Question about Zoeller 10-0034 Switch-Mate Pump Float Switch with 15' Cord
Sump pump float adjustment
How far above the drain tile should the water level be before the sump pump turns on?
  • Anonymous Oct 02, 2013
    I had a similar problem with my sump pump in Edmonton, but got it resolved relatively easily, thank goodness. Hope it works out for you as well!
  • 57 Answers
This really depends entirely on you. the higher the water level the less frequently it will run. most motors use more power to start than they do to run so starting less should save you money.
Posted on Nov 21, 2009
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
Hotpoint Built-In Dishwasher HDA3600DWWmy dish
there is an electronic solenoid near where the drainhose connects to the sump that changes the waterflow direction from recirculate(washing), to evacuate (draining). this is electronically controlled by the timer. you can test the power leads at the solenoid for voltage when it sould be draining. if none then the timer is faulty. if there is voltage then the solenoid is faulty. if the solenoid is engageing, then the water diverter is faulty. if the water diverter is broken, replace the dishwasher.
overflowing is another problem of its own. the water level float/ sensor is not working and could be caked with detergent. work the float from the inside of the dishwasher, it should move freely. if so, then there is a switch connected to the float on the underside. test it with an ohmmeter. if bad replace it. if it is an electronically timed water level control then it could be a problem with the timer as well, but with hotpoint they are usually manual.
Sep 27, 2013 | Hotpoint Dishwashers
How can I tell if a WM48 Zoeller Sump pump is operational. It appears the water level is over the float.
Depending on the sensitivity of the float switch you may find that the float must be completely upside-down for the pump to turn on. The easiest way to check if the pump works is grab the float by hand and hold it in the inverted position - if your pump kicks in and starts pumping you know the pump itself works and you may want to adjust your float (I use tie-straps around the handle and around the float cord to artificially shorten the float). If your pump does not pump water when the float is inverted try shaking the float to see if the inner switch is stuck. Hope that helps.
Mar 25, 2011 | Heating & Cooling
How can I adjust the float?
You can't adjust the flost on those pumps... there is a magnetic switch that turns the pump on when the float gets to the top...
The only way to adjust the water level is to adjust the hieght of the whole pump...
heatman101
Feb 23, 2011 | Flotec Simer//Omni 2957 Submersible Sump...
Water keeps overflowing over the ice making coils
Do you mean that it is overflowing the sump tray into the bin? If so there are two things to check. First make sure the unit is level. Second their is a simple water float valve much like an old toilet float that keeps the sump full. Turn the machine off and make sure that the float will stop the water flow 100% when the sump water level is just over the bottom of the water pump impeller. If the float will not stop the water flow either the water pressure is too high or the float valve is bad and has to be replaced. In general water pressure should be between 20-40 psi.
Dec 18, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
The high level water alarm intermittently beeps and the pump starts and stops several times before clearing out the water
On the controls to the pump there is a float, or 2 floats that control wheather the pump is on, or off. I don't know wheather this one has one float or 2 so i will give a short explanation for either fix.
Little giant usually has 1 float on a length of cord, or 1 float with a rigid frame that it goes inside, or has a guide rod. No matter which system is employed there is a built in dead band for the interval between when the pump turns on at a high level, and when it shuts off at a low level. If the float is on a rod, or in a cage it needs to be able to move freely. There is a method to control the turn on height, and the turn off height with some little clamps that connect to the switch. So when the liquid level gets high the pump turns on, and then when the liquid level gets to the lower limit the pump automatically shuts off. If these little keepers are right near the top of the float, and right near the bottom of the float then as soon as the pump turns on the liquid level drops just a bit, and the dead band is real small, so it just shuts right off. the liquid flows backward through the pump and then it turns back on, ect... If this is the case move the adjustments that surround the float. Presto.
If it has a little float on a cord then the adjustment for the level needs to be secured to the discharge pipe or something. It has a mercury switch inside the float to turn it on, and probably another to turn it back off when the float goes to a desired level just above the suction at the base of the pump. I would use black zip tie's to hold the cord so that the desired "turn on the pump level", and the propper "turn off the pump level" are what you want. Just hold the cord against the discharge pipe so that the float is above the suction opening to the pump, and the strait up level of the float are what you want.
If it has 2 floats on cords then one of the floats will turn the pump on if both are held upright by the liquid level. This float must be the top float that is mounted on the discharge pipe. If the 2 floats are mounted in the reverse position then the pump will cycle quickly. There will be a nearly nonexisting dead band. Both will be upright but the control circuit will shut the pump off when the top float, which should be on the bottom, lowers even slightly. Use the same method as perscribed above to attach the floats. The one that belongs on the bottom, the one that turns the pump off, should be placed so that the pump will shut off before it tries to pump air. the top float will turn the pump on if it and the lower float are both upright.
Presto.
Oct 27, 2010 | Little Giant TSW-SP-C 45 GPM - TSW Sump...
Pumb only pumps a small amount out of the basin. Float needs adjusting to go all the way down and empty the basin. How do you adjust the float/bulb to travel farther down without shutting off after only a...
Flotec website shows several submersible sump pumps, and pump types:
http://www.flotecpump.com/asp/productapplication.asp?AId=28
Click product, then click on 'parts and literature' to access manual
Here is a Flotec manual:
http://www.flotecpump.com/pdf/FP525%2811-1-06%29.PDF
Manual for this type of sump pump says:
Quote from manual: Automatic float switch is sealed and factory adjusted for
most home sumps. Turn-on water level is 10" - 12" above
pump base. Turn-off water level is 4" - 6".
The manual also says that running the pump when dry will ruin the seals.
This implies that the water level setting is set so the seals will not be damaged
You might be able to dig the sump deeper, but I don't know if that meets your objective.
Oct 24, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
Just purchased a home with water ace sump pump.
That's the idea; if you lift the float the water starts pumping because it works off of that float. That type of pump is usually meant for water that is in a tub or bucket, so that when the water reaches a certain height and causes the float to rise allowing the pump to kick on. I use a pump like that to pump our the drained water from my washing machine in my basement, i let the water go into a big 50 gallon drum and then once the drum is half full i have it set so the float rises and pumps out the water. That being said, if you are putting this in your basement at floor level, you would need to get a 10 gallon bucket meant for sump pumps (you can get one at your local home store) and rent a jackhammer if your basement is concrete and put the bucket in the floor and the sump pump in the bucket, this is called a sump pit. Another option is to get whats often called a "floor ******" pump. Its a pump that sucks the water out when it reaches around a half inch of depth and it can be used in several feet of water (I've used these as well, there is no float involved), and it can be set on level ground there is no sump pit needed. The one thing with my pump you may not want, is that it's constantly running because its constantly monitoring for water so that a lot of water will not build up (especially if water can damage some thing in the surrounding area) . You can check out all the types at your local home store.
May 27, 2010 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Water backs up in the floor drain during heavy downpour even thou
the sump pump shold not be run into the sanitary sewer, but if your floor drain is hooked to a sump pump pit and it doesn';t pump the water before it gets to the drain tile it could come up in the drain,, to solve the problem get a pump that the float is lower in the pit,, suggestion zoeller cast iron submersable pump cost about 100 less the install price, great low profile pump, it keeps less waterin the sump pump pit so there is less mosture
Mar 11, 2009 | Invacare Supply Group Invacare Top End...
Zoeller 10-0034 Switch-Mate Pump Float Switch with 15' Cord Logo
2,099 people viewed this question
Top Zoeller Electrical Supplies Experts
Fred Sops
 steve
steve
Are you a Zoeller Electrical Supply Expert? Answer questions, earn points and help others
