be installed
Jun 24, 2008 | HP Pavilion dv4000 Notebook
Sound and audio devices problem
hi frind
u need to install your lapotop driver when install driver then sound come so install your motherboard driver cd in your lapotop
if u not have driver cd tell me your laptop model no so i can give u link to downlod driver
Apr 12, 2008 | HP Pavilion dv4000 Notebook
I am unable to reinstall my windows copy
Have you created the Recovery CD's? If so, put the recovery CD in the disc drive and restart your machine. Most notebooks start from CD first and then from hard drive. If not, you could change that in it's BIOS. (Press F10 at the moment you see the HP Invent logo).
When the disc boots it allows you to choose from multiple options. Choose the options that sounds like "Restore factory defaults" or something like it.
The D-partition is only used to create the disc and hold info. There is no software there to run for recovery.
I hope this helps, if you need more help just ask.
I work at a company who is an HP Partner so.
Greetings,
DarkNeogen
Jan 24, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
289 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
