Question about Nokia E71 Smartphone
I have the no gateway reply issue and i did the ip
I have the no gateway reply issue with the nokia e71 and i did the ip thing and it didn't work. is there any other way??
I face problem with my new mobile nokia e71 (web: no gateway reply) PLEASE HELP!
Home>Tools>Settings>Connection
Delete all your Access point connects except Default.
Tools>Settings>Connection>Access Points>{choose AP}>Options>Advance Settings>IPv4 Settings
and manually entered the 4 settings of IP addresses
Then get the configuration details from your service provider, and store these details.
Try again you may get connected.
May 01, 2011 | Nokia E71 Smartphone
In NOKIA E71 will always appear "web: no getway reply" at the time of wifi conn
It means either your wifi router isn't correctly configured (gateway IP address) or you attempted to connect to an protected wifi infrastructure. First, try to connect to an free hotspot (airport, restaurant, etc)
Mar 06, 2011 | Nokia E71 Smartphone
We are getting this Error "Web Getway Replay"
try to get the settings changed manually, it can be rectified, and switch off and on your phone.
May 05, 2010 | Nokia E71 Smartphone
Why is my Nokia E71 mobile phone not charging fully
Ok could be 3 things.
1.Go to your dealer and ask to try a new battery.
2.If that doesn`t help ask to try a different charger.
If the above 2 didn`t solve it , then its the phone.
At this stage if you are under warranty ask for your money back or another phone.
Hopeive helped a bit .
Dec 15, 2009 | Nokia E71 Smartphone
Uplink internet (PPPoE) will not be accessible after power cut
You are using the PPPOE connection. when you set up the router for the PPPOE connection, Do you see Internet IP address on the status page of the router.
If you have the internet IP address on the status page of the router then that is a very good thing. make sure that it shows the Internet connection type pppoe on the status page also.
your computer are communicating with each other they have the IP address that is a good thing also.
Now you can check the internet connection.
open the command prompt ( START ==> RUN == type cmd and click OK) In the command prompt try to ping the router IP address.
Suppose your router IP address is 192.168.1.1. then in the command prompt type " ping 192.168.1.1 " and hit ENTER on your key board.
You will get replies from the same IP address that is 192.168.1.1.
that means the connection between the computer and the router is working properly.
Now type in the command " ping 4.2.2.2 " and hit enter.
If you get the 4 replies from 4.2.2.2 that means you computer is communicating with the DNS servers. If you get the reply form different number or if you do not get replies that means the router is not set up properly or user name and password for the pppoe might not be proper.
Now you got 4 replies from 4.2.2.2.
Then type the command " ping yahoo.com" and hit enter.
Now check if you get replies from yahoo.com ( there might be replies from the number 66.x.x.x. or 207.x.x.x).
If you get the replies then everything is working properly. the issue might be with the firewall or internet browser.
Now if you don't get replies from yahoo.com but getting replies from 4.2.2.2 that means you will need to assign static DNS numbers on the computer.
In preferred DNS = 4.2.2.2
in alternate DNS = 4.2.2.3
that will resolve the issue.
Click Here for more info about the networking
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
No gateway reply E71 problem solving
i have done this entire exercise but not able to solve, can anyone please advice me on the same. i have E71 nokia but when ever i want to connect thru my office Wifi lan it could not connect, thanks! Vanu
Aug 25, 2009 | Nokia E71 Smartphone
When I try to logon to the internet on my N73 nothing comes up and then after a few minutes it will say no gateway reply
I too get the same reply on my Nokia E71. But the second or the third attempt gets me to the net.
Aug 03, 2009 | Nokia N73 Cellular Phone
Website blocking in sl2_141 bsnl modem
i am using nokia e71 with simens sl2_141 its connected thru wlan but when i use to web browsing it shows web no gateway reply
plzzzzz can any body hepl me out
May 27, 2009 | IBM (56X3388)
No gateway reply urgent help
if u want to connect ur wifi mobile with a wired internet laptop to use wifi from ur laptop and connect ur mobile to the internet absolutely free... WITHOUT ANY ROUTER.... my email id sufi24uae@yahoo.com
May 02, 2009 | Nokia E71 Smartphone
Nokia E71 Smartphone Logo
369 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
