Question about Samsung YP-U3 MP3 Player
MP4 Player removable disk doesn't come up
When I plug in my MP4 player it doesn't connect through the USB port
  • Taysies Feb 03, 2008
    Mine also doesnt register the USB connection. Only just bought it brand new, but with no instructions. Also, my computer is a brand new laptop. What the hell??? It doesnt even come up on My Computer
  • AVitman Feb 15, 2008
    how can i build my own directory put over there my songs and not to see on the screen artist album etc....??
  • 8,596 Answers
The hold/lock is probably engaged - unlock it; or you are running Vista
go to manufacturer's website and get the Vista-compatible software/firmware if you are running Vista
Posted on Jul 06, 2008
6ya staff
SOURCE:
Download to a go gear mp4 player
Connect the player to your PC (desktop/laptop) from the USB port on the player to a USB port on your computer and transfer videos (MP4 files), music (MP3 files) and pictures (JPEG files) to the player.
Dec 31, 2014 | Audio Players & Recorders
I have a genx mp4 player model-gmp4-01. the moment i connect it with my pc through usb it gets charged automatically but i am not able to access its files like removable disk. also the windows does no
The USB cable is probably strictly a charging cable, not a sync cable or a dual charging/sync cable, so it will only charge the player but not make it visible to/accessible by your computer. You can get a sync cable or if you already have a multi-port USB hub that you use to connect devices to your computer (mouse, flash drive(s), etc.), try connecting the player through an available port on the hub.
Nov 30, 2014 | Audio Players & Recorders
Mp4 player not working
Check your MP4 player's system requirements.
Some MP4 players are only capable of working with certain operating systems and hardware, so refer to your player's documentation to ensure it is capable of functioning with your PC.
Change the USB port your MP4 player is connected to if you have confirmed your PC can function with your MP4 player.
Disconnect other USB devices, and try connecting your player to another USB port if you are still having problems.
Try restarting your PC if it is capable of working with your MP4 player.
Restarting your PC resets non-functioning USB ports, which may be your problem.
Make sure your USB cable is connected properly.
If your player requires you to install drivers, make sure you install them.
Try connecting your player to another PC to see if the new PC recognizes it.
If it does, chances are your computer does not support the hardware necessary to run your player.
Reset your MP4 player if your PC is still unable to recognize it.
Resetting your player varies depending on the manufacturer and model, so refer to your player's documentation.
Contact your player's manufacturer if you are still unable to get it to work with your PC.
http://applestore.altervista.org/mp3mp4.pdf
Aug 25, 2013 | Intel Computers & Internet
My pc canot detecte my mp4
Your MP4 driver disk must be installed and run BEFORE you hookup the MP4 player.
If you have done the faux pas above, all the installs in the world will not fix it. You MUST remove the USB driver. Use Device Manager. In XP, this is found by right clicking my computer and selecting properties. In properties select the hardware tab and choose 'Device Manager'.
Stop here. If you have no idea what I wrote, review 'Device Manager' on the Windows Website or ask a KNOWLEDGEABLE friend for help. See http://support.microsoft.com/kb/310123.
Now, select the MP4 device, while it is plugged in to the USB port, and right click. Select 'Uninstall'. Remove your MP4 device when device manager is done.
Close Device manager and all the other windows. Start your USB install from scratch, without the USB plugged in untill the install asks or completes.
I have ALWAYS had successful installs with this method.
Mar 28, 2010 | Ice Tech KEO MP3 Player
My comp. doesnt recognize my premier mp4
The computer recongize it as a removable disk.
plug in your mp4 player
click start
click computers
click removable disk
formate the disk
copy and paste you songs.
Dec 23, 2008 | Premier MP4 Digital Media Player
I need to know how to download music to a mp4 player.
all mp3 and MP4 players have a built in USB port for connecting it to your computer, connect a USB cable to your MP4 player and the other end of the able to your computer's available USB port, windows will recognise the drive and install it for you. all you need to do is to go to my COMPUTER and double click on your MP4 player drive to open the content of your drive
check to see that the drive is has foldes like MY MUSIC, you can use windows media player to sync music files in your library to your MP4 player.
Dec 13, 2008 | Classic Electronics MP6410 MP3 Player
Can't get the usb port to accept the mp4 player.
Switch on your Mp4 player and connect it to the usb port. Your computer should produce a message "New Hardware Detected". If you don't get such a message either the lead, the usb port or the Mp4 player is faulty.
If you do get such a message, if your computer can't find and instal the right drivers automatically there will be another message or the Found New Hardware wizard will appear. By following the onscreen instructions your computer should be able to search the internet for suitable drivers.
In any eventuality, when connected the Mp4 player should appear in the My Computer window and if it doesn't it isn't connected.
Jun 26, 2017 | Samsung YP-T9JQB Digital Media Player
Istage mp4 player
buy one that actualy works
Jun 15, 2008 | Acer MF35 MP3 Player
Premier 2gb mp4 player
there is no current soloution, there is a virus on the net that completly wipes all information off mp4's including the driver files, repair files and mp4 player files.
the only temporary way to fix it is to either find another mp4 and copy the sofware off that and install the divices from the copied folder, or somehow download the files off the net.
Apr 19, 2008 | Premier MP4 Digital Media Player
Manual for infitek mp3/mp4
Problem: Infitek MP4 player is recognized by Vista and Windows XP but when you try to put files on it, error pops up.
Solution: The MP4 needs to be reformatted to FAT32 file system, here is howto do it:
1) Connect USB cable to PC
2) Connect Infitek to cable.
3) An AutoPlay window will pop up on your PC. Select "Open folders to view files using Windows Explorer"
4) On the left of the explorer window the following will be seen "Removable Disk (?:)" (? can be any letter in the alphabet, most likely E-K)
5) Right click on "Removable Disk (?:)" with your mouse and select "Format"
6) "Format Removable Disk (?:)" window will appear, select FAT32 from the FIle system Combo box and select Quick Format from the Format options and click on START
You may need to format the MP4 more than once, it did not work for mr the first time.
7) After you receive a message, Format completed successfully you can drag and drop any files to the "Removable Disk (?:)" which is the MP4 player storage area.
8) Disconnect the cable, turn on the MP4, if at main menu use the >>| key to get to the Music, Click MENU key to get to the first song, click >|| to play song.
I used .WMA files (Windows Media Player) songs. They seemed to work ok
Oct 07, 2007 | Coby MP-610 MP3 Player
Samsung YP-U3 MP3 Player Logo
87 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
