Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
My HP G6000 Laptop switches off at different times. I have run the diagnostic programme and it tells me to change hard drive???
  • 113 Answers
Well change the hard drive, the software (diagnostic)is detecting hdd failure backup your stuff fast and replace the hdd
Posted on Nov 19, 2009
"non-stystem disk or disk error replace and strike any key when ready"
Sounds to me like the hard drive has gone out on it.
If you turn the laptop over you will see a couple panels that can be removed... There will be one that has what looks like a circle type design by it that indicates hard drive access... If you cannot find this icon its not a big deal as the screws are just phillip head screws..
1. Remove panels
2. Verify Hard Drive is seated properly. (Might disconnect then reconnect to make sure)
3. If you can tell the make and model of hard drive this would be a good time to write it down. (I.E. Toshiba, Western Digital, Seagate)
4. Replace panel
Try booting the computer again. If the problem continues then you need to online and do a google search for hard drive diagnostic bootable disc for your hard drive. Most of these programs are universal and can do a cross platform basic checks on hard drives.
To go into more detailed diagnostic you are best to use the software designed by the maker of the hard drive.
1. Download test disc and burn
2. Boot laptop from cd-rom using bootable test disc
3. Run diagnostics.
If it fails then you have a bad hard drive and you will need to replace the drive.
Dec 30, 2013 | HP Compaq 6735s Notebook
Hi. When I try to turn on my HP mini it tells me to "Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key" I have tried almost everything I know how...
Your hard drive appears to be corrupted. Your computer is telling you that the boot sector cannot be read. If you have recovery discs, you may try a recovery. A full recovery will erase all your personal files. If it gives you an option to restore to an earlier working startup or repair startup, choose those options first.
Since it is an HP, it will give you the option of running the recovery program from the protected area of the hard drive when the HP screen comes up during startup. Pushing F11 during the startup screen on an HP will nomally take you to a recovery mode. F9 may take you to a diagnostic and you can check your hard drive from there.
You can press F10 to enter the Setup menu. You can check your basic settings to see if the computer is registering your hard drive. Do not make any changes in the Setup Menu unless you know what you are doing.
You can boot your computer from a bootable DVD or USB device (press Esc key during startup to change your boot order) and then try to copy your files to a USB drive. Once your files are safe, you can attempt to recover Windows without fear of losing your data.
If you are handy with your hands, you can remove the hard drive and connect it to another computer via a USB adapter to copy your files to a safe location or/and run diagnostics.
Quite often, a virus will target your boot area of the drive rendering it unable to boot your computer, but the drive and your data can be recuperated. USB adapters for laptop hard drives can cost you as little as $10 on Ebay.
Good luck
Jul 31, 2011 | Computers & Internet
In my compaq laptop hard disk is not operating while same hdd is working in other laptop
Windows uses Registry Keys, from XP onwards. If you remove a working bootable hard drive from your pc and place it in another pc, there is a very real possibility that the Registry will record foreign Keys as it is in a different pc and delete some of the Registry Keys, making it non bootable. It can even render the information, files, documents etc un readable.
I suggest refitting the hard drive and running the recovery programme in the hope you can rebuild the Registry Keys. Then run CHKDSK/F to detect any errors on the surface of the disk.
Hope that fixes it.
Dec 20, 2010 | HP Nx6310 Notebook
Wireless switch orange all the time on hp g6000 cant connect to web, was working perfect just stopped,
Hi
1 thing for you to check first.Go to Start-Control Panel-System-Hardware-Device Manager.Look down at the Network Adapters category and see if your device somehow became disabled,and if so right click on it and select enable.If it's x'd out,see if it tells you there is a driver problem.
Next,if you still have a connection to a desktop and are using a wireless router,try going to the Router's website and go through the wireless and network setup processes again.And see if that helps.
If you can't do anything there,the cheapest fix is to get a USB network dongle.You can run your laptop connection through 1,and you really have no other option if your onboard adapter has gone bad,other than take it to a shop,and that will be far more expensive.
If this helps,would you please rate my post?
Let me know what happens.
Bob
Aug 17, 2010 | HP Compaq Presario F500 F700 and G6000...
Compaq Presario F500 F700 and G6000 Motherboard - 442875-001 : motherboard of my laptop is gone. What can I do?...
If you sure that your Motherboard is gone and wont work at all, sorry to tell you that but you need a new Motherboard and a new laptop.
May 17, 2010 | HP Compaq Presario F500 F700 and G6000...
HP laptop will not recover or restore! HP
Run a system restore back to factory default setting.
Start system and hold down the f11 key till it rings a bell.
This will start the restore program.
Follow the system prompt. But remember to backup your documents and files.
Good luck.
Feb 04, 2010 | HP Pavilion dv6812nr Notebook
How do you open the casing on the HP G6000 (laptop). My wireless is not working I believe there is a fault with the switch. The only areas i can get into is the ram and the hard drive.
h10032.www1.hp.com/ctg/Manual/c01095493.pdf
This is the disassembly instructions straight from Hewelett Packard. Just click the link above and it will either automatically download the PDF or open in your browser. I hope this helps.
Mar 25, 2009 | Computers & Internet
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
124 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
