Question about LG RH188
LG RH188 HDD/DVD rec Spuriously starts REC, STOP, Keys don't work
LG RH188 DVD recorder > 2 years old
Suddenly started spuriously recording and/or stop. This occurs at various frequency (sometimes is Ok for 1/2 hour, ..., sometimes does continously).
Also found keys don't work (not sure when stopped becsuse never use) but remote works flawlessly.
Everything else seems to work OK too.
Seems similar problem to "Timeshift problem" above although timeshift doesn't seem to be a key function.
From service manual the key detection is done by 2 ADC inputs (keys change voltage). Both are affected. I have cleaned dust inside where I could get at but this didn't fix. Pressing keys generates the correct resistance. Haven't removed main board to get to the IO board and at the timer chip (as 2 inputs are affected unlikely to be a "contact" problem).
This seems a common failure to this product.
Has anyone found reason or a fix, or waht to look for ?
Could a return to factory setting fix this?
PS: I only have a RH197 manual, does anyone know where to get the 188 manual free?
Thanks for any help, willing to expriment to fix,...
SOURCE: LG DBRH197
Read the timer record troubleshooting suggestions - timer record will only start is the unit is turned off!
Posted on Aug 02, 2007
SOURCE: LG RH7796W DVD/HDD Recorder
The problem has fixed itself, thank you
Posted on Feb 27, 2008
SOURCE: transferring from timeshift buffer to hdd
When in timeshift, press record on the remote (every time you push "record" 30 minutes are added) and make sure the program you are recording is not macro protected. If your program has already finished rewind to the beginning of the program and push record the correct number of times to cover your program and then press stop on the remote. It should then be at the bottom of your hard drive list.
Posted on Dec 29, 2008
fieldy14
  • 456 Answers
SOURCE: lg dvd recorder dr275 initializing problems
replace dvd loader assy or mpeg pcb.
Posted on Jul 05, 2009
SOURCE: samsung dvd sh897m - can not use the timeshift
just a question of connecting the aerial cable from the dvd player direct to the sky box - now working.
Posted on Jan 04, 2010
Can i attach backup device to my lg HT356SD?
I would say yes, from what the manual says, the LG HT356SD has some Unique Features:
#1 Portable In : Listens to music from your portable device.
(MP3, Notebook, etc)
#2 USB Direct Recording : Records music from CD to your USB device.
Read the manual, on page 26 it will show you how to do it, I found it at www.theatresystem-manual.com under lg, or go directly to the link I provided.
http://www.theatresystem-manual.com/manuals/lg/LG_HT356SD.pdf
Recording to USB
1. Connect the USB device to the unit.
2. Select a DVD/ CD function by pressing
FUNCTION.
One track recording - You can record to USB after
playing the file you want.
All tracks recording - You can record to USB after
stop.
Program list recording - After showing the
programmed list, you can record it to USB.
3. Start the recording by pressing X REC.
4. To stop recording, press Z STOP.
Mar 18, 2014 | LG LHT854 Theater System
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
press
to select:
1~31= one time, or
DAILY= MON~ FRI, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
press
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
press
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Or
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Regards,
BElectric
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
How to set up Panasonic Answering Machine KX-TG4391
Recording your greeting message You can record your own greeting message (2 minutes max.). 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm away from the MIC. 4 Press {?} (STOP) to stop recording.
Playing back the greeting message Press {GREETING CHECK}.
You can also operate the answering system by pressing dial keys on the handset
Key Operation {^} or {V} Adjust the receiver/speaker volume {1} or {<} Repeat message (during playback)*1 {2} or {>} Skip message (during playback) {4} Play new messages {5} Play all messages {8} Turn answering system on {9} Stop playback*2
Oct 17, 2010 | Panasonic DECT 6.0 Expandable Cordless...
JVC DR-MH30S DVD Recorder Image file
ciao! tutti vittime del dvd rec [jvc dr mh20-]..jvc dr mh 30...jvc dr mh 50..e un risolvere dell problema di LOADING...il mio jvc dr mh30..di 6 mese e roto ..ma trovo risolvere..difetto e nel hdd,160gb..e in corrozione..e roto hardisk,solo sistema operativo.......con softer COPY CLONE PRO..free da iternet.scarica nell cd room..nel avvio dell pc,che sono due hdd,uno rotto ,e uno buono..guarda instruzione dell cd..e tutto ok,per copy di hdd..e tutto ok per legare poi nell dvd rec jvc dr mh 30..ho provato io e tutto ok...ma io ho trovato hdd dell dvd rec jvc dr mh20..e io ho un dvd rec jvc dr30..ce un problema picollo dopo copy cloner,,mio dvd rec mi conosci solo 80gb..ma perche e in origine da dvd rec jvc dr mh20[80gb]..cercho un hdd di dvd rec drm h30..opure jvc dr mh50..per copy cloner,mio hdd,per conosciere 160gb..opure 250gb..atentti problema di LOADING..e nell due alimenti di hdd..e suporte di dvd..sono quattro line..12v..terra..terra..5v....sono simille anche perhdd..anche per suporte dvd..controla nel condizione di LOADING..se non sono precise..voltaggio..persempio..12v=10v..opure 5v....4.2v..e perdita..da un contesatore electrolitica.e asciugato da lavoro fastidiosa.......se aiuto da poco..non lo so aspettiamo nell mio e-mail....arivederci[ agimqosesda@yahoo.com ]
Apr 14, 2008 | JVC DR-MH30S DVD Recorder
JVC DR-MH30S LOADING
Had this JVC recorder for a couple of years, It has always take ages to
boot up and start working now its stuck on "Loading" on the display.
Anyone no of a reset seqence that will restart the machine
Nov 20, 2007 | JVC DR-MH30S DVD Recorder
Record dvd
1. Make sure the dv-camcorder is properly connected
2. Press INPUT repeatedly to select the external
input to record from.
• AV1: Audio/Video Input mounted on back
panel.
• AV2: Audio/Video Input mounted on front
panel.
3. Load a recordable disc.
4. Set a recording mode as necessary by pressing
REC MODE repeatedly.
DVD: XP, SP, LP or EP.
5. Press the REC button once to start recording.
The REC indicator lights in the display window.
6. Press STOP (x) to stop recording.
Nov 14, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
LG DBRH197
Jul 03, 2007 | LG DBRH197H DVD Player/HDD Recorder
Weekly timer recording not working
Have you tried setting the clock to manual mode: Page 18 in the manual I think.
Jun 30, 2007 | LG DBRH197H DVD Player/HDD Recorder
Not Able to Record/Playback
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
THANK YOU
Jun 16, 2007 | Olympus VN-1000 Digital Voice Recorder
LG RH188 Logo
148 people viewed this question
Computer Repairing
Computer Repairing
