Question about Sony Playstation 3 (PS3) Console
Was on hd and wont go back to analog
Had the ps3 on a hd tv with hdmi cable and want to take it to ordinary none hd tv but the picture just goes blank. what do i do
    Problem Solver:
  • 5 Answers
Go to display settings and you must change the video output manually to 480 or less.
Posted on Nov 16, 2009
One of the most annoying aspects of the PS3 are its video settings. Take it up to the bedroom portable or round to a friend's house and there's a good chance that you won't be able to see anything on screen because your 'new' TV is running at a different resolution or using a different cable connection. And - because you can't see anything - you can't change it.
Until now. Shut down your PS3 then restart by pressing and holding the power button.This will reset your PS3 to its most basic 480p graphics mode so you'll be able to see enough to choose RGB SCART, component, HDMI or whatever from here.
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
My tv is not picking up any hdmi signals from my ps3 and xbox. whats wrong?
The first step for this issue is to try a hard reset. Hook up the PS3 with both the Analog cable and the HDMI, set the TV to the Composite (analog) Input that you have chosen. Then, while the PS3 is off (red light), press and hold your finger on the power button for approx. 10-15 seconds until it beeps again. This will reset the PS3. After it turns back on, go through the set up steps, and after, it may tell you it has detected an HDMI connection, say yes and switch the TV to the HDMI input you hooked it up to. Click on yes before the timer ends and you should be all good.
Jan 21, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
My ps3 was switced to hd and wont switch back to a av cable
You have to set it back to the regular cables the same way you did with the HDMI
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
Wesitinghouse 37" all of a sudden wont work with hdmi cables plugged in. only picture with component cables in. ps3 wont work individually either currently have it directly into cable source and everything...
Same problem I had... My problem was with any HD input from PS3 (only HD device I have), the PS3 was fine on other televisions so I determined that it must be a problem with the TV in question. I fixed this problem by unplugging the TV, letting it sit for about a minute and then plugging back in.
Apr 13, 2009 | Westinghouse LTV-37w2 HDTV
Cannot get my HDMI cable linked from my ps3 2 my hd tv
Try video settings on the playstation 3. Adjust it to reflect hdmi.
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
No picture or sound on ordinary TV after hooking up with HD TV
You system is still out-putting through the HDMI cable. Press & hold the "on" button after the system is already on, it should go back to regular factory settings & show up on your screen.
Dec 14, 2008 | Sony Playstation 3 (PS3) Console
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Sony Playstation 3 (PS3) Console Logo
126 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
