Question about Apex Digital GB51HD09 51" Rear Projection Television
Apex G51HD09 TV will not turn on. Constant humming from transformer on power bard. Where can i find a new board?
    President:
  • 4,402 Answers
You can try and see if ptscorp.com will repair the board.
Posted on Jan 09, 2008
Got 40 in apex lcd flat screen tv and looks like its missing the power supply board anyone help me
some models have a external transformer like power supply. Cable plugs in wall socket goes to power supply transformer, cable from transformer connects to TV with a male female probe type fitting. It appears the power supply is missing.
Mar 04, 2016 | Televison & Video
Loud hum sound
usually the transformers on the psu would give a slight buzz,but when tv i on standby the only power going to main board is minimum,dont know if your model has aa built in fan,would need model number
Dec 09, 2013 | Insignia Televison & Video
Th-42pd25 humming sound and faint picture
Sounds like an inverter transformer humming, not producing enough current to display a bright picture. Check the caps in power supply, next to the plug where it says 24v and goes to the inverter board on the left side of tv. Or check for bad connections on inverter transformers on inverter board, Thanks
Nov 11, 2011 | Panasonic Televison & Video
Have a aprilair 550 for some time. Installed a new Lennox G61MP furnace and the technitions failed to reconnect the wiring that powers the humidifier. Need wiring schematic. Does humidifier transformer get...
Hello, yes the transformer will get a 120 volts from the Furnaces control board, there should be a terminal labeled HUM on the control board. You need to bring 2 wires one from HUM and one from a nuetral tap on the board to the line side of the transformer, this way every time the blower motor on the Furnace turns on the humidifier will aswell.
Aug 23, 2011 | Aprilaire 550 Humidifier
The unit now has a very low but noticeable humming noise when it is turned on... and does not go away. Its almost like a bad or obstructed fan? - christopher buchanan
This is a LCD tv,it dosen't have a fan inside this tv.The humming sound u hearing it is comming from the tv power supply board itself.Some how those high voltage transformers,in the power supply board are having gapping voltages tranmitting,when power up those transformers are going in and out of it highvoltage coils.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 02, 2011 | Samsung LN52A850 52 in. LCD HDTV
LG 42LH30 Audio Problem (Background Buzzing)
Ur power supply board.Transformers have have high voltage gap.This problems must take the tv aparts put some glue arond the transformers,sometime solved this problems,or must replaced all the trnsformers make the humming noise.Brand new tv take it back,where u bought it get a replacement or call the Manufacture help to fix the problems or replaced the part that cause the problem.
Feb 08, 2010 | LG 42LH30 42 in. LCD TV
I have a DGTEC 22'' LCD TV that has a high pitched hum when in the standby mode. This hum disappears as soon as the TV is turned on and the TV functions as normal. But as soon as it is put back to standby...
On the main power supply there are transformers that many times the factory will silicon/glue down to the PC board as these transformers with the right amount of voltage can vibrate or as you say hum. This can be corrected if you take it into a trusted TV Service Shop and make them aware of the issue so that they may be able to re-silicon or Glue these transformers better. Should be great deal of cost - usually shops have a $60 to 100, 1 -hour min charge.
Blessings,
A/V Media Guy
Nov 23, 2009 | Televison & Video
Apex converter boxes malfunction.
If the converter box wont power on and makes a cyclic whinging noise, it may be one of the 4 470uF caps on the low voltage side of the power supply. Check for domed tops on the caps nearest the fly back transformer (center of the board). I replace all four of those caps just to be sure and it is playing fine now.
Nov 15, 2009 | Apex Digital Televison & Video
TV Fault
I would return the tv for a replacement
it sound as if one of the transformers is arking internally. or you can replace the "Control module" but it is in very short supply
Lou Margo
Allied Electronics
loumargo@verizon.net
May 20, 2007 | Polaroid FLM-2625 26 in. HD-Ready LCD...
Apex Digital GB51HD09 51" Rear Projection Television Logo
75 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
