Question about HTC S620 Smartphone
Manual network selection
How will i select the network manually on a windows smart phone
  • 813 Answers
1. Press the Talk button to bring up the call history/dialpad. Now press Menu (at the bottom right hand corner) and select Options. Go to Network tab and select Manual under Network Selection.
2. Tap Start >> Settings. Tap on Phone option in Personal tab, go to Network tab and select Manual under Network selection.
Posted on Nov 16, 2009
How do I turn on an acer aspire wireless switch?
Sony's Sony Vaio laptop features built-in wireless LAN adapter that allows the computer to connect to any wireless access point. If you want to adjust the device's WiFi settings, you must use the proprietary software and hardware that comes preinstalled on the laptop and the Internet connection options that come with Windows. Once you have all of the correct settings enabled, you can have your laptop connected to a wireless access point without any additional applications.
Enabling Wi-Fi with Wireless LAN Switch b> Before you can connect to a wireless network or change any of your Wi-Fi settings, you must first enable the computer's Wi-Fi feature with the wireless LAN switch. This switch is located directly below the laptop's screen and is labeled "Wireless." Once you have located the switch, slide it into the "ON" position. b> Enable Wi-Fi in Vaio Smart Network b> Once Wi-Fi has been enabled with the wireless LAN switch, you must enable Wi-Fi using the laptop's proprietary wireless connection software, "Vaio Smart Network." To access this program, click the "Start" button in the computer's task bar and select the "All Programs" option. Select the "VAIO Smart Network" option to launch the program. Alternatively, you can click the VAIO Smart Network icon in the computer's task bar to launch the program. This icon is in the shape of a green button with two white arrows on it. Once in the application, click the switch to the right of the "Wi-Fi" heading to toggle it to the "ON" position. Windows Connect to a Network b> With Wi-Fi enabled, you must connect to the wireless network using the "Connect to a Network" feature that is a part of the Windows operating system. Click the network icon in the computer's task bar to bring up a list of the available wireless networks. This icon is in the shape of a computer and an Ethernet cable if you not connected to a network. If you are connected to a network, it is in the shape of signal bars. Select the desired wireless network from the menu that appears and select the "Connect" option. Enter the networks password if necessary and connect to the network. b> Network and Sharing Center b> If the wireless network that you want to connect to does not appear in the "Connect to a Network" window, you must connect to the network manually. Click the network icon in the computer's task bar and select the "Open Network and Sharing Center" option. Click the "Manage wireless networks" option, followed by the "Add" option. Click the "Manually create a network profile" option and type the network's information in the spaces provided. Place a checkmark next to the "Start this connection automatically" option and click the "Next" button to connect to the network.
b>
Feb 08, 2013 | Sony VAIO VGN-AR150G Notebook
Tip
Wireless Network issues. Validating identity and Certificate Errors in Windows...
At times after you have entered the correct password for the wireless network on your computer you are unable to connect to the wireless network and see the below mentioned errors:<br /><br /> <ul> <li>"Windows was unable to find a certificate to log you on to the network." </li> <li>"Validating identity" replacing the name of the wireless network. </li> <li>A pop-up window requesting for login credentials off the wireless connection. </li></ul><br />To avoid these error messages, you need to manually create or add a wireless network profile. Follow these steps to manually add a wireless network on Windows XP and Vista computers. <br /><br /><span>Manually add a wireless network on a Windows Vista computer:</span><br /><br /> <ol> <li>Click Start, and then select Network. </li> <li>Select Network and Sharing Center.</li> <li>Click Manage wireless networks.</li> <li>Click Add and select Manually create a network profile.</li> <li>Type the SSID, select the type of security and type the wireless password in the Security Key/Passphrase field. </li> <li>Select the Start this connection Automatically and Connect even if the network is not broadcasting check boxes. </li> <li>Click Next and close the window.</li> <li>Go to the Network and Sharing Center and select Manage network connections.</li> <li>Right click on Wireless network connection and then select Status. </li> <li>Click details and check the IPv4 address. </li> <li>If there is a valid IPv4 address, check if the computer can access the Internet wireless.</li></ol><br /><span>Manually add a wireless network on a Windows XP computer </span><br /><br />Note: The following steps are for a wireless network that has WEP security.<br /><br /> <ol> <li>Click Start, then select Control Panel.</li> <li>In the left pane, select Switch to Classic view.</li> <li>Click Network Connections.</li> <li>Right click Wireless Network Connections and select Properties.</li> <li>Click on the Wireless Networks tab.</li> <li>Click the Add button.</li> <li>Enter the name of the wireless network (SSID). </li> <li>Set the encryption type to WEP.</li> <li>Clear the key is provided for me automatically check box.</li> <li>Enter the network key and confirm it. Note: Make sure that "This is a computer-to-computer (ad-hoc) network" is not selected. Click OK, and then click OK again.<br /></li> <li>Right-click Wireless Network Connections and select Status. </li> <li>Click on the Support tab and check if there is a valid IP address.</li> <li>Check if the computer can access the Internet wirelessly.</li></ol> <br /><br />If you still receive the same error message after manually adding a wireless network on a Windows XP computer, ensure that IEEE 802.1x authentication of the wireless adapter is disabled.<br /><br /><span>To disable IEEE 802.1x authentication: </span><br /><br /> <ol> <li>Click Start, then select Run.</li> <li>In the Run dialog box type ncpa.cpl and then click OK.</li> <li>Right-click the Wireless network connections icon, and then select Properties. </li> <li>Click the Wireless network tab.</li> <li>Click the Properties button beside Remove. </li> <li>Click the Authentication tab, and clear the Enable IEEE 802.1x authentication for this network check box.</li> <li>Click OK to update the settings.</li></ol>This TIP applies to: <br /><br /><span>All Windows XP and Vista computers that display the listed error messages when attempting to connect to wireless network of routers (specifically NETGEAR).</span>
on Apr 28, 2011 | Computers & Internet
Will not connect to wifi network
Hope this helps
Nov 11, 2012 | Sony VAIO VGN-N325E Notebook
How to activate gprs and mms settings of samsung GT-S3353
How to configure manually Samsung GT-S3353 Chat GPRS, MMS, Wi-Fi and browser settings
  • On your phone 'Menu' go to 'Settings'
  • Select 'Network'
  • On Network, select 'Connections'
  • You will be prompted by 'The menu manages connection profile. Incorrect configuration will prevent online connection.' message, just click 'Yes' to Continue.
  • On 'Connections' you can see all the list of Access points including Wi-Fi hotspots you connected.
  • Example: myGlobe Connect, myGlobe MMS, myGlobe Inet, Smart Internet, Sun GPRS, Smart MMS and FreePublic Wifi etc.
  • You can select which access point you want to edit manually, just point and click 'Options' then 'Edit'
  • If you want to create new access point for your network you can do it manually with your Samsung GT-S3353 Chat, just click 'Options' then select 'Create'
Apr 25, 2012 | Samsung S3650 Corby / S3650 Genio Touch...
How to open gprs
By the way, what is the brand of your phone so that I would be able to give you the instructions.
Or I would assume that you are using smart phones.
Smart phones use GPRS to connect to your mobile carrier and allow you to roam. GPRS is the wireless network that allows calls to be made and voice mail messages to be received, and it carries your voice over the airwaves. There are times when you may need to open (turn on) your GPRS if it becomes closed (or turned off). When your GPRS is open, you can select a network to connect to.
1.Press down on the "Menu" button from the home screen of the data device.
2.Click the "Settings" or "Tools" icon for phone configurations.
3.Scroll to and select "Phone Settings" or "Network Settings."
4.Click the options for "Airplane Mode" or "Wireless Mode" (based on your smart phone manufacturer).
5.Select the option for "On" or click the "On Checkbox" to open up your GPRS.
Open GPRS for Network Selection
1.Press down on the "Menu" button from the home screen of the smart phone.
2.Click the icon for "Settings" and then select the option for "Call Settings."
3.Click or press on the icon for "Network Selection" to open the menu and then click on "Default Setup" to access the network configuration options.
4.Scroll to and select "Manual" to change the phone from automatically selecting a network.
5.Select the desired network and make sure that the phone connects. Test the phone by making a call with the new network.
Open GPRS for Voice Mail
2.Click the icon for "Settings" and then click the icon for "Messaging."
3.Scroll to and click the option for "Messages Settings."
4.Click the icon for "Voicemail."
5Make sure that the option for "Voicemail" is set to "On" to receive voice mail messages..
Sep 06, 2011 | Computers & Internet
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
What is network selection? which is better automatic a or b ?
Most GSM handsets offer a choice to select a new network, automatically or manually. The default setting, in most cases, is automatic, which instructs your mobile to automatically connect to the strongest network signal available. As you move, the handset will continually monitor the available networks, and keep you connected to the strongest one. In a manual network selection setting, your mobile handset will detect if there is more than one network present and offer you a choice. If you then select one network, your mobile phone will remain connected to it regardless of the alternative networks available. You may prefer to remain connected to one network if it offers cheaper outgoing call charges. To manually select networks please refer to your mobile phone user manual for instructions. Your Jersey Telecom SIM card can store a list of your preferred roaming partners. If you have an automatic network selection setting, and there are two networks of equal strength available, the mobile phones will connect you to the one that is highest on your SIM card’s preferred list. The list can be edited by using the appropriate menu on your mobile phone. Check your mobile phone user manual for details.
don"t forget to say thank's
Mar 31, 2010 | Motorola Mobility RAZR V3m Cellular Phone
I cannot get my software to install and function
NOTE: QuickVerse Smart Tags will only work with Microsoft products that support the technology. (Your version of Microsoft Word must be 2002 or newer.)
during the installation of QuickVerse. However, if a Microsoft document was open during installation, you may have to walk through the following steps manually.
Phase 1 - Manually register the QV13SmartTags.dll file
  1. Download and extract this ZIP file to your desktop
  2. Windows XP: Right-Click and select Open
    Windows Vista: Right-Click and select Run as Administrator
Phase 2A - Turn ON Smart Tags in Microsoft Word 2007
  1. Start Microsoft Office Word 2007.
  2. Click the Microsoft Office Button, and then click Word Options.
  3. Click the Proofing tab, and then click AutoCorrect Options.
  4. Click the Smart Tags tab.
  5. Verify that the Label text with smart tags check box is selected and that your smart tag is both listed and selected in the Recognizers list.
Phase 2B - Turn ON Smart Tags in Microsoft Word 2002 or 2003
  1. Start Microsoft Office Word 2002 or Microsoft Office Word 2003.
  2. On the Tools menu, click AutoCorrect Options.
  3. Click the Smart Tags tab.
  4. Verify that the Label text with smart tags check box is selected and that your smart tag is both listed and selected in the Recognizers list.
click on this link directly for more troubleshooting
http://www.quickverse.com/shopfiles/Faq.asp?ID=41221
This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya.
Nov 28, 2009 | Findex QuickVerse Bible Suite 2008
Samsung sgh-e590 limited service
HI i have same problem with my samsung.
Sep 27, 2009 | Samsung E590 Unlocked GSM Phone
HTC S620 Smartphone Logo
162 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
