Question about Saws
HILTI WSJ110ET SERVICE MANUAL NEEDED - HOLDING TOOLS PART BROKEN. NEED TO REPLACE THE DAMAGED PART.
    Sniper:
  • 61 Answers
Send me an email and I will gladly email you a parts diagram. :)
paul@wysehire.gi
www.wysehire.gi
Posted on Dec 13, 2009
  • 2,176 Answers
Cant find that model number online I suggest calling them direct at 1-800-879-8000 and asking that a breakdown be sent to you as a PDF file.
Posted on Nov 17, 2009
What diameter are the bearings which he'd the tools in a hilti te72
Beware on an important point is that HILTI used on almost every point in high rpm tools special tolerance free bearings,the first difference first thing is you can be thinking " o thats not turning smooth " because you can feel the bearing (then its in a proper condition ONLY IF if you turn it and there is no tolerance to feel but its not feeling like a standard bearing a standard ballbearing will damage in a short time the tool, if there is something happens (and the working hours are reached, one good point is Buy allways a complete service wear parts set. do fill the oil level not over not to muchn or too less.
because of the special Turmopol oil lubrications there are cheaper equivalents to buy for the tool with enough lasting time for the second lifetime becase of the very high price of the first used oil. there are working hours on the tool calculated but one broken ring can become by an accidental thing then there is an special observation and mayby one component too change thing to replace can give an early repetition or another defect, do not use hydraulic oils because the oil is an special sinc free hydraulic because of the materials alloy internally make the oil in short time black because normal hydraulic has sink. Marketing technical chioce on patents that will be a reminder that you have bought the brand Hilti.
Down the picture in the website of electrotanya you can read the word PROCESSING be patient and wait until you can read GET MANUAL .
Elektrotanya for electronics experts
Oct 30, 2017 | Hilti Drills
How much oil put in hilti t15
Thats the most delicate question on fixya
45ml or 50ml hd20 or an other cheaper sae20-20 can also be used and also bought by Hilti
Be aware of all the secrets of the tight-toleranced parts and bearings by this brand . in case you will service this by yourself because its not comparable with other brands by using a consumables kit. because only change a few parts will not made a succesfully repair because of marketing technical developments because everything works very close accuratelly together by brand Hilti. the impact bold you will see perhaps optional see nothing but measure it on the seal can make a decision for the whole machine.
Hilti and Duss are both one of the best tools but have a complete service nessecary if there are the working hours on it.
HILTI TE15 Service Manual free download schematics eeprom repair info for...
Jan 27, 2016 | Hilti Drills
Puncture part has broken and need to replace it, not sure where to start and if special tools needed
Tube may be damaged and the support hole could be enlarged and will leak after you try to insert a new tube. Best you have it done by the factory service to avoid a warranty problem.
Sep 09, 2013 | Keurig Elite B40 Coffee Maker
How to calibrate a hilti pri 2 laser
There is no "calibration mode".
To check calibration set the tool on a fixed surface. turn it on. let it autolevel, then mark the wall with a pencil at a distance of 15- 20 feet. rotate the laser on its axis 90 degrees, and see if it self levels to the same line. if it does not, send it to hilti, you'll have it back in a week.
Nov 13, 2012 | Hilti Laser Level. Rotating Laser PRI 2...
Need Instructions to Disassemble TE 12 Hilti hammer Drill
I see you posted several symptons on the TE12, the logical area to check is "hilti.com" you should be able to download the parts breakdown and order all the related parts needed, If you have trouble finding that you can call them at the phone number listed on their site, I think it is 1-800-879-8000, but you might want to double check. They have customer service agents that are more than willing to help in your problem, If you need more assistance let me know.
Oct 27, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
I need brushes for hilti UH 650
to my knowledge you can't buy hilti parts. they want you to send it to a service center. i work in a tool repair shop and we can't get parts. i would go to a shop that repairs tools and have a number of brushes and try to find one that will match up.
Jul 31, 2010 | Hilti 284228 UH 650 Universal 1/2" Hammer...
Reprogramming 905 hilti hammerdrill
See if your brushes need changing. You can buy them online and do it yourself. Let me know if you need guidance. Please rate me
Jun 09, 2009 | Hilti Drills
Hilti te 10 switch problem
You may research your area for a Hilti service center / dealer or order your part directly from
www.hilti.com
or call (866) 445-8827
Good luck
Aduz
Mar 14, 2009 | Drills
Service light on
When the service light comes on in a normal Hilti all you need to do is replace the brushes,....however on a te-706 there are no brushes to replace, you will need to contact Hilti and have them service it.
Nov 14, 2008 | Drills
Saws Logo
611 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
