Question about Microsoft Windows XP Home Edition
In DirectX Diagnostic Tool under DirectX Features, it shows that Direct3D Acceleration is Not Available. I uninstalled and reinstalled my Nvidia drivers and I no longer can run 3D software. Please advise.
  • 3,051 Answers
Hello there:
this is normaly due to to a 3d accelerater is not installed your ndivia driver would really not have any thng to do with it
What i recommend that you do is to go to the web and download direct x 10 this is the latest and updated direct x that works well with operating systems ok
I hope that this has been very helpful for you
Best regards Michael
Posted on Nov 18, 2009
GRAND THEF AUTO CANNOT FIND ENOUGH AVAILABLE VIDEO MEMORY
Reinstall your video drivers. Also make sure that in 'Display Properties', your hardware acceleration level is set to 'Full'. Confirm that all DirectX / 3D features are enabled in 'dxdiag' as well. Make sure you have at least 32+MB of VRAM.
To uninstall video driver right click to MY computer >>>>properties >>>>Hardware>>>> device manage >>>> right click display driver>>>> uninstall.
Note: before uninstalling the driver make sure you got the driver cd or the software with you.
Mar 22, 2014 | Microsoft Windows XP Professional With...
I need 3D accelerator
Direct3D is a component of Microsoft's DirectX graphics software and is one of the more commonly used graphics accelerators in PC gaming. Of course, before you can enjoy the benefits of Direct3D acceleration, you need to have that particular component enabled in DirectX. Fortunately for your gaming needs, enabling Direct3D acceleration is not an overly complicated process, and can be achieved in a matter of moments. Open the "Start" menu and type "dxdiag" into the Windows Live search box, then press "Enter." This will bring up the "DirectX Diagnostics" dialog box. Click the "Display" tab. Locate the "Direct3D Acceleration" entry. Click the "Enable" option next to the Direct3D entry. This will turn on Direct3D acceleration. You may need to restart your computer to make the changes effective. Hope this helps. http://www.microsoft.com/games/en-us/aboutgfw/pages/directx.aspx http://ati-catalyst-drivers.en.softonic.com/ Optimise your ATi graphics card's performance b> http://download.cnet.com/3dmark2001/3000-2121_4-10056689.html
Jan 09, 2013 | Toshiba Computers & Internet
No hardware-accelerated Direct3D device were found . this the problem appears when I open my game. help me to solve this problem. or give me this kind of device.
depending on the windows you are using, the accelerators should install automatically, or else the system does not support or you can download the accelerators form microsoft and install them.
Jun 22, 2011 | Computers & Internet
I am having a problem. I downloaded the game, Battlezone 2, and installed it. Ive downloaded it from several different sources and am running into the same problem. When I load the game it says "Can't...
Direct3D 6? Wow, the game must be way older than your computer. You probably installed DirectX 10 or later. There were major changes after DirectX 9. The software routines to manage graphics hardware acceleration through DirectX 10 or newer are probably very different from DirectX 6, so the game's graphic controller interface can't find them.
Try going into the game properties (right-click on the main executable file and select Properties from the pop-up menu).
Set it to run in XP compatibility mode and see what happens.
Check to see if the game has the option to run without hardware acceleration. If this provides acceptable performance, that is your answer.
If necessary (and if Microsoft still makes it available), try installing DirectX 6. Vista may snag on it and make you remove it and reinstall a newer version, but it's worth a shot if the other fixes don't work.
Jul 03, 2017 | Activision Video Game Consoles & Games
I had download project igi and it is showing that no d3d driver with acceleration
try
open start menu, then open run, then type dxdiag, on directx files tab
look for d3d8.dll or higher, if you can't see it then you need to install some drivers but before that
you need to go to display tab, then look for directx features see if the directdraw, direct3d, and agp accelecation is enabled, if not, minimize the directx diagnostic window, goto desktop , right-click select properties goto settings, adjust the resolution to 800x600 or higher, then change the color quality to highest 32bit, or higher, just don't do 256color bad quality it will disable the d3d,
then back to directx diagnostic windoow check again then test the directdraw and direct3d,
if it don't work you will need to update your video card driver, or buy a new vga card, with d3d capabilities, the higher the better,
note: some card may not be compatible with your board so try to google first for compatible parts
by korotchan
hope it help
Jul 08, 2010 | Eidos Interactive Project IGI: I'm Going...
The application failed to initialize properly (0xc0150002). click ok to terminate the application. yahoomessenger.exe - application error. the application failed to initialize properly(0xc0150002). click...
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
May 14, 2010 | Yahoo Messenger
Direct 3D Driver Installation Or Reinstallation?
The HAL error is because you haven't installed your grafikcard so windows is using a defaultdriver. You need to download the drivers for your videocard.
I can't say what card you have, for that you have to read the productpaper that came with the computer or open the pc and check the card.
Most graficcards have either nVidia or ATI chips. Intel is the brand on your CPU (and some other stuff) but they dont do their own graficcards.
My advice:
¤ Check the manual/documentary of the computer and look for the type of card you have for your grafics.
¤ If you can't find it in any documentation. Open the computercase and check the cards for any card with a logo from either nVidia or ATI.
¤ When you find the correct card. Check for the name of the card. (could be ATI HD5670, or anything like that)
When you have all info on what card you have. Go to either nVIdia or ATI driverpage and select your card and download/install the driver.
Restart computer hand it should be fine.
Btw. at http://free.grisoft.com you can download a free version of AVG Antivirus. So you don't need to worry about staying connected.
Cheers and hope this will help.
Sep 15, 2009 | Compaq Evo D510 Minitower (Open Box)...
If i open the game, the screen shows very big icons and no image
You are running a low budget onboard chip for graphics. This SiS chip is barely enough for running windows. In order to play any directx or openGL game decently, you will NEED to buy a dedicated graphicscard.
Look for an Ati or Nvidia with 256mb or higher.
Jan 28, 2009 | Computers & Internet
Lineage2 critical error problem
type dxdiag in run window and follow instructions for enabling 3d acceleration
Dec 05, 2008 | Video Game Consoles & Games
My pc game keeps shutting down and keeps saying runtime error
1. Click Start, click Run, type dxdiag, and then click OK. 2. Click the Display tab. In the DirectX Features area, make sure that DirectDraw Acceleration and Direct3D Acceleration are enabled.
Note Windows Vista automatically enables DirectDraw Acceleration and Direct 3D Acceleration if these features are supported by the display device and by the driver. 3. If either feature is disabled, click Enable next to the disabled feature. 4. Click OK when you are prompted. 5. If multiple video adaptors are installed on the computer, repeat steps 2 through 4 on each Display tab. 6. Click Exit to close the DirectX Diagnostic Tool.
If this does not fix it then Tell us the game details - name etc:
Apr 07, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
167 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
