Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
Husky Air Compressor has rattlling noise!
Husky Air Compressor Model # H27508UWK has LOUD/OBNOXIOUS rattling noise which appears to be coming from the crankshaft & Fan area when it is running. Belt is fine and not overly worn. When powered off connecting rod has lots of play and moves freely on crankshaft. I'm thinking this free play is making this noise. What is the fix action? Bearing replacement, or something else. I do have the Operations manual that has an IPB so giving me the name/number of a needed part will work.
Thank You
    President:
  • 1,167 Answers
Buddy im an engineer on these machines for 30 years and when this problem has occured believe it or not but it cheaper to buy another pump unit or compressor plus its the hardest job getting the crank out so your choice bud
Posted on Nov 16, 2009
I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
Free Husky Air Compressor User Manuals ' ManualsOnline ...
powertool.manualsonline.com > ... > Husky > Power Tools Husky
Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
Sep 04, 2015 | Air Tools & Compressors
Noise
There are basically two moving parts, the fan and the compressor. It more then likely is the fan. Be sure the air path is clean and the fan blade does not hit anything. If it is the compressor I would suggest getting a new unit and using that one elsewhere for the short time it has left.
Apr 22, 2014 | Haier 65-Pint Dehumidifier
We have a Jenn-Air Dryer, model JDE2000 that has recently started making an obnoxious rattling noise while running. The belt appears to be intact, the drum rotates and clothes are dry when finished. I've...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Mar 19, 2011 | Dryers
I am getting a loud rattling noise. could this be my compressor
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Jan 29, 2010 | Frigidaire Refrigerators
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Loud rattle noise when compressor cycles on
if this noise is coming from the compressor, it will eventually fail. If you just purchased it, i would ask for a replacement fridg and let the manufacturer deal with the repairs that it needs
Jan 07, 2010 | Refrigerators
What is the loud rattling noise. For the last several months we have had a loud rattle coming from the rear and bottom part of the refrigeratory. Help us understand what we can try to fix this problem.
Hello, I will try and guide you to find a solution to this noise. If you are willing and able,roll out this unit to excess the lower panel. Behind this will be the compressor, condenser, and condenser fan motor. Check to see if this fan and motor are the source of the noise. Maybe bearings, blade hitting the panel, something may have been sucked up in the fan making noise, ect.Clean the front of this coil while you are in there searching, to keep the pressures in the system at normal temperatures. You can use a brush to clean. I am confident you will find the source in this area, and resolve this noise. The unit is operating good? If so that is a good sign it is not a serious problem. Please keep me posted on what you have found and I will be here if you require my help. Sincerely,
Shastalaker7
Dec 13, 2009 | Samsung RS2630SH Side by Side Refrigerator
Loud rattling noise that vibrates of oan on coming
check all things are tight like exhaust & fan etv & not rubbing
on anything
also look for wear marks from rubbing! shiny bits
Jul 18, 2009 | 2004 Jeep Grand Cherokee
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Loud noise from air conditioner when accelerating
bearings are shot in the compressor , repair or replace
May 11, 2009 | Heating & Cooling
Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
902 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
