Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Motorola razr k1 the keys are nasty and breaking. short somewhere
Motorola razr k1 the keys are breaking, falling apart. There must be a short somewhere because there is this high piched sound when you use it to text.
How do you a factory reset
You can Factory Reset the Mobile Means,.Unlock it..You can get the Unlock code for the Motorola Motro Razr krzr K1 model mobile here
http://www.superunlockcodes.com/motorola-motokrzr-k1/rs12wp9/ and Unlock it........
Nov 09, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
How do i master reset motorola k1m if i forgot my pass code
Please remember after you finish all of this, you NEED to reboot your phone for everything to take effect. And only do this with a K1m, not a K1.
Master reset/clear is not in testmode on K1m. You need to either use software2_bing.gif such as radiocomm etc or you can do it from opcode screen.
Perform at your own risk!!! This will delete everything (contacts, pics, etc...), not just contacts!
Goto opcode screen:
Enter: CLR, 0, 4, 8, 2, 6, 3, * (Note: Must be done quickly.)
From the opcode screen:
Enter 18* and click center radial button on phone. Then enter 0 and click on center radial button.
-wait and it will say success after a short time.
Enter 18* and click center radial button on phone. Then enter 1 and click on center radial button.
Exit out. Contacts, Pix & Flix, Called #’s, etc should all be deleted…
Note:
18* enter, 0 enter – does master reset.
18* enter, 1 enter – does master clear.
WARNING: There are other #’s that can be entered…but I think you can really BREAK/BRICK your phone in there quite easily…
Performing master reset/clear using software like radiocomm is proven and works well, but if you do not have the software and want to wipe phone before selling, returning, etc… then…
Apr 03, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Bluetooth wont connect to any devices on my razr k1
make sure that you are following the right process. It should be compatible. when you set your phone to "find me" the bluetooth symbol should come on? It should be flashing. Was the headset linked to another phone before? If so you may need to "reset" it. make sure that you have turned the headset in the mode to link up with a device then use the razr to find a bluetooth device. it Should hook right up. Also make sure bluetooth is turned on on the razr
Jan 03, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola krzr is making static noises and dialing repeated 7's. What can I do?
Not much, sounds like a short somewhere. I would bring it in for service.
Oct 23, 2009 | Motorola Mobility KRZR K1 Cellular Phone
Motorola razr v3 purchased on line screen is in spanish.
Go to Settings Menu > Initial Setup > Language
Change it to English
Here's a link to the Owners Manual if you want it...
http://www.motorola.com/staticfiles/Support/Mobile%20Phones/RAZR%20V3/US-EN/_Documents/Static%20Files/V3_06_UG_generic.pdf
If this was a help, please take time to rate it. Thank you!
Oct 14, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola ZRZ4 K1, what does ssl mean, and it's porpose?
SSL is short for "Secure Sockets Layer". It uses a cryptographic system that uses two keys to encrypt data for security.
May 24, 2009 | Motorola Cell Phones
Motorola k1 boost unlimited phone Unable to charge
u r facing a problem with charger circuit that lil circuit shud be replaced.
Dec 29, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola razr k1
open the front lcd part with the help of t 6 screw driver and try to take out it a jack 2 replace it.reply me
Jun 17, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Relacement frount screen motorola razr k1
u can get lid frm markety or u can order frm site fr ur phone and u can replace it urself
I forgot my unlock code
press the menu key , when the phone ask for the sec code it should be 000000 - default security code if you have change it then enter the code and you are back in your phone.
Mar 02, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
106 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
