Question about Samsung SGH-E900 Cellular Phone
Message "conditional forwarding" when connecting to a number
How do i block a number on my alcatel one touch pixi 3
Block Calls & Messages:
  1. Open the apps drawer and launch "Contacts"
  2. Tap the name of the contact you want to block calls and messages from
  3. Tap "Edit" > "Menu" and enable "All calls to voicemail"
Unblock Calls & Messages:
  1. Launch "Contacts"
  2. Tap the contact you want to unblock
  4. Disable "All calls to voicemail"
Forward Calls (Unconditional):
  1. Tap "Phone" on the home screen
  2. Tap "Menu" > "Settings"
  3. Tap "Call settings" > "Call forwarding"
  4. Choose to "Always forward" and if necessary, enter the phone number to forward calls to
  5. Tap "Enable"
Forward Calls (Conditional Forwarding):
  1. Open the "Phone" app
  3. Go to "Call settings" and tap "Call forwarding"
  4. Select to forward calls "When busy", "When unanswered" or "When unreachable"
  5. Enter the phone number you want to forward calls to and tap "Update" or "Enable"
Turn Off Call Forwarding:
  1. Open "Phone" and tap "Menu"
  2. Tap "Settings" > "Call settings" > "Call forwarding"
  3. Select "Always forward", "When busy", "When unanswered" or "When unreachable"
  4. Tap "Disable"
Read more: http://cellphoneforums.net/general-cell-phone-forum/t381553-alcatel-onetouch-pixi-3-block-calls-messages%3B-forward-calls.html#ixzz4TXeusLlT
Dec 22, 2016 | Alcatel Cell Phones
How can read a message from another number
You can't read SMS messages from another phone unless you forward the message to your phone. This is because messages are sent to the phone number. You can do a backup of the message to your PC using the software provided by the phone manufacturer or get the software 'Moborobo' for android, install on a PC and connect phone to PC and do the transfer. Then you can read all the message.
Nov 07, 2014 | Cell Phones
What do you mean by forwarding on conditional on?
Forwarding on conditional, means that calls can be forwarded to a different number (or voicemail) on certain conditions.
These could be, unanswered, unobtainable or busy.
Normally you would have this set to forward to voicemail if you are unreachable, or unanswered.
But you can forward ALL calls to a different number if you wish.
Please note that different phone providers can charge for this feature.
i.e. forwarding a call to your home number, they may charge you for forwarding.
May 12, 2014 | Cell Phones
Can you forward sent messages
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Oct 23, 2012 | Samsung Cell Phones
How do I forward messages
Hello Jerseyjay,
To forward a message, open that particular message and click the "options' and in 'options scroll down until you see forward > select 'forward' and next enter the number to which you want to forward the message, Done : ) .Good Luck.
please rate if this solution was helpful !
Jun 21, 2011 | LG Optimus 7 E900 (16 GB) Smartphone
How can i block a number on a nokia 6500c my service provider can not is there any other way for blocking unwanted calls
The 6500c does not support conditional call forwarding (CCF) which is useful if your carrier does not provide blocking services. I have owned several nokia, a samsung, two LG, and currently have a blackberry 9330. If unwanted calls are a serious problem, consider upgradeing to a mobile phone that supports CCF. Conditional call forwarding can be used to forward any unwanted phone number includeing calls from unlisted, unknown or restricted callers. Depending on where you live, the call can be instantly forwarded to a service, such as trapcall.com, that unmasks the caller in addtion to providing the standard message "This number is no longer in service" for example.
Apr 25, 2011 | Nokia Cell Phones
I have a panasonic KX-T7665 how do I forward calls to my mobile
The simple answer is on the intercom dial *7102 9 number #. That forwards all calls outside. However, outside line and trunk-to-trunk programming has to be programmed into the system.
There are other conditions located in the Operating Manual under Call Forward. In mine, it's on page 71.
Carl
Mar 21, 2011 | Panasonic Lands Phones
How do you forward a text message you have recieved
Follow the steps:
1. Open the message, which you want to forward. 2. Highlight message to be forwarded. 3. Go to menu then select forward option. 4. Enter the number to which it should be forwarded. 5. Then send it.
Jun 26, 2010 | HTC Tattoo Cell Phone
How to turn on Voice Mail again.
You phone is no longer forwarded to the voicemail pilot number. It should be forwarded in a no answer condition and a busy condition.
Mar 11, 2010 | NEC Dterm DTP 16D-1 Corded Phone
Message forwarding
only calls can be forwarded but you can try your area code + number
Sep 03, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
138 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
