Question about Casio Office Equipment & Supplies
I have Casio DC500 DATA-CAL Calculator have replaced the battery and done a reset but all I get is a 0 in display no other keying works..can u help me?
    Problem Solver:
  • 5 Answers
I have this calculator.
I haven't got batteries yet, but I have the manual.
These are the instruction for resetting:
1. Press the RESET button on the back of the calculator with a thin,
pointed object.
2. When a data item is stored in the secret area, the message "SCRT RESET?" appears on the display to confirm whether or not you actually wish to perform the Secret Reset procedure.
Press the SET key to proceed with the Secret Reset.
3. The message "SCRT RESET !" appears on the display for a short while to indicate that reset is complete, and then "0." appears to indicate that the secret area data and password have been deleted.
4. Press the RESET button and the message "RESET ?" appears on the display to confirm whether or not you actually wish to perform the Reset procedure.
Press the SET key to proceed with the Reset.
Hope this helps.
David.
Posted on Mar 13, 2010
  • morsy_amr Apr 20, 2011
    I need to know the battery type (number) please
Please tell me to find out the inverse of any matrix with an example in scientific calculator
  1. Press the "Mode" key next to the "On" button.
  2. Press 6 to choose matrix
  3. Press 1 to Enter the matrix data in MatA
  4. It will ask for the Row by Column dimensions (mxn), press the corresponding key, for this example we'll use a 2x2 matrix, so press 5.
  5. Enter the data into the calculator using the arrow keys and number keys.
    The for now enter 1 0 as the matrix (press the = key after you have finished entering a number). 0 1
  6. Press the AC key once the matrix has been entered.
  7. Now press SHIFT, 4 and press 3 to select MatA
  8. "MatA" will now be displayed on your screen
  9. Press the "-1" key (just below the mode key)
  10. "MatA-1" should be on your screen, press the = key.
  11. The inverse of the matrix will be displayed.
Jul 02, 2011 | Casio FX-115ES Scientific Calculator
Time problems
Sorry to say it but the DMS key is to convert between Degrees, minutes, seconds and decimal degrees (angle units). This cleared here is how to use the DMS key on this calculator.
Label of key [deg symbol ' "]. It is between [(-)] and [hyp]
To enter a value in decimal degrees
12.58 [deg ' "] [=] Screen displays 12.58 deg on top line and 12 deg 34' 48" on bottom line.
Pressing the [deg ' "] key while this value is displayed will show 12.58
To enter a DMS value:
Press the [deg ' "] key after each number even if one of the numbers D,M,S is nill (0).
Exemple Enter 25 deg 0 ' 48"
25 [deg ' "] 0 [deg ' "] 48 [deg ' "] [=]
Screen displays 25 deg 0' 48" on bottom line
Pressing the [deg ' "] key converts this result to decimal degrees 25.013
Jan 14, 2010 | Casio FX-115ES Scientific Calculator
Okay, so I've got a fx-7400G PLUS. My stupid friend put the contrast to light and turn it off. The calculator stop working. What can I do to make it work again? Thanks in advance.
Reset the calculator. On the back of the calculator there is a reset button (Above battery compartment and to the left. Use a thin pointed object to push it. The calculator will ask for confirmation to reset all memory back to default. Press [F1] to accept.
And next time avoid hanging out with stupid people, and don't lend them your calculator. Didn't you know that stupidity is contagious?
Hope that helps.
Thank you using FixYa and for rating this solution.
Dec 03, 2009 | Casio FX-7400G Plus Calculator
I need to reset my scientific calculator so it gves me scientic notation and normal numbers
Hello
Press the [MODE] key until you reach the display format setup screen, with FIX, SCI and NORM. Under them you have, repectively, 1 2 and 3.
Press the number under the display format you want. If you are presented with 0 tilda 9, you are expected to enter a number between 0 and 9. The number you enter will decide how many decimal digits your results will have.
Hope it helps.
Oct 02, 2009 | Casio FX-300MS Calculator
Need to change the tax rate from 7.75 to 8.75 onmy Casio DR2220HD
I found my manual papers.
Push the CA button
Hold down the set key (%) until the 0 prints and shows on the screen.
Then type in the new tax amount and hit Tax+ .
You will also need to repeat the above for the Tax- .
This works for my DR-220HD Casio Calculator.
Good Luck
Apr 01, 2009 | Casio DR-220HD Calculator
Casio FX-880P and TM Error
You need to reset you calculator. With the casio fx 880P on, press "P" in the back until the display goes off, then press all reset, next to the Power On. If it doesn't work, try again.
It worked with me. Daniel.
Apr 01, 2009 | Casio Portable Keyboard Touch Sensitive...
Percenteg Function problem in my Casio MJ - 120 Model Calculator
I found it by myself, I can help you.
1. Press (AC)
2. Hold (Rate) for about 2-3 second
3. Press (Set / TAX+)
4. Input the tax rate
5. Press (Set / TAX+)
6. Hold (Rate) for about 2-3 second again
7. Press (Set / TAX+) again
And Then you can test the rate .
From Thailand
Mar 12, 2009 | Casio Office Equipment & Supplies
Reset the time function
To set the clock time
1 Press the KB/CAL key, to switch the LCD display into calculator mode,
then type the new time, in 24-hour format display.
2 Press Prog+Send key once will set the new time to clock display.
Examples for time format:
231105 = 11:11:05pm display 23-11
102359 + 10:23:59am display 10-23
Sep 05, 2008 | Focus Electronic Focus FK 8200 Keyboard
Casio MS-120TE tax rate
Found this on the casio site worked fine on my ms-120TE
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds until set and a 0 is displayed
3. Press [TAX+]
5. Press [SET/%]
this is the link:- http://www.casio.com/support/content/AF64A1AC-193D-4650-A9A9-98BB6FE26CFE
Dec 05, 2007 | Casio fx-300ES Calculator
Open Questions:
471 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
