Question about Hotpoint Aquarius WF000 Front Load Washer
Where is the filter to clean it
The machine is making banging noises. Someone said it may be that the filter needs cleaning. How do I access the filter to clean it?
    Scholar:
  • 62 Answers
Hi
most of these filters are located at the back of the appliance.
Make sure power is disconnected first!!!
Unscrew the plate at the bottom rear of the appliance.
You will see, on the right hand side, a black corrugated hose that connects from the bottom of the drum to the drain pump.
On the drum end there will be a big metal clamp that you can unscrew. Once lose the hose should easily come off the drum. Inside this hose you will find a filter that may be full of fluff.
Reassembe the hose and make sure you tighten the clamp properly otherwise it will come off and flood everywhere on your next wash.
Regards
Aardvark Repairs
Posted on Nov 16, 2009
My Pfaff 5.5 creative vision original machine will only sew a few stitches then starts making a bang noise. But when I take the bobbin case out it does run smoothly.
If you just had it cleaned, did they not check whether it functions properly? If so, take it back. Something is wrong and you can damage it further by continuing to try to use the machine.
Mar 05, 2016 | Sewing Machines
1. Loud banging 2. detergent not fully dispensing
is there something loose? and on the detergent, how much do you use each load?
Jan 05, 2014 | LG WM3470H TurboWash Series 4.0 cu. ft.
LG washine machine starts to makes noise when its starts to spin, how best can i be helped
Hi yawkentikron,
I believe there is something in the drain pump rubbing against the impeller, this needs to be cleaned out.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | LG Washing Machines
My machine is making a loud banging noise
These are the things that cause my machine to make a "banging" sound:
The machines with the horizontal/drop-in bobbin sometimes collect lint in the bobbin case.
Sewing fabric backed with a synthetic/foam/vinyl or adhesive.
Wrong size needle for the type of fabric being sewn.
Mar 13, 2010 | Sewing Machines
High pressure, and heater noise
I am not sure if you have solved this issue, or not, but if the PSI on the gauge is high then the problem may not be the heater. When you have the system turned on, and the PSI is reading higher than normal, just the flow of water coming out your return lines. If the flow is normal, like when you clean your filter, then see if you have a way to re-route the water so it bypasses the heater. If the PSI on gauge drops, then the issue is in the heater.
If the flow of water is slower than normal, with the PSI reading high, then you have a blockage somewhere in the system. It could be something simple like removing debris from skimmer and pump backets, to time to backwash, or clean, the filter.
If the flow of water is really hard and fast, with the PSI high as well, then you have too much water going through the system and need to slow it down.
Jun 27, 2009 | Pentair MiniMax 100 Aboveground 100,000...
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
Wash machine agitates but won't drain the water -- on any cycle choice. Machine makes noise like something is happening, but water remains.
Yes, the problem is the pump filter which is hidden behind the lower front panel. To access the filter, unscrew three screws at the bottom of the panel and carefully remove the lower front panel. Make sure to unplug the machine. With the panel removed you will see the pump filter. Get a bucket and some towels ready, because when you open the filter, you may get a gallon plus of water coming out. GE failed to put this in the use and care manual for the 6260. But low an behold, GE put an access door and explicit instructions on cleaning the pump filter in the updated 6400.
You may have burned out your washer pump. That is what happened to me. The machine would not drain or spin properly and so I kept pushing the blinking start/pause button to get it going again. Then it finally did not drain at all. I installed a new pump and with the cleaned filter, the machine worked like new. For some, simply cleaning the filter allows the pump to work properly. As the filter gets clogged the pump has to work harder and harder to pump out the water. When this happens the cycle times get extended . One symptom of a clogged filter is the final minute (spin cycle) takes much longer. Obviously this is a "design flaw" that GE "fixed" in the recent version of the 6260.
Jul 07, 2008 | GE WCVH6260FWW
Hotpoint Aquarius WF000 Front Load Washer Logo
177 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
