Question about Casio FX-115ES Scientific Calculator
Casio 991ms model calci display is very dull some
Casio 991ms model calci display is very dull some times not visible at all
  • Casio Master
  • 7,993 Answers
The battery may be depleted and needs to be replaced.
Hope it helps.
Posted on Dec 05, 2009
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
Casio fx 991ms
On a fx-991MS? With many other models, including the fx-991ES, I'd say you have the calculator in binary mode but the 991MS doesn't have such a mode.
Aug 03, 2013 | Office Equipment & Supplies
How to find inverse of log in a casio 991ms calci?
The inverse of the natural logarithm (in base e) is the EXPONENTIAL function (e^x). It shares the same physical key as the LN function. One is accessed directly and the other through the SHIFT key. The inverse of the logarithm in base 10 is the function 10^x. Both functions share the same physical key as described above.
More generally if y=log(in base b) of x =log_b(x) then x=b^(y). The base must of course be a non-zero positive number.
Aug 25, 2011 | Casio FX-115ES Scientific Calculator
How to interpolate with 991MS
i am giving the key input with an example..
example-
at 0, value is 300
at 50, value is 270
so how much at 30...
On 991MS,
Go in Reg mode, for doing that : press Menu,Menu, 2
Enter the values as follows,
0,300 and press M+ key on the calci
(Note: there is a "," in between 0 and 300)
then enter the following,
50,270 and press M+ key
now enter the following input exactly as displayed below:
(30) shift 2 > > > 2 =
you will get the answer as 282.
I hope you got it!!!
LOFT!!!
Feb 22, 2011 | Casio FX-115ES Scientific Calculator
Dear sir, about casio scientific calculator
u have to check the the correct polarity of the cell and the calci.... put the cell in all combination and press ON key.... if still u have problem ur calci might have some internal problem that u can't solve.......
for more contact prajwal_yes@yahoo.com
Feb 25, 2010 | Casio Office Equipment & Supplies
Hi, I have a Casio calculator fx-991MS giving me wrong answers!
I am only looking for a plausible cause of the error, because I do not believe your calculator can make such a mistake. I think you accidentally activated the Exponential display format and did not pay attention to the small, raised -03 that came at the end of the number displayed. It is a common mistake for those not very familiar with Scientific or exponential notation.
Let us try to reset your calculator to the normal (floating point) format.
Press the [MODE] key a number of times until you reach a screen that has FIX, SCI, NORM and under each one a number (FIX 1, SCI 2), Norm 3). To have the number of decimal place you gave in your result (4 decimal digits), you press 1 to select Fix then 4.
Be aware that scientific calculators usually stop displaying results in floating point format ( 0.0000045 ) if the number is smaller then 0.001. So basically, 0.00099 will be displayed as 9.90-04, -04 being raised above the level, and in smaller size.
Hope it helps.
Oct 01, 2009 | Casio FX-115ES Scientific Calculator
M mod n in Casio fx991MS
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
1, 3 ,4 which is 4*1=4 and 7-4=3 remainder...
Jun 29, 2009 | Casio FX-115MS Plus Calculator
Casio FX-115ES Scientific Calculator Logo
268 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
